The 4.88 mega thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JerryTaco, Sep 24, 2017.
  1. Nov 11, 2018 at 7:37 AM
    #721
    Seannysins
    Seannysins New Member
    Sean
    Tucson
    2017 Tacoma TRD Sport 4x4
    285/70r17 tires, VTX wheels, 3 inch Fabtech Dirtlogic lift
    Does anyone know a good place in Tucson to get a regear installed?
  2. Nov 14, 2018 at 8:35 AM
    #722
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Has anyone had an issue after putting in gears where at redline at WOT the truck just falls on its face. Hitting rev limiter and fuel cut off?
    I'm running the TSB with 4.88's and 265/70/17 tires. More and more lately if at wide open throttle and the truck reaches redline it just cut's out and stumbles then upshifts and then away it goes. Happens in all gears in almost all situations.
  3. Nov 14, 2018 at 9:43 AM
    #723
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Ah so I ran into the rev limiter but even with 5.29s I had to really to stomp the gas to do it. Ya the truck basically just topped out until it shiffted. Normal as far as I can tell and no real reason to be revving that high anyway. I dont drag race the truck so no reason to ever have the gas pedal pegged like that.
    mcharfauros likes this.
  4. Nov 14, 2018 at 9:46 AM
    #724
    commbubba19
    '23 TRD PRO
    oh i agree. but around here if you're not up to speed and you need to merge, it can happen. most of the time it's in that 2-3 shift area.
    there's also times i need to pass on a single lane highway. last thing i want is the truck to putt out when i have oncoming traffic.
  5. Nov 14, 2018 at 9:47 AM
    #725
    JoeCOVA
    Joe
    Colorado Springs
    How many miles on the new gears? Tranny may need more time to figure itself out.
  6. Nov 14, 2018 at 9:48 AM
    #726
    commbubba19
    '23 TRD PRO
    couple thousand
  7. Nov 14, 2018 at 9:51 AM
    #727
    JoeCOVA
    Joe
    Colorado Springs
    Hmmm I guess its just normal then? I dont know, we are definitely hitting it but probably no way to avoid it
  8. Nov 14, 2018 at 12:55 PM
    #728
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    yes
    I've learned to drive without hitting the cutoff by not thinking my truck is anything sportier than a lifted truck with 35s and gears.
  9. Dec 3, 2018 at 7:54 AM
    #729
    rasber3140
    rasber3140 Well-Known Member
    2021 TRDOR Barcelona Red
    Where would y'all recommend getting Nitro 4.88's for a 2018? The Toyota master mechanic at my dealership said he would do the work for $600, I just need to bring in the gears.
    mcharfauros and 4x4Taco09 like this.
  10. Dec 3, 2018 at 8:56 AM
    #730
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    If that price includes pulling the pumpkins that is a killer deal. check the group buy section - there was a Nitro gear group buy going on. If not check with @Babyjake16 - he may be able to point you in the right direction for a much better price than vendors or Nitro direct. GL.
    xsf18cdf, mcharfauros and Babyjake16 like this.
  11. Dec 3, 2018 at 8:57 AM
    #731
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    Directly from Nitro. -- Wow! $600?
  12. Dec 3, 2018 at 9:00 AM
    #732
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    I’m pretty sure nothing changed really from 17 to 18. Depending if your truck is AT or MT and what tire size you run. Some feel the MT is perfect (depending on tire size)
    The AT i’d say regear would be beneficial regardless. The double overdrives are too tall...I wish Toyota continued to have used the 5 speed auto but whatever’s. 4:88’s and 33’s on my truck feels perfect
    $600 is deals tho. I paid 760 for labor
  13. Dec 3, 2018 at 10:31 AM
    #733
    rasber3140
    Thanks for the heads up on the group buy. I will give him a shout when he gets off of work to confirm, but when we talked he said he was going to plan for 17 hours of labor to do front and rear. I had just assumed that meant pulling pumpkins.
  14. Dec 3, 2018 at 10:46 AM
    #734
    GoldenBrew
    Golden, Colorado
    those kind of hours would, or should, include pulling them, removal, install and set-up on new gears, …. the whole tamale and some breaks between. Still a great price.
  15. Dec 3, 2018 at 12:35 PM
    #735
    Babyjake16
    Babyjake16 @project_traitor
    Jake
    Utah
    2008 Super White Tacoma
    33" Nitto Trail Grapplers 17" TRD Matte Black Wheels ICON Stage 5 w/ differential drop 30% Tint 2 - Pioneer 12" Shallow Mount Subs Focal Speakers Pioneer Head Unit 2 - Pioneer Amps Custom Stickers/Badges Paracord Grab Handles Painted Interior (all panels, headliner and carpet) Clazzio Leather Seat Covers with leather arm rests Ditch Lights 3 - 8" HieseLight Bars in bumper Rock Lights - Cali Raised LED Custom Fabricated Front Bumper - Blackout Fabrication Rock Sliders - DOSECC Fabrication Bushwacker Fender Flares (color matched) Morimoto LED Fog Lights
    Appreciate it!
  16. Dec 3, 2018 at 1:23 PM
    #736
    GoldenBrew
    Golden, Colorado
    check with @SDHQ OFFROAD seems to me they do installs - Gilbert AZ - close to you.
  17. Dec 3, 2018 at 1:27 PM
    #737
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I just had 4.88 installed in mine. No noises.
    The shop recommended the following break in period regardless of the polish (mine is cryo'd).
    First 100mi, 15-20mi driving under 50mph, easy on the throttle. After 15-20mi, let truck cool off for 30min.
    Next 400mi, drive under 65mph, easy on the throttle.
    At 500mi, change diff oil.
    Amazing difference now compared to stock, and got some MPGs back. Really happy with it.
    taco 16, CMScheid and mcharfauros like this.
  18. Dec 5, 2018 at 12:37 PM
    #738
    Hookedup
    Hookedup Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    What size tires?? 285/75R17?? 33-34”?? I’m just curious cuz I’m about to buy a 2019 TRDOR and I’ve already purchased all suspension parts and plan on running that size tire\wheel.. I have no issues (that i can tell) on my 2012 running similar size.. seems the gears will cost an additional $2+K.. oh boy!!
  19. Dec 5, 2018 at 1:03 PM
    #739
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    255/85R16
    Hookedup[QUOTED] likes this.
  20. Dec 5, 2018 at 2:08 PM
    #740
    commbubba19
    '23 TRD PRO
    Any issues with wide open throttle and upshifts?
    I’ve posted about mine having issues on the upshift and pulling major power after the shift. Then comes back.
