The 4.88 mega thread!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JerryTaco, Sep 24, 2017.
  1. Aug 26, 2020 at 7:47 AM
    #1421
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    +1 to this.
    I had my 4.88s installed December 2019. The change was dramatic with 4.88s, but there was still some erratic shifting at highways speeds. Overall I've been pretty happy for the last nine months.
    That said, I finally added OVtune this week. The combination of gears and ovt makes this truck an absolute joy to drive. Do both, you absolutely won't regret it.
  2. Aug 26, 2020 at 3:15 PM
    #1422
    TWTaco
    TWTaco Well-Known Member
    Dave
    No i did not use the master kit my truck was new less then 8000 miles on it. You wont need it. I had the master kit just in case but martin said they are to new to need to replace!
  3. Aug 26, 2020 at 3:25 PM
    #1423
    Tacoman21
    Tacoman21 Well-Known Member
    Bob
    2020 Silver TRD offroad 4x4 DCLB
    3" lift with KMC wheels 285/70/17 4.88 Nitro gears
    I don't mean to bother you but what about the pinion seals and axle seals? They need replaced.
    Did you watch them?
  4. Aug 26, 2020 at 3:28 PM
    #1424
    TWTaco
    Dave
    You better check with Martin on that i cant remember if he did or not on those seals.
  5. Aug 28, 2020 at 8:52 AM
    #1425
    OVR1LND
    OVR1LND Whisker biscuit
    Mesa, AZ
    2019 Cavalry Blue Tacoma TRD OR DCSB
    TJM rock sliders, RCI bedrack, Smittybilt RTT, Cali Raised LED bed stiffeners,JDM ASTAR Headlights
    Love what im reading in the reviews of these 4.88 gears. Im in a 2019, AT with a bedrack, sliders, RTT and 33's. So sounds like these are right for me. I was quoted $1,650 from AZ Differential in town using Yukon gears i believe. So looking to get this done soon. Any comments or advice is greatly appreciated.
    Dirk Diggler likes this.
  6. Aug 28, 2020 at 9:09 AM
    #1426
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    4.88’s will work. I truly think you should consider 5.29’s I’m on heavy 33’s 64lbs ea. And about 300lb total added weight (sliders, Full alum skids, some gear in bed) and truck feels perfect.
    bnh032 and OVR1LND[QUOTED] like this.
  7. Aug 28, 2020 at 10:14 AM
    #1427
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    I would go 4.88 for sure. People also need to be mindful of the fact that 5.29 gears limit your top speed to 83-85 ish mph, 4.88 will limit to about 93-95 mph unless you have that tuned out.Not that you’re going to be doing 80 with all that gear but who knows. I consistently drive 80mph here in SoCal so 5.29 was not going to work for me.
  8. Aug 28, 2020 at 12:10 PM
    #1428
    bnh032
    bnh032 Active Member
    Brandon
    18' cement trd off road
    I went with 5.29's as well, Love them. Night and Day over stock.
    Im on 35's with sliders, armor, bumpers, winch, rack and tent.
  9. Aug 29, 2020 at 8:31 AM
    #1429
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I drive 80 mph a lot with my truck. 5.29’s and 33” I’m limited at 89mph with my speedo corrected for tires. But there is a new test OVtune with a fix being tested right now.
  10. Aug 29, 2020 at 9:33 AM
    #1430
    Anderson5290
    Brandon
    Corona, Ca
    That’s not bad. I’ve heard of others limited to 83-85 mph range. But how is your mileage at that speed? I know at 80 mph mine sucks ass with 4.88 vs with the stock gears. If I’m at 65-70 it’s decent but that too slow for me unless I’m rolling with my Jeep crew.
  11. Aug 29, 2020 at 9:44 AM
    #1431
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    my mileage is pretty bad. But I wasn’t expecting great mileage going with 64lb e load tires. On average around town I get about 14-15mpg. Best I’ve ever got with new setup is about 17mpg all highway. Where I live there’s a lot of hills tho. If it was flatter I’d expect those numbers to be 1-2mpg higher. I usually cruise highway at 65-70mph.
    Completely stock I was averaging 15mpg around town but was able to hit 21mpg highway.
  12. Aug 29, 2020 at 9:46 AM
    #1432
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    4.88MT get 19mpg around town, 22-23-24+ on highway, 30 when feathering.....
  13. Aug 29, 2020 at 9:48 AM
    #1433
    Anderson5290
    Brandon
    Corona, Ca
    My tires are pretty heavy as well and I’m getting pretty close to the same mileage.
  14. Aug 29, 2020 at 10:20 AM
    #1434
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    what's your setup like, that's extremely impressive mileage
    TWTaco likes this.
  15. Aug 29, 2020 at 10:30 AM
    #1435
    Anderson5290
    Brandon
    Corona, Ca
    Im not sure I believe that. I can barley get 24-28 mpg coming down the cajon pass with the wind at my back and I don’t even need to hit the gas for a good while. Best I’ve seen on the street is 14-16.
  16. Aug 29, 2020 at 10:33 AM
    #1436
    TWTaco
    Dave
    He would have to be very light and going no more then 60 on flat highways!
    blitzkrieg3002 likes this.
  17. Aug 29, 2020 at 11:17 AM
    #1437
    Anderson5290
    Brandon
    Corona, Ca
    I get the 22-24 mpg is possible. But 30 even on a stock truck is kinda BS considering my wife’s corolla barley gets that kind of mileage. Maybe downhill but considering what it would take to go up that hill overall mileage would be far less. When I head up to bigbear which is weekly I get crap mileage going up and great mileage coming down so I average like 16-18 but that’s coasting most the way down the hill.
  18. Aug 29, 2020 at 11:41 AM
    #1438
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    30mpg is NOT like get that on a full tank, just saying I can get that down hill, etc pretty normal. But sure, made that up if I said my truck gets 30 mpg. It doesn't.
    OTH I can do my normal commute to work, 12 miles at 4AM and get 20 mpg, NO FREEWAY. Just 35-40 MPH back roads. Coming home, some construction stops, traffic 19mpg
    Right NOW dollars to donuts my trip MPG is reading either 18.7 or 18.9. Because I idled a bit this tank, dump runs, lumber yard and such with no true freeway driving.
    Guys - I am not making this shit up.
    I am running OVT latest MT tune, I don't punch it like I did at first. I carry no weight normal, just bikes and like I said some dump runs and lumber runs. What I do, is get it into 5th or 6th ASAP. Use the low end power for the taller gears. Downshift to 4 for hills, corners in 3rd.
    Now I guarantee my MPG will drop when cold weather and cold weather gas come on.
    Dirk Diggler and Grossomotto like this.
  19. Aug 29, 2020 at 11:52 AM
    #1439
    Anderson5290
    Brandon
    Corona, Ca
    Glad you cleared that up that’s for sure doable. While taking it easy I could probably get close to the same in similar conditions.
  20. Aug 29, 2020 at 11:55 AM
    #1440
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    After the tune, and the 2.0 Upgrade it took months to contain myself. :taco::burnrubber:
