The 2020 Annual Citrus Meet!
Discussion in 'Florida' started by Key-Rei, Jul 19, 2015.
  1. Jan 31, 2019 at 5:55 AM
    #3461
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Anyone not using there campsite or backing out? All doors seem booked and it me and a buddy. 2 trucks. Longvtravel 3rd gen and a 2nd gen
    FlyinRyan893 likes this.
  2. Jan 31, 2019 at 5:56 AM
    #3462
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    if you don't have any luck, look at mutual mine. My exterra buddies are camping there, it may have some open spots.
    dnpbakon[QUOTED] likes this.
  3. Jan 31, 2019 at 6:24 AM
    #3463
    dnpbakon
    Kevin
    I’ll look into that if we have no luck!
  4. Jan 31, 2019 at 8:27 AM
    #3464
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Tillis Hill is also a good spot if you don't have dogs. They don't allow dogs there because it's the campground for the horses.
  5. Jan 31, 2019 at 10:26 AM
    #3465
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I have one spot at my site.
    dnpbakon likes this.
  6. Jan 31, 2019 at 10:50 AM
    #3466
    dnpbakon
    Kevin
    What’s your spot? If my buddy bails I can camp with ya? I’ll split the payment
  7. Jan 31, 2019 at 11:02 AM
    #3467
    5 Lug Fury
    Kenny
    Knoxville, TN
    I'm on site 2 and yeah no prob.
  8. Jan 31, 2019 at 11:03 AM
    #3468
    dnpbakon
    Kevin
    Right on man I’ll be in touch
  9. Jan 31, 2019 at 12:40 PM
    #3469
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Add Brandon D. to site 24. He has one spot available to share still
  10. Jan 31, 2019 at 1:02 PM
    #3470
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Spot is filled already!
    24A. Brandon D.
    24B. @dnpbakon
  11. Jan 31, 2019 at 1:26 PM
    #3471
    Taco No Baka
    Lee
    Tampa, FL
    I'm starting to thing the OGT isn't going to make it to this one. I may have to show up in the T4R and run with the...ahem...overly conservative group. Unless @Timbo's Customs thinks he can get me a set of sliders mounted and I can get the lift done and someone lones me a set of 33x12.50R16 MTs. I know @Rattletrap66 and I could get the lift on in a day. The rest I'm not so sure of and I'd still be open/open, although I do have traction control without the center diff locked...I assume that extends to all four corners.
  12. Jan 31, 2019 at 1:37 PM
    #3472
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :rolleyes: OP needs updating :D
    Well damn. It won't be the same without the OGT. Tim is welding up Brandon's sliders soon so doubt he'll have time for another set
  13. Jan 31, 2019 at 1:41 PM
    #3473
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I'm not attending so campsite 18 will be open with "Dom the Impaler"
  14. Jan 31, 2019 at 1:43 PM
    #3474
    Taco No Baka
    Lee
    Tampa, FL
    So noted. Got a lot of shit on my plate, so I'm trying to keep up as best I can.
    As far as the OGT, she might end up needing an ECU. At any rate I'm probably going to have to go visit with @Scooter WCT and while I cough up the diagnosis fee to figure out what's going on with it. Plus I have a confirmed rod knock, not as bad as Frank's but it's there none the less.
  15. Jan 31, 2019 at 1:49 PM
    #3475
    Taco No Baka
    Lee
    Tampa, FL
    OP updated correctly? Check me Frank. I've been dealing with shit so I might have missed something.
  16. Jan 31, 2019 at 2:09 PM
    #3476
    dnpbakon
    Kevin
    Message or text me buddy a friend of mine would like to split the spot with you 9546558316
  17. Jan 31, 2019 at 3:56 PM
    #3477
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Well @Taco No Baka , looks like Dom had said he was splitting with Brandon a few weeks back. Sorry Kevin!
  18. Jan 31, 2019 at 4:03 PM
    #3478
    TacoTRD78
    Stuart,fl
    Dom was splitting site 18 with me so Dobbs can take my spot at 18 and 24 should be open for Kevin and his buddy90C67B15-057E-4D49-A312-BC5180D27F37.jpg
  19. Jan 31, 2019 at 4:09 PM
    #3479
    Taco No Baka
    Lee
    Tampa, FL
    :boom::bananadead:
    You guys figure out what's going on and let me know, haha.
    TacoTRD78 likes this.
  20. Jan 31, 2019 at 4:16 PM
    #3480
    TacoTRD78
    Stuart,fl
    :rofl::rofl:
