The 4.88 mega thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JerryTaco, Sep 24, 2017.
  1. Dec 5, 2018 at 2:12 PM
    #741
    Hookedup
    Hookedup Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    Ok nitro gears I assume.. what issues did you have before?? Lagging power?
  2. Dec 5, 2018 at 2:33 PM
    #742
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I'm not sure as I only got them installed 150mi ago and I'm still in the break-in period.
  3. Dec 5, 2018 at 2:34 PM
    #743
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Yes Nitro. I have a lot of weight and bigger tires so it's just lagging behind and had to step on the throttle more than usual with stock gears.
    Hookedup[QUOTED] likes this.
  4. Dec 5, 2018 at 4:44 PM
    #744
    Hookedup
    SOFLO
    Ok I’ll see what performance i get once i install tires and lift thanks
  5. Dec 5, 2018 at 4:57 PM
    #745
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Deciding whether to regear with 4.88/ ARB lockers or to wait until the OV Turbos become available. Having some added low end torque & ponies will dramatically reduce need for new gears.
  6. Dec 5, 2018 at 6:05 PM
    #746
    NickJacq23
    NickJacq23 Well-Known Member
    So you’re running 37’s with 4.88’s?? Would you mind shooting me a PM if so
  7. Dec 5, 2018 at 6:17 PM
    #747
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    If you are in an Air Quality zone - emission requirement - you won't be adding the OVTune Turbo option. It does not meet requirements. If you are in an area that does not have emission requirements many of us will be soooo jealous!
  8. Dec 5, 2018 at 6:27 PM
    #748
    erok81
    erok81 Well-Known Member
    Imposter
    Yes 37’s with 4.88’s. Let me know what questions you have.
  9. Dec 31, 2018 at 6:28 PM
    #749
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    I'm thinking about regearing to 4.88 within about a month on my rig with 33" tires. If I ever go bigger, it wouldn't be for at least 5 years.
    My problem is that I get 17ish mpg in the city but only 13 mpg on the highway. I have a lot of drag from my aluminum cab/bed rack. I don't have much armor though, so I'm not too heavy. Steel bumper/winch and steel sliders are all I am planning on. Then again wheel/tire combo is 84lb each.
    Am I correct to be planning on 4.88 or should I get 5.29?
  10. Dec 31, 2018 at 7:05 PM
    #750
    erok81
    Imposter
    I wouldn’t do 5.29’s with 33’s. Someone here did. If you search around it’s in this section for the forum. Mine was fine with 4.88’s and 35’s. Is yours an auto or manual?
  11. Dec 31, 2018 at 7:39 PM
    #751
    DaMaDo
    Northern AL
    2018 White TRD Pro
    Auto, it NEVER goes into 6th. Ever. Sometimes it likes to stay in 4th at 70....and mileage is better than in 5th.
  12. Dec 31, 2018 at 8:52 PM
    #752
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    If you plan to go larger tires (even if it’s 5 years down the road) do the 5.29’s. It’s such an invasive process to do gears, and expensive (unless you do it yourself) save the headache and do it right the first time. You’ll save money, time, and prevent doing a second break in procedure in the end (unless you cyro)
    taco 16, DaMaDo[QUOTED] and H3llRid3r like this.
  13. Dec 31, 2018 at 9:04 PM
    #753
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Honestly, I would look hard at the 5.29’s. I did the 4.88’s and I’m happy with them, but if the 5.29’s were available at the time I would’ve done them. I do have 34” tires and lots of armor, but I don’t see how you could go wrong with 5.29’s.
    taco 16, DaMaDo[QUOTED] and alwaysHI like this.
  14. Dec 31, 2018 at 9:26 PM
    #754
    alwaysHI
    2017 MGM DCSB
    Same. I’m on 33’s and at the time only 4.88’s were available. I love the truck how it is with gears. Wouldn’t mind feeling what 5.29’s would be like tho haha. Guarantee a lot of pep to the step!!
    taco 16, DaMaDo and H3llRid3r[QUOTED] like this.
  15. Jan 8, 2019 at 9:40 AM
    #755
    VTTaco97
    VTTaco97 Member
    Virginia
    2018 DCLB TRDOR
    285/75R16 KO2s, 2in Eibach Pro, 4.88 Yukons, OVTune 1.05
    I'm on 33s with 4.88s and it's perfect for my truck, but I don't have any extra weight other than about 100lbs of tools in the back. I turn 2100 rpm in 6th at 70 mph.
  16. Jan 8, 2019 at 10:57 AM
    #756
    DaMaDo
    Northern AL
    2018 White TRD Pro
    That might be best for me. All the non-removable stuff I'm adding is about 400lb.
  17. Jan 8, 2019 at 10:58 AM
    #757
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    That has more to do with Toyota and their throttle map. Get a re-tune like the OVTune..
  18. Jan 8, 2019 at 11:01 AM
    #758
    DaMaDo
    Northern AL
    2018 White TRD Pro
    Yeah that will be my next mod after regearing.
    sd1uh8as[QUOTED] likes this.
  19. Jan 8, 2019 at 11:11 AM
    #759
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Mine as well
  20. Jan 8, 2019 at 1:31 PM
    #760
    H3llRid3r
    SLcUT
    I would go with 5.29’s, if I was to do it again.
    taco 16, mcharfauros and JoeCOVA like this.
