The Drifter - Specs and FAQ
Discussion in 'Tonneau Covers, Caps and Shells' started by Iggy, Mar 26, 2018.
Thread Status:
Not open for further replies.
  1. Jul 15, 2020 at 10:23 PM
    #4141
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Fixed that for you...
    JasonLee, Eazy.E, Loco_Barbon and 2 others like this.
  2. Jul 16, 2020 at 6:00 AM
    #4142
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Yeah they look great going down the road with the door/entire side missing because someone used a razor blade to brake into it, or it just fell off because the hinges are garbage. And what a great idea to have the whole side open up but then build the cage that compleatly block you from being able to get anything in or out of the bed from the side.
  3. Jul 16, 2020 at 8:24 AM
    #4143
    Asphaltcowboychip
    Asphaltcowboychip Well-Known Member
    @moisesonsurez
    2017 Tacoma +3.5 LT
    A lil this a lil that.
    Digging the Vagabond decal color !
  4. Jul 16, 2020 at 8:25 AM
    #4144
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Frontrunner specs their door at 35lbs, crazy to think the regular glass windoors save that much weight. Wonder if the solid panel option is lighter than the glass.
    Powder coat probably adds several pounds when you consider the surface area.
  5. Jul 16, 2020 at 8:53 AM
    #4145
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    GFC is a rust bucket! Would never recommend one of those.
    I have a friend that just delivered his GFC to them for a 'refresh' that includes powdercoat, new hinges, seals, etc. GFC needs to spend less time on IG and get their sh***t together.
    JasonLee, Holloman, MJonaGS32 and 8 others like this.
  6. Jul 16, 2020 at 10:11 AM
    #4146
    Loco_Barbon
    Hugh Mungus
    i LiKe tRuCkS!!
    Hahaha, you mean a new piece of cloth that holds the whole thing together??
  7. Jul 16, 2020 at 8:08 PM
    #4147
    snwbrdr852
    snwbrdr852 Well-Known Member
    Utah
    '17 DCSB OR V6 AT 4WD
    Hmmm, yeah something doesn't add up if they're only 35 lbs each... Weird.
  8. Jul 16, 2020 at 8:24 PM
    #4148
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    No offense taken, just wanted to know what your reasoning was. GFC side flaps are an interesting idea, but turn out to be impractical. Someone said they leak but not sure about that. And like I said tent windows are in the wrong place, struts are outside and exposed. But yeah the extruded aluminum wedge top sides are cooler than the Drifter, and it takes a cool photo with the flaps open as long as the camera focus isn't sharp enough to see all the bugs.
    Just yankin' yer chain. It's an interesting design. Weighs 100 lbs. less than the Drifter, which counts. To each his own.
  9. Jul 16, 2020 at 9:43 PM
    #4149
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    there’s a laundry list of known issues, most documented on this forum. Got to the point of them abandoning this forum to start their own so they can control the narrative. End of the day you’d be the buyer. Research is on you. Let’s not go down that tangent and derail this thread, again. Free market ftw
  10. Jul 16, 2020 at 11:01 PM
    #4150
    Powered Parachute
    Powered Parachute Well-Known Member
    Olympic Peninsula Washington State
    2014 V6 4L Manual DCSB TRD Sport
    Fab Fours rear bumper. Bestop. Uni Filter Clamp-On Breather. Scratched up and dinged mod.
    I prefer the Vagabond but the rest of the family likes the GFC. Too bad the hospital hinges don't hold up. I wondered about that when the little dude with beard in the installation video said use two hands and don't put pressure on any one side when opening/closing. I am currently leaning to a Hiker Trailer Deluxe. I know you guys probably don't care since this is a vagabond thread. I apologise.
    mac_2_nite, Holloman and tacomgee like this.
  11. Jul 16, 2020 at 11:02 PM
    #4151
    Powered Parachute
    Not hospital but cheap hinges. F this forum keyboard format.
  12. Jul 16, 2020 at 11:11 PM
    #4152
    fdatx2
    fdatx2 Active Member
    Michele
    This is a thread specifically about the Vagabond Campers and questions. Since you still seem to be trying to make up your mind, there are other threads about the various wedge campers and comparisons on this forum.
    Here’s one with links to each manufacturer:
    https://www.tacomaworld.com/threads/wedge-campers-assorted-oddities.538935/
    Everyone here likes to answer questions about the Vagabond but you don’t seem like you have your mind made up so maybe ask questions about all the campers and compare.
  13. Jul 17, 2020 at 8:55 AM
    #4153
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    I want one of theses so BAD!!
    Eazy.E and tyfoon11 like this.
  14. Jul 17, 2020 at 10:51 AM
    #4154
    Loco_Barbon
    Hugh Mungus
    i LiKe tRuCkS!!
    The sooner you order the sooner it arrives. :spending:
    tacomgee, Eazy.E, tyfoon11 and 3 others like this.
  15. Jul 17, 2020 at 11:15 AM
    #4155
    Trdooper
    Trdooper Well-Known Member
    Tom
    Oakley Ca
    2017 Tacoma TRD OR DCLB
    If I order the insulation package but not the powder coat option, what color are the interior walls. I assume white? What material are the walls made of with the insulation package?
    Eazy.E likes this.
  16. Jul 17, 2020 at 11:29 AM
    #4156
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Not sure what it is made of but I believe they are white even with powder coat options... powder coat is exterior
    Trdooper[QUOTED] likes this.
  17. Jul 17, 2020 at 1:34 PM
    #4157
    RangeRick
    Rick
  18. Jul 17, 2020 at 2:51 PM
    #4158
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
  19. Jul 17, 2020 at 3:01 PM
    #4159
    RangeRick
    Rick
    There are three hinges in the front. The person I was quoting (who admittedly sounds like he's trolling the forum to tweak Vagabonders) said something about weak hinges. I'm wondering 1) if anyone thinks this is true, 2) do we indeed have to take care to open up from the center, not putting too much pressure on either side, to reduce strain on these three hinges, and 3) does anyone think a continuous hinge would work better?
    I assume the answer is no. Generally lighter-duty hinges, not to mention more bolt holes. I was just wondering what you guys thought.
  20. Jul 17, 2020 at 3:04 PM
    #4160
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Have there been any complaints or issues with the hinges VO uses? I've not heard of any.
    Must be trolling.
    Anderson likes this.
Thread Status:
