The Drifter - Specs and FAQ
Discussion in 'Tonneau Covers, Caps and Shells' started by Iggy, Mar 26, 2018.
Thread Status:
Not open for further replies.
  1. Apr 26, 2020 at 8:52 AM
    #3841
    Sinner2
    Sinner2 Well-Known Member
    Rod
    Michigan
    Black with naked top. Thought I ordered black top but did not. Even still I like it quite a bit, perhaps even better.
  2. Apr 26, 2020 at 9:08 AM
    #3842
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    That’s a good look and helps with the heat as well versus black top.
  3. Apr 26, 2020 at 3:48 PM
    #3843
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I think ours might be in the same batch, I was scheduled for install a few days before yours. I was hearing the same regarding powder coat and installs.
  4. Apr 26, 2020 at 9:15 PM
    #3844
    eleland
    eleland Active Member
    Eric
    2019 Tacoma Base v6 4x4 Double Cab
    I haven't heard any status for weeks. Is Vagabond Outdoors still in business? I assume they are at least shut down for covid, but I don't know as there has been zero communication. Does anyone know what the last order number was that was completed?
  5. Apr 26, 2020 at 10:14 PM
    #3845
    SliMbo4.0
    Rick
    They've been shut down/on stay-at-home orders like many businesses that were unfortunately deemed non essential. (I'd argue that my mental health needs them open so I get the hell out of town for a while.)
    Not sure the number that was last completed but somewhere around 110-ish. You won't really hear from them til they start prepping for your build. Unless you have questions, then email or call.
    parttimedirtbag and tyfoon11 like this.
  6. Apr 26, 2020 at 10:25 PM
    #3846
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
  7. Apr 27, 2020 at 8:11 AM
    #3847
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    My experience is that Phil will call you back if you have a legitimate question other than "when will my Drifter be ready?" I understand people need to plan ahead, but there's no accurate answer to that right now.
  8. Apr 27, 2020 at 9:06 AM
    #3848
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    We can't forget that before VO, Phil was just one of us - a TW member. He gave up his career and started doing VO full time. So if anyone is frustrated that VO isn't operating at full capacity it's him because it's his livelihood.
  9. Apr 27, 2020 at 7:08 PM
    #3849
    zhellman
    zhellman Well-Known Member
    Zack
    Thanks for the measurements! What are you using to mount your cabinets to the rails?
  10. Apr 28, 2020 at 7:13 AM
    #3850
    Trdooper
    Trdooper Well-Known Member
    Tom
    Oakley Ca
    2017 Tacoma TRD OR DCLB
    For all those building conspiracy calenders based on build numbers, add this to your excel spreadsheets: I'm order #150 - order date july 14th 2019. 6 foot bed with no powder coat (not sure if they batch them differently based on build options). I have not gotten a call regarding finalizing my build so they are not to that batch yet. If you have met the VO guys you know they are doing everything they can to push these out.
    Debating starting the build out prior to getting the drifter; my concern is having to retro-fit around the mounting clamps with the bench top. Anyone build a bench prior to delivery? Tips/tricks?
    parttimedirtbag and Anderson like this.
  11. Apr 28, 2020 at 7:28 AM
    #3851
    zhellman
    Zack
    I'm 156 and ordered July 24th, looks like they were getting a lot of orders in the Summer. 6 in just 10 days is impressive
    parttimedirtbag, Shaggs and tyfoon11 like this.
  12. Apr 28, 2020 at 7:41 AM
    #3852
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The clamps are adjustable on where you position them front to rear. If you just leave a gap for them you should be fine. What kind of measurements do you need? The dimensions are on GCI's website, I am pretty confident that the clamp used for 2nd & 3rd gen Tacomas is the G-133. http://gciclamps.com/products/toyota/
    splashflash likes this.
  13. Apr 28, 2020 at 8:23 AM
    #3853
    MattySee
    MattySee New Member
    Can anyone comment as to whether the moonroof on a 2020, 5 foot bed, double cab off road would be rendered useless/covered by the Drifter?
  14. Apr 28, 2020 at 9:05 AM
    #3854
    mhshark
    mhshark Well-Known Member
    Bend, Or
    The drifter will cover about half of it, maybe a little more
    Anderson and MattySee[QUOTED] like this.
  15. Apr 28, 2020 at 9:07 AM
    #3855
    mhshark
    Bend, Or
    I’ll cross post this into the build thread but - has anyone wired a connector to plug a drifter into a goal zero for power? I’m a 12/24v noob so trying to figure out if this is possible. Would be a 1000 model.
    parttimedirtbag likes this.
  16. Apr 28, 2020 at 9:09 AM
    #3856
    snwbrdr852
    snwbrdr852 Well-Known Member
    Utah
    '17 DCSB OR V6 AT 4WD
    It covers about 60% of it, but there's a few inches clearance, so it's not completely useless.
    I don't use the tilt up function anymore while moving, but opening it is still nice until you get to maybe 35 or 40mph, where the air hitting the front of the Drifter is kind of being blasted down at you.
    MattySee[QUOTED] likes this.
  17. Apr 28, 2020 at 9:15 AM
    #3857
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Im going to tie my drifter electrics into a secondary battery inside the drifter so I dont see why you couldnt tie it into a goal zero. Just make sure its sized properly, Im planning on using a 40A breaker for the fan, lights, 12V outlet.
  18. Apr 28, 2020 at 9:51 AM
    #3858
    mhshark
    Bend, Or
    Thanks man. I’m more curious if people wired the drifter to an Anderson connector to fit the goal zero or did something else
  19. Apr 28, 2020 at 12:31 PM
    #3859
    JasonLee
    15 TRD OffRoad
    For those losing their mind waiting... I would entertain trading my short-bed, Tacoma Drifter for a spot in line for a Nomad plus cash... I'm starting to consider picking up a 1st gen Tundra for that sweet V8 rather than dump a ton of money into my 1st gen with a supercharger and other stuff. I'm not using it as I'm sheltering-in-place / working from home and when I'm not working, I'm trying to get a new job.
  20. Apr 28, 2020 at 3:19 PM
    #3860
    RangeRick
    Rick
    I'm #157 ordered July 30th. Let's hope production speeds up once things open back up. I'm sure it will.
    Bentrodder likes this.
Thread Status:
