The 4.88 mega thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JerryTaco, Sep 24, 2017.
  1. Sep 30, 2017 at 6:08 AM
    #101
    Marc529
    Marc529 Well-Known Member
  2. Sep 30, 2017 at 1:53 PM
    #102
    socal996
    socal996 Well-Known Member
    Thanks for the info
  3. Oct 4, 2017 at 8:45 PM
    #103
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    A little more detail on my gear swap and how I use my truck. My 2016 TRD OR 4x4 is my daily driver, trailer puller and trail explorer. It's about 2 years old and I've got 25k on the truck. I work 48hr shifts and am fairly close to my job so I don't have allot of comuting miles. Most of the trucks time has been spent pulling my camper to the mountains and cruising around the desert.
    I'm running 265 75r16 general x3 tires which are just under an inch taller than the stock TRD OR tires so I was definatley concerned about being over geared before taking the plunge.
    The 4.88s have made a HUGE difference in towing performance. Overall RPMs are lower due to the ability to hold higher gears and trans temps average much lower as well. Towing MPGs are up too. Be aware that diff temps are probably up little since the diff is now expierencing more revolutions but there is no easy way to monitor that.
    Daily driving is IMO an improvement as well. First gear is a bit too low but I'd consider overdrive to be a big improvement as it hardly ever shifts out of 6th gear (driving 75-80 mph). MPG has only slightly improved but I'm overgeard with my tire size.
    Off-roading has of course also become allot more fun! The first gear that feels bit to low on the road is just right and the extra torque is phenomenal. I recently spent some time on the Oregon dunes and can say I had a blast driving the truck in sport mode (allot of 2nd and 3rd gear) keeping the RPMs up.
    Now as far as metal treatments, and break in goes I opted for the standard break in routine. I called around my area and found cryo treating to cost about as much as the gear sets. I know cryo is a must with monster trucks and rock bouncers but I didn't think it'd be necessary for my 275hp truck on 32s... I didn't rem polish either since it would've delayed my install (which I wanted complete before my last trip) and I would've done a proper break in anyway. Break in is simple, a few heat cycles, 1000 miles easy driving, no highway droning and then a few more heat cycles with your trailer if you plan on towing. I changed my diff oil after about 1100 miles and found it to be in like condition, also found very few very small fragments on the diff magnet.
    I had AZ diff specialist do the work. Great shop that does nothing but differentials. I'd say they are Toyota experts but they're also pretty much experts in for any vehicle that has a ring and pinion.
    Midnite2020Pro likes this.
  4. Oct 4, 2017 at 8:59 PM
    #104
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Great to hear that you're running 32's with this. I'm running 33's (285/70/17) so my anxiety of being over-geared is diminishing.
    Joe23 and Lord Humongous[QUOTED] like this.
  5. Oct 4, 2017 at 9:01 PM
    #105
    Lord Humongous
    AZ
    Dude, due the over drive gears being so high I'm pretty sure most owners would be happy with 4.88s on stock tires!
  6. Oct 4, 2017 at 9:27 PM
    #106
    PNWTacoma
    Paul
    That's why I decided to bite the bullet on this upgrade. My truck is only 5 months old with only 7k miles and it's terrible on long drives, especially when I only average 13 mpgs...
  7. Oct 4, 2017 at 9:42 PM
    #107
    JerryTaco
    JerryTaco [OP] Well-Known Member
    Gears definitely make those long road trips infinitely more enjoyable. My truck will be a year old at the end of the month with almost 25k miles. It's seen about have the miles prior to the re gear and can tell you that the second half has been a lot more enjoyable! I am also carrying a lot more weight now as well and yet the truck is so much more fun to drive
    PNWTacoma[QUOTED] likes this.
  8. Oct 5, 2017 at 7:07 AM
    #108
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    exactly what my plan is - 4.88 w stock tires. ??? What about breaking in the front differential gears- seems like that should be done but running fwd on dry pavements is not a good thing. ???
  9. Oct 5, 2017 at 7:31 AM
    #109
    PNWTacoma
    Paul
    Thanks for the validation. I'm looking to have a "new" truck again!
    Question, though, do you have the Shift sense pro and TSB done as well (only if you have an A/T)
  10. Oct 5, 2017 at 7:32 AM
    #110
    PNWTacoma
    Paul
    I'm sure it's fine in a straight line, but why don't you hit some dirt or forest roads for this?
  11. Oct 5, 2017 at 7:44 AM
    #111
    JerryTaco
    I do not have the Shift Sense and since my truck is a 2017, i haven't had the need for the TSB. Having said that, my truck shifts great, holds gears and I have seriously not had a single issue. I can't say enough how easy the truck is to drive. Even fully loaded, with my RTT, camping gear and whatever else, it just doesn't have to try hard at all to get up to or maintain speed. Definitely one of my favorite mods hands down.
  12. Oct 5, 2017 at 1:22 PM
    #112
    GoldenBrew
    Golden, Colorado
    ?? Do the front pinion gear and ring gear function independently of fwd? i.e. front gears turning but axle not locked until fwd engaged? If so then it would be breaking in too during the same time the rear is. otherwise you would think they would mention breakin for each front and rear. ???
    RANGER13 likes this.
  13. Oct 5, 2017 at 1:28 PM
    #113
    GoldenBrew
    Golden, Colorado
    I have the SSP and have had all the TSBs done for shifting- things are way better but I think the trans hunts gears too much in the "d" mode. Not much more to be done other than regear - which I think will make the difference. Will report back once all is done.
  14. Oct 5, 2017 at 7:58 PM
    #114
    Cclogan8
    Cclogan8 Well-Known Member
    Logan, Utah
    16 Taco DCLB
    Its getting bad, Im almost broke.
    Im set to have 488’s installed while on vacation in Phoenix in a couple weeks. I’m going to be driving it back to Utah after the install. I’ll report back on my gas mileage to and from.
    JerryTaco[OP] likes this.
  15. Oct 5, 2017 at 7:59 PM
    #115
    JerryTaco
    That's awesome! Who you having do it?
  16. Oct 5, 2017 at 8:02 PM
    #116
    Cclogan8
    Logan, Utah
    16 Taco DCLB
  17. Oct 5, 2017 at 8:03 PM
    #117
    JerryTaco
    Solid choice!!
    Cclogan8[QUOTED] likes this.
  18. Oct 5, 2017 at 8:04 PM
    #118
    Cclogan8
    Logan, Utah
    16 Taco DCLB
    They will also be calibrating the speedo and installing a icon leaf pack in the rear.
  19. Oct 5, 2017 at 8:05 PM
    #119
    JerryTaco
    Hell yeah, gonna be like a whole new truck. The icon leaf pack is amazing. I absolutely love it.. rxt I'm assuming?
  20. Oct 5, 2017 at 8:10 PM
    #120
    Cclogan8
    Logan, Utah
    16 Taco DCLB
    What is RXT?
