The Drifter - Specs and FAQ
Discussion in 'Tonneau Covers, Caps and Shells' started by Iggy, Mar 26, 2018.
Thread Status:
Not open for further replies.
  1. Sep 28, 2020 at 4:03 AM
    #4461
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    Here are some quick ones I snapped at work. Not really dark out with the parking lot lights but it gives you an idea about the interior light coverage. All my bed power is coming from a single AGM battery in stock location.
    *Edit: the bed power plugs I have were from Off-Grid Engineering. (contains volt meter, 2 dual USB ports, cigarette style plug and one other kind that I can't remember the name of(usually what folks change the cigarette style to since it is a more secure plug. I'm sure someone will know the name of it.)
    Short LED near 3rd brake light(see reflection on front wall)
    Full length side LED
    Ceiling LED
    All are dual color and dimmable (white/amber)
    tyfoon11 likes this.
  2. Sep 28, 2020 at 6:00 AM
    #4462
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    Yes. A long bed drifter on a 2nd gen will fit on a 3rd gen long bed but you will need to change the lower rear hatch seal to seal correctly. I am sure the VO boys could help you with that.
    socalexpeditions and tyfoon11 like this.
  3. Sep 28, 2020 at 7:38 AM
    #4463
    mhshark
    mhshark Well-Known Member
    Bend, Or
    I have a Yeti on my rear seat platform that lowers my fridge. I also ran the drifter’s power into the cab and plug into that. It’s nice to have the outlets in the drifter so that we can charge things up while sleeping but ultimately the power is coming from the yeti
    Hopefully this makes sense?
    mcb-2018-trdsport likes this.
  4. Sep 28, 2020 at 9:08 AM
    #4464
    georginclay04
    georginclay04 Well-Known Member
    Rob
    Denver, CO
    Future 2020 Tacoma TRD
    Thank's Slimbo for the photos! That is all stock lighting if you get both lighting options? It seems like you really wouldn't need much additional lighting to move about the drifter if it is all sealed up? I'm just trying to avoid having to wear a headlamp inside. If I would still need to use a headlamp to shuffle though bins (I'll be living out of bins the first year of ownership until I figure out the layout) I'll consider other lighting options.
    Looks like if you have all the lights on, on the LED it would be plenty bright though and no headlamp would be necessary. Is that correct?
    Thanks again for the photos.
  5. Sep 28, 2020 at 9:14 AM
    #4465
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2017 Ford Transit by Axis Vehicle Outfitters
    There's definitely enough lighting inside to not need a headlamp, even if you don't order any lightning package. The one rear hatch light that comes stock is plenty, any others would just be an additional improvement.
    georginclay04[QUOTED] likes this.
  6. Sep 28, 2020 at 9:16 AM
    #4466
    georginclay04
    Rob
    Denver, CO
    Yes, does anyone have a photo of what this set up looks like? Sounds like it runs off the truck battery. If, the power outlets are easily accessible near the rear door that's one thing. If they are tucked in the back that would be no different than using my Yeti. Thank's for help.
    Looking forward to getting this drifter (Order 140 still no word) so I an begin contributing to some answers!
  7. Sep 28, 2020 at 2:04 PM
    #4467
    Eze1139
    Eze1139 Well-Known Member
    Eric
    Reno NV
    2020 Cement TRD OR DCLB
    I hope you're right on the delivery date but am not getting my hopes up. I have accepted the early January time frame for my delivery, if not later.
    #152 & no call or email on specifics or final payment.
  8. Sep 28, 2020 at 2:24 PM
    #4468
    RangeRick
    RangeRick Well-Known Member
    Rick
    1996 Tacoma Standard Cab SX (Early TRD Off Road, manual 5 speed, V6, factory locking diff)
    Yes I’m jealous of 159 getting a phone call. All the good phone calls are taken.
    parttimedirtbag and smelly621 like this.
  9. Sep 28, 2020 at 10:01 PM
    #4469
    climbnow_worklater
    climbnow_worklater Well-Known Member
    Sean
    2019 Tacoma DCLB
    F: ADS 2.5" extended travel #700, Camburg UCAs, DuroBumps, CMC, TC Alignment Tabs R: ADS 2.5" extended travel, Deaver U402 Stage II, BAMF Hammer Hangers, Timbrem U-bolt flip and Bumpstops, extended brake lines, extended diff breather Armor: Full RCI Aluminum Skids minus Fuel, (rerouted exhaust cross-over), RCI Rear Bumper, Victory Offroad Aluminum Strike Bumper, RCI Sliders Recovery: Smittybilt X20 10k winch (synthetic line, Factor 55 1" Fairlead and Flatlink Splicer) Wheels: 255/85R16, AlphaEquipt Command 16x8 +0, .75" BORA Spacers Misc: AlphaEquipt Snorkel, TRP Low Profile Sharkfin, Vagabond Drifter 159 (someday)
    I called and happened to catch him!
  10. Sep 28, 2020 at 10:32 PM
    #4470
    SliMbo4.0
    Rick
    Yes, my interior lighting are all Vagabond options(upper & lower). Like @SenatorBlutarsky said, the standard light(pic#1 & 4) is plenty for ambient light inside and not need a headlamp. If I could do it again I would have asked them to leave the small one off and just went with the side ones(Vagabond lower lighting option). For me I just use those more often and they might give a little more useable light for digging through bins since they run the length. The standard light also gets in the way of the bug net that I bought through Vagabond that's from another vendor(Strawfoot, I think). At the time I got it, they had not installed one yet so I'm just going to try and work on modifying the net over the winter.
  11. Sep 30, 2020 at 8:23 AM
    #4471
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
  12. Sep 30, 2020 at 8:32 AM
    #4472
    RangeRick
    Rick
    No. Hmmm. I know this can occur due to a variety of reasons, from crash or power failure at the hosting company to problems with Mr. Internet himself. Few months back I alerted Phil to his expired cert. They're busy don't you know. We'll see...
  13. Sep 30, 2020 at 9:22 AM
    #4473
    parttimedirtbag
    parttimedirtbag The Next Frontier
    Kathy
    Southern Utah
    2014 VK56 swapped Nissan Frontier Pro-4x
    ARB aluminum front bumper VK56 swapped engine BFG K02s 265/75/16 Topo Topper Mesa camper
    Really wishing I had placed my order earlier last year now. We're about to be kicked on our asses out of our house at the end of the month and I could comfortably work and live out of the Drifter even for a little while with my new job. Hopefully we can figure out a good next step and maybe we'll move into the truck once we have the Drifter sometime next Spring (order 201, 1/6/19).
  14. Sep 30, 2020 at 10:18 AM
    #4474
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    anomalyTRD likes this.
  15. Sep 30, 2020 at 4:49 PM
    #4475
    georginclay04
    Rob
    Denver, CO
    Hey All,
    I know I've flooded the forum but... I received my final invoice today and boy it was a doosy! I'm sure it'll be worth it but... :eek::eek: Looking forward to focusing back on this project and I'll keep you all updated on the building process. My invoice was #140 and it is expected to be ready in November - Just in time to spend a few weeks living out of the tent climbing in Yosemite (if it's open) and then get the drifter for some luxury Cali and desert travel. I don't think I will miss the dirtbag tent life.
    I originally paid for a bear bones deposit and then today someone reached out to me with the list of my add on's I requested in a prior email. They never responded to that email but obviously they received it. AKA if you send emails they seem to be reading them just not responding until it actually matters. Thinking back on it, I sent soo many detailed emails to Phil early on essentially asking questions on designing the rig. He was probably spending a lot of time responding to those it finally wasn't worth it and now they just respond when it's time for the build out? It is all an assumption there.
    Hope this helps with anyone waiting wondering if they need to send an update email on their new design ideas.
    Also thank you for the help, I did add the charging option and the lighting. Off to the store to buy some Ramen for the next month.
  16. Oct 1, 2020 at 1:19 AM
    #4476
    805REC
    805REC Well-Known Member
    Tristen
    Fairbanks, AK
    Black 2017 TRDOR
    2.5 Kings with RR all around, Total Chaos UCAs, spindle/camtab gussets, Allpro Expo pack with ubolt flip and timbren bumps, SSO slimline bumper with X20 winch, Snugtop camper with prinsu cabrack and toprack, all sitting on 35" Duratracs and Raceline Matte bronze wheels. Numerous interior mods as well.
    Been watching these comments in the background for a greater part of a year now, i know that Vagabond is going through a shortage on aluminum. Is there any word from them regarding when that will be resolved? im not keen on waiting over a year for mine due to life and am thinking about selling my slot or refunding to get a Campking outback.
  17. Oct 2, 2020 at 10:08 AM
    #4477
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I was talking with @SliMbo4.0 last night and we got to talking about the clamps on the 2nd gen and how the front-most one interfered with the front bed reinforcements on the market.
    I then realized that with the insulation package and no side access (windoors, hatches, FrontRunner, etc) on my Drifter, the front-most clamp actually can't go that far forward before hitting the insulation panel where it curves toward the vertical cover.
    I have the GCI G-133 clamps (and I think that's the standard issue for 2nd and 3rd gen owners) and wondering if anyone has found another quality clamp that has a little less reach to clamp down further forward with the insulation package
  18. Oct 2, 2020 at 12:45 PM
    #4478
    venisontaco
    venisontaco Well-Known Member
    Question - Is it really necessary to replace the shark fin antenna with the low profile one to fit the drifter or will the stock one work?
  19. Oct 2, 2020 at 12:53 PM
    #4479
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    What gen do you have? If you have a second gen and are still rocking the plastic bedside rails, then it is not “necessary” to replace your shark fin. If you have metal bed rails, then I would say yes, it’s necessary. If you have a 3rd gen, it is not necessary.
    But, they are aesthetically pleasing to the eye!
    :D
    RCRcer and d.shaw like this.
  20. Oct 2, 2020 at 1:11 PM
    #4480
    venisontaco
    @Anderson I have the 2nd gen and I just replaced the bed caps with the Relentless metal ones this week. 20200927_124756.jpg
    Anderson likes this.
Thread Status:
