The Dreaded Squeaky Leafs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoman00, Jul 22, 2021.
  1. Jul 22, 2021 at 9:09 AM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    So, once upon a time I owned a 2nd gen, and while it served me very well for 200k miles before I off-loaded it, I was constantly battling those damned squeaky leafs. Fast-forward to now, I own a 2021 model with only 4K miles and while cruising slowly around a National park yesterday on paved ground, I noticed a creaking/squeaking that sounded similar to my squeaky leaf issue on my 2nd gen. I did try the search function before posting and found mostly 2nd gen stuff…
    I was hoping they fixed it on the newer models… anyone else?
    Junkhead likes this.
  2. Jul 22, 2021 at 9:11 AM
    Bishop84
    Bishop84 Well-Known Member
    We fix this at the dealer by simply lubricating the silencer pads with synthetic lube. You spread the leaf with a screw driver and push in silaglyde, or spray lubricant in.
  3. Jul 22, 2021 at 9:13 AM
    tacoman00
    Rockville, MD
    thanks! I’ll do that. It’s frustrating that it’s even an issue on a brand new $40k truck!
    ConantTaco likes this.
  4. Jul 22, 2021 at 9:15 AM
    Bishop84
    My 16 did it when I got it and it made no sense, sounded like a 50 year old truck.
    I tried washing them loaded and unloaded, no luck.
    Finally someone tried the lubricant and it fixed it long term.
    The 2nd gens had replacement silencer pads, but the 3rd gen is presumed to be those pads.
    tacoman00[QUOTED][OP] likes this.
  5. Jul 22, 2021 at 9:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you jack up one side just ahead of the leaf mount, you can almost separate the leafs by hand. Takes 5min total.
    The squeak will go away eventually as the surfaces get mated and polished.
    ConantTaco and SunRunner like this.
  6. Jul 22, 2021 at 9:17 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    This fixed it for me: https://www.kbvoodoo.com/blog/2017/4/6/squeaks-are-annoying
  7. Jul 22, 2021 at 9:17 AM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Reminds me of an old article I read about Jeeps once about packing leaf springs with grease and then wrapping the whole mess with leather and lacing it up. Definitely would quiet things down.
    Personally I don't think it would be worth it.
  8. Jul 22, 2021 at 10:23 AM
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    There's a TSB for squeaky leaf springs: T-SB-0273-17. I had it done on my truck early on. It has permanently eliminated the squeak.
  9. Jul 22, 2021 at 10:37 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I use motorcycle chain wax on mine when they get squeaky. Usually last me 6months-1year between squeaks.
  10. Jul 22, 2021 at 11:22 AM
    tacoman00
    Rockville, MD
    I just googled that TSB and it only lists 16-17 model years…?
  11. Jul 22, 2021 at 1:21 PM
    jayuu
    If that's the case you'll have to revert to one of the DIY remedies. I was getting ready to do the same back in '17 when I came across the TSB and decided to give it a shot. Might be worth your time to check with a dealer to see if it still applies. The worst thing they could do is say "No."
  12. Jul 22, 2021 at 1:34 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    For the longest time, I thought my leafs squeaked. It was actually a spare that was squeaking. I lowered the tire, cleaned it and no more noise. Hope that helps.
    Phlogiston and Moed like this.
  13. Aug 10, 2021 at 10:14 AM
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    Did the dealership charge you for it? My 2016 w/ 45k miles needs the same, but I have no warranty.
  14. Aug 10, 2021 at 1:06 PM
    jayuu
    No. I had reported the issue within the 1st year and had to wait for them to get the parts in. I don't know if they charge for TSBs. You could ask the dealer.
  15. Aug 10, 2021 at 3:25 PM
    NewMexiMan
    2016 SR 5 Speed
    Alright, thanks.
  16. Aug 10, 2021 at 5:15 PM
    ljh824
    ljh824 Regular Guy
    Lou
    Kabul, Afghanistan / Oviedo, Florida
    -21 AG Sport 4x4 DC
    Any ideas on what could be making the front suspension squeak? I've got a nasty squeek coming from the front driver well. I've lived everything that moves and it still squeaks
