The 2.7L Single Cab Thread
Discussion in '4 Cylinder' started by BabyTaco, Jan 7, 2012.
  1. Nov 26, 2018 at 9:34 PM
    13yota
    13yota Well-Known Member
    Colorado
    2013 2.7 single cab 4x4
    I used corbeau seats, their brackets fit perfectly. I used my own seatblets. The airbag wiring has been my only difficulty, i was able to transfer the passenger seat sensor fairly easily.
    06RegCab1[QUOTED] likes this.
  2. Nov 26, 2018 at 10:03 PM
    stlntaco
    stlntaco Well-Known Member
    Jake
    California
    ̿̿ ̿'̿'\̵͇̿̿\з= ( ▀ ͜͞ʖ▀) =ε/̵͇̿̿/’̿’̿ ̿ ̿̿
    Metaltech4x4 makes an OCS module that converts the passenger seat weight sensor to a switch, has an optional wire you can connect that disables the seat belt chime and lights so you can run harnesses, and comes with the resistors to turn off the airbag light. I bought it with my Corbeaus. If that helps.
    06RegCab1 likes this.
  3. Nov 26, 2018 at 10:43 PM
    06RegCab1
    06RegCab1 Well-Known Member
    Wyatt
    Maui Hawaii
    2006 Regular Cab, 2.7 5 speed mt, 4x4
    Raptor lined basalt gray CBI off road moab 2.0 bumper steel CBI off road ifs skid steel Home made high clearance rear bumper McNeil racing +2" fiber glass fenders Cali Raised LED fog's (flood, amber) Arb air locker, 5.29’s Alpharex headlights 17" Stealth Custom Series Ray 10 35x12.50r17 MTZ’s King 2.5" extended travel coil-overs 650lbs springs AccuTune valving Total Chaos UCA's King 2.5" RR rear shocks Icon RXT Leafs Down south motorsports extended brake lines MagnaFlow Catalytic Converter MBRP Cat Back Exhaust 2.5" axle dumped LCE Heavy Flywheel URD ST shifter AJT design 5spd shift knob Sundown Audio SA 6.5 sub Audio control 4 channel Skyhigh car audio 6.5’s and 1” tweeters Lots of second skin sound deadoner
    Ive been wanting to swap seats so bad, my bench seats springs under the left side on the drivers seat all broke and im using 200lbs zip ties to hold up my left leg, also previous owner stripped all the bolt holes out, and left a gaping hole where the front right mounting location would be, so i have to re-tap and weld in new metal :frusty:
  4. Nov 27, 2018 at 5:49 AM
    13yota
    Colorado
    I have that actually, though my weight sensor was a different part number that had a different connector. I moved the weight sensor over to the new seat fairly easily, works perfect. I didn’t realize it came with resistors for the airbag! I was so disappointed it didn’t fit I put it all back in the box and haven’t looked at it since. I’ll definitely check it back out!
  5. Nov 27, 2018 at 5:51 AM
    13yota
    Colorado
    Highly recommend it if you can! Made a huge difference! I haven’t looked underneath, and the holes in a location you can just put a nut on the bottom side to hold a bolt down?
  6. Nov 27, 2018 at 4:42 PM
    06RegCab1
    Wyatt
    Maui Hawaii
    It ended up in a part of the body I couldn't snake a bolt through, it frustrates me enough where I've considered selling the truck multiple times, every single spot a bolt should thread into is stripped, or like the last pic just a huge ass hole
  7. Nov 27, 2018 at 6:34 PM
    13yota
    Colorado
    I’ve had a few jeeps like that it really makes everything about it a pain. Any possibility of putting in random seats and mounts from another vehicle and just welding it down?
  8. Nov 28, 2018 at 5:37 PM
    bringenufgun
    bringenufgun Well-Known Member
    Bill
    OFallon Mo.
    14 Tacoma regular cab 4X4
    none
    anybody here like their bench seat besides me?
    whatstcp likes this.
  9. Nov 28, 2018 at 5:41 PM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I do, but I'm old school. Trucks have benches and sports cars have buckets. :)
  10. Nov 29, 2018 at 6:36 AM
    Greenpants
    Greenpants Well-Known Member
    Massachusetts
    2009 4x4 Tacoma 4 banger
    The tailgate mod
    Like the bench too. Had buckets in my old 96 Taco & used to sit one of my kids on the console. Yah, I know , no seat belt , it was th
    e olden days.....
    greenpants...mike
    Bikinaz[QUOTED] likes this.
  11. Nov 30, 2018 at 4:54 AM
    bringenufgun
    Bill
    OFallon Mo.
    none
    well i'm 63 and maybe that's part of it. but the damn thing is comfortable to me and fits right. sold my optioned out FJ to buy this. love the spartan accommodations of the TacomaIMG_0673.jpg .
    bijick, Early B. and tacoburrito like this.
  12. Nov 30, 2018 at 7:40 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I drive my truck like a sports car and with the 885 springs/Nitro shocks and 305 tires it actually handles well and takes turns at speeds like a sports car. So the buckets definitely help hold you in place better than the bench. Now if it only had an engine like a sports car! :D
  13. Nov 30, 2018 at 9:29 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    +1 -- although straight line performance is lacking mine will embarrass sports cars in the corners and on the exit/entrance ramps. If I fitted some real sticky soft compound tires it would be even more impressive. I also own a sports car, a quick motorcycle and a supermoto so I know corner speeds.
    Bamagrad2002, Yotabilly and ryfox0276 like this.
  14. Dec 1, 2018 at 2:37 AM
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    Who has a remote start? Wanting to add it but being told because I have manual locks they either won’t do it or it would be a lot more money because they would have to run a bypass to the door
  15. Dec 1, 2018 at 7:38 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    I don't know if yall are still asking seat questions, but I put buckets out of a 2010 Scion xB in mine. Made the mounts myself, they are almost too big. In the middle is a dometic cf11 fridge freezer.
    the macf likes this.
  16. Dec 2, 2018 at 7:47 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Years ago, I installed a remote start in an old 80's 4Runner. I know I did not hook up any power door locks (not sure if the truck had them). But that was quite a while ago and maybe the newer remote starts are different. Ask them what brand it is and then research it compared to other brands.
  17. Dec 2, 2018 at 7:51 AM
    RhodeIsland4bang
    RhodeIsland4bang Back seats are for freeloaders!
    Rhode Island, USA
    2011 DCSB SR5 6MT
    Count of one four legged freeloader
    I’d like to see that, do you have a build thread or one about the seats/refrigerator?
  18. Dec 2, 2018 at 11:22 AM
    Nomad_Pilot
    Clay
    Ft Collins
  19. Dec 2, 2018 at 11:26 AM
    Nomad_Pilot
    Clay
    Ft Collins
    Now a days some states legally require any vehicle that can be remote started to have electronic locking doors to prevent theft. I know it's stupid. I know for a fact Florida is one because I got a ticket for it
  20. Dec 2, 2018 at 5:06 PM
    RhodeIsland4bang
    Rhode Island, USA
    2011 DCSB SR5 6MT
