The 4.88 mega thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JerryTaco, Sep 24, 2017.
  1. Oct 5, 2017 at 8:16 PM
    #121
    JerryTaco
    JerryTaco [OP] Well-Known Member
    That's the full icon leaf pack replacement vs the 3 lead add a leaf
  2. Oct 5, 2017 at 8:21 PM
    #122
    Cclogan8
    Cclogan8 Well-Known Member
    Logan, Utah
    16 Taco DCLB
    Its getting bad, Im almost broke.
    I currently have a block under my springs with airbags. I asked for deavers and they recommended the icon add a leaf. Maybe becuase the airbags?
  3. Oct 5, 2017 at 8:56 PM
    #123
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    I believe the diff is always passively turning and the power is applied through the t-case when 4x4 is selected.
    I've been told that a few easy 4x4 trips are important for breaking in the front diff.
    Something to think about is the front clamshell holds 1.6 quarts of oil vs the rear (8.75") which holds 4.2 quarts so the front clamshell will heat up allot faster given the same load.
  4. Oct 5, 2017 at 9:48 PM
    #124
    Marc529
    Marc529 Well-Known Member
    I got the same setup and got the truck back today. Stopped 5 times in 45 miles going up hill a 2000' climb overall. I checked the heat with a IR gun, the hottest was 186, cooled to 130 at stops. No speed over 55 most at 45-50 mph so I could not map it at 70 mph. I tow too and live in the hills so this should be interesting. Nice to see higher RPM in 4 gear. I am running the Shift Sense Pro so working on which profile to use. The 3rd profile for more aggressive seems too much. Moved it to the 2nd profile to try tomorrow.
  5. Oct 5, 2017 at 9:55 PM
    #125
    Marc529
    Speedometer discovery
    I installed the calibration unit to adjust for tires and checked it against GPS and it is real close.
    Did the 4.88 and expected to make another adjustment but not necessary. Speedometer is still accurate sooo I think the speedometer is using the ABS sensor system and not the transmission. That is good as this will feed many systems and now my real error factor is just the 1" tire size change.
  6. Oct 5, 2017 at 10:09 PM
    #126
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Have you checked to see if the odometer it's still accurate as well?
  7. Oct 6, 2017 at 4:22 PM
    #127
    Marc529
    Yes odometer is accurate too.
  8. Oct 6, 2017 at 5:00 PM
    #128
    vikingwill
    vikingwill Member
    2016 Blue Access Cab MT Tacoma
    Hey guys, lots of good info I just read here. I'm running 33's on my M/T OR and was wondering if you think it's worth the change from 4.3 to 4.88. From what I'm reading, it sounds like a pretty damn good upgrade but most of you guys have the 3.9 A/T. I'm waiting to hear back from a shop on a quote but I know it's gonna be expensive in Canada so I'm not sure if its worth it. I've added a decent amount of weight with a bumper, winch as well as a couple hundred pounds in the back at all times. I know it would help and I want to do it but it just seems like quite a small difference vs the cost.
  9. Oct 6, 2017 at 5:33 PM
    #129
    Marc529
    4.88 first 100 miles
    My setup- 265/75r16 k2 tires so one size larger at 31.65" I also have the Sense Shift Pro v2 with 3 shifting profiles.
    Off the line the torque improvement is very big. It blast through the first 2 gears as you come up on speed quickly. I now feel like I can match most cars now if I want.
    Most people do the gear mod for big tires, 33"- 35 tires. The result brings the truck back to normal.
    I did this for performance or improved torque applied to the ground. There is no change in engine HP or the torque that the engine puts out.
    To get more torque you need to do two things. Get the engine to run at a higher RPM before shifting and change the diff gear which I did. The stock shift pattern causes you to shift around 2200 rpms most of the time unless you put your foot in it. Running RPM is around 1200 -1800 in any gear. This is well below the power curve that provides max torque at 4600 RPM.
    With the gear change here are some examples: at 40MPH old -1660rpm, new -2072rpm That 412 rpm makes a big difference even if the gears are the same.
    Now the Diff gear change gives an additional 20%.
    I think this formula is correct:
    Our truck has 265ft lbs at 4600 rpm so with the stock gear 3.909 that provides 1036 ft lbs of torque applied to the wheel in 4th gear which is 1:1 ratio. With a 4.88 gear it goes up to 1293 ft lbs. Multiply this by 3.6 (1st gear) and you get 4654 ft lbs applied to the wheels to push the 5,000 vehicle.
    With a new shift map I now get to use the available HP. Now shifting takes place between 3000 and 4000 rpm. The difference now is before when you step on the gas to accelerate say in 4th gear, you downshift to 3rd. Now I don't downshift rather I have the power and additional torque to accelerate staying in 4th and as speed goes up shift to 5th.
  10. Oct 7, 2017 at 9:24 AM
    #130
    K_Sandhu
    K_Sandhu Well-Known Member
    Karan
    Castro Valley, CA
    2017 Double cab TRD off-road 4x4 long bed
    I am planning on buying gears soon and tried to contact couple of vendors here but havent heard anything back from them. Where did you guys purchase your gears from and for how much? Thanks!
  11. Oct 7, 2017 at 9:29 AM
    #131
    Marc529
  12. Oct 8, 2017 at 7:37 PM
    #132
    K_Sandhu
    Karan
    Castro Valley, CA
    Thanks! I will do that. I am planning on taking everything apart myself and then taking the pumpkins to Rearend Specialties in San Jose and get the gears installed
    Toynado likes this.
  13. Oct 9, 2017 at 5:45 AM
    #133
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    Can't go wrong with RES.....
    erok81 likes this.
  14. Oct 9, 2017 at 8:27 AM
    #134
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Word of caution, check your orders when it comes in. I received my box and scheduled my appointment. This morning when I was about to take my truck to the shop, I noticed that the front gears were missing. Stupid me thought both front and rear gears were in the same Nitro box. Sure enough, it was split into two deliveries: one through Fedex and the other through USPS. Well, I found the USPS box but unfortunately it didn’t have the front set, just another install set without the gears. I’ve contacted the Owner and he’s looking into the snafu. Sucks since the gear shop blocked the next two days for my install....
  15. Oct 9, 2017 at 8:58 AM
    #135
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    well that sucks! been reading and following - seems like one or more purchasing options have been less than reliable with orders, parts and shipping. Worries me about who I place order with. Care to share initials or more on who did not get it right the first time?
  16. Oct 9, 2017 at 9:02 AM
    #136
    JerryTaco
    I can tell you that without question, SDHQ is a solid vendor when it comes to shipping. They take a lot of pride in their shipping department and one tour of the shop makes that very clear. Nevertheless, I do know that you likely wouldn't have issues with them.
  17. Oct 9, 2017 at 9:11 AM
    #137
    GoldenBrew
    Golden, Colorado
    probably a good idea to call any vendor being considered to review parts needed, shipping and who to call if something does not arrive as ordered. I'd like to think every vendor on TW list is 100% committed to customer service and competitive pricing.
  18. Oct 9, 2017 at 9:15 AM
    #138
    JerryTaco
    Agreed. I hate the idea of doing everything over email and will always call any customer service line for any given vendor. If they are difficult to get ahold of, or not helpful, usually a deal killer for me.
    PNWTacoma likes this.
  19. Oct 9, 2017 at 9:38 AM
    #139
    PNWTacoma
    Paul
    Well, not the vendors fault on this one. Apparently Nitro had a back order on the front gears and didn’t notify him. Luckily he had a set in the store and is sending it out today. FYI, he mentioned that the front gears are in very limited supply so if you haven’t ordered yet, hurry up!
  20. Oct 9, 2017 at 6:43 PM
    #140
    SilverTacomaGuy
    SilverTacomaGuy Well-Known Member
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Little tree air fresheners. Clazzio black leather seat covers.
    I'm heavily thinking about having some 4.88 gears installed in my truck. As my truck is my daily and only means of transportation. How long does it usually take for a GOOD shop to install gears in the 3rd gen Tacoma's? Is it a task that I can drop my truck off in the morning and drive back home the same night for example?
