The 4.88 mega thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JerryTaco, Sep 24, 2017.
  1. Dec 30, 2017 at 7:27 PM
    #241
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    No. Didn't have time to ship and receive. No biggie, the break in sounded pretty simple.
    KTJO 4x4 likes this.
  2. Dec 30, 2017 at 7:31 PM
    #242
    TWTaco
    TWTaco Well-Known Member
    Dave
    Will be getting mine sent out to REM Tuesday i hope!
  3. Dec 30, 2017 at 8:39 PM
    #243
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    I did mine at the same time too
    KTJO 4x4 and MESO[QUOTED] like this.
  4. Dec 31, 2017 at 10:59 AM
    #244
    CooleyOne
    CooleyOne TRD OffRoad
    EastBay, NorCal
    2017 TRD OffRoad Taco
    2017 TRD OffRoad
    What's that? Needle bearing removal as precautionary?
  5. Dec 31, 2017 at 11:09 AM
    #245
    MESO
    State of Jefferson
    Yes
  6. Jan 12, 2018 at 6:42 AM
    #246
    CooleyOne
    EastBay, NorCal
    2017 TRD OffRoad
    Follow up. Truck is in the shop, they looked at ABS sensors and apparently they all tested correct and operable. They're taking it to another shop to do a different 'scan' and see what that yields. Of note, they also said they inspected the Actuator and its functioning properly.
    The Shop continues to be insistent that the Hypertech is what's needed to clear the ABS/DSC lights and suspects the 4WD is due to the truck being in a 'Limp' mode from said lights. Based on the feedback from this this forum, I'm proramming my new Hypertech with JUST the Wheel Diameter parameters (31" Old / 35" New) and then will plug this in to see what we get. Will NOT be entering in the differential data (old 3.91 / new 4.88).
    Feel like we're just grasping at straws now and guessing what's going fix everything. Not throwing shade at the shop yet as they're trying to work with me. Just wishing I had an expert Taco mechanic who new exactly what was happening and could say, "oh yeah, here's the issue and we'll get it fixed ASAP" rather than a bunch of "i think... let's try this" going back and forth....
    Friedtacolover likes this.
  7. Jan 12, 2018 at 7:08 AM
    #247
    CooleyOne
    EastBay, NorCal
    2017 TRD OffRoad
    Also thinking that since the ABS/DSC lights come on instantly, without even shifting into gear, that the truck is sensing/reading a problem right away. It's NOT thinking everything is fine, then after driving reading any data and THEN turning on the lights. Like something is broken -OR- it's in "Limp Mode" as stated earlier. I'm not sure if the truck needs to be Reset, like disconnecting the battery or something. Again, I'm just guessing at troubleshooting.
  8. Jan 12, 2018 at 7:22 AM
    #248
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Try unhooking the battery for a while and let everything reset.
    The ole "did you unplug it and plug it back in" trick.
    CooleyOne[QUOTED] likes this.
  9. Jan 12, 2018 at 12:27 PM
    #249
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Is your hypertech hooked up correctly? I had the same lights until I flipped the connections on the board.
  10. Jan 12, 2018 at 12:28 PM
    #250
    Trident904
    Brian
    17 4Runner TRD OR
    Sitting here at ECGS while they finish up installing my 4.88s. The anticipation is killing me.
  11. Jan 12, 2018 at 12:48 PM
    #251
    CooleyOne
    EastBay, NorCal
    2017 TRD OffRoad
    Just got a new unit and there is no board anymore. The dongle has a female and male end, plugs directly line. I had the older version and am familiar with the board. Posted previously that I tried all combinations, which you suggested. Good thought! Tried that. ;)
    Trident904[QUOTED] likes this.
  12. Jan 12, 2018 at 10:23 PM
    #252
    Trident904
    Brian
    17 4Runner TRD OR
    Now I'm having issues with my hypertech after the 4.88s went in. The truck says Im averaging 10.8 mpgs while actual mpgs are around 12.7 mpg per my math (which could very possibly be quite questionable) and my speedo is 10 off after plugging the new data into the hypertech. Something does not seem right. Should I not have input my new gear ratio? How do I reset the hypertech to "new in box" status?
  13. Jan 12, 2018 at 10:28 PM
    #253
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    I think speed and odo are measured at the wheel, so changing gears won't change that. You only have to correct for increased tire size? I'm sure someone will correct me if I'm wrong.
  14. Jan 12, 2018 at 11:02 PM
    #254
    MESO
    State of Jefferson
    Have you unchecked the gear difffernce section and re-try it yet?
    Trident904 likes this.
  15. Jan 13, 2018 at 1:06 AM
    #255
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Do not put gears in hypertech it messes everything up only tire size. To revert use factory tire size for stock truck then redue it.
  16. Jan 13, 2018 at 1:48 AM
    #256
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Anyone with 4.88s do a 0-60 test on camera yet?
  17. Jan 13, 2018 at 8:31 AM
    #257
    metal-rex
    metal-rex Well-Known Member
    Meridian, Idaho
    2017 Inferno TRD OR DCSB
    Avid sliders
    How do these trucks run with 4.88s on 265/75 r16 or similar? I've been searching and can't find someone with experience. How does it run through the gears?
  18. Jan 13, 2018 at 9:04 AM
    #258
    Trident904
    Brian
    17 4Runner TRD OR
    RPM would be high as hell
  19. Jan 13, 2018 at 10:08 AM
    #259
    doubletap
    doubletap Well-Known Member
    Los Angeles
    2017 Tacoma TRD Offroad MGM
    So how are you liking the 4.88’s? Notice a difference at all? My truck is in the shop getting 4.88 nitro gears installed right now but won’t be finished till Monday. Anticipation is killing me.
  20. Jan 13, 2018 at 10:18 AM
    #260
    CooleyOne
    EastBay, NorCal
    2017 TRD OffRoad
    Can you (or anyone) elaborate on the details of What is precisely happening and Why 'it messes everything up'. Not sure what 'everything' is, sorry just don't understand but there might be some value here if you can explain? Many thanks. Kind like going to the doctor and saying "i'm totally messed up" - he would ask you to please be more specific. ;) Only trying to learn specifics, again with hours trying to get to the bottom of many dynamic aspects. Again, thank you.
    I'm asking because I'm knee deep in a whole 31" to 35" tire/wheel upgrade, 3.91-to-4.88 Nitro install and Hypertech programming. I've been troubleshooting for hours between this forum, Hypertech support (which incidentally was completely MIA yesterday along with a non-functional website) and my shop. Many of whom are giving me "I think" and "it should be" and "have you tried" or "a guy once said" ... not trying to be cynical, just honestly trying to get real data and specifics to fix, not experiment - which is what I feel I'm doing with opposing ideas. :)
    Again, thank you! Once I'm out of the woods on my build, I'll be happy to document exactly what happened along the way, what I learned and try to provide the What, Where, When, Why and How it all came together.
    McFlysRide likes this.
