The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Feb 20, 2014 at 12:07 PM
    #6261
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    My 8.4'' diff fits a T100/tundra axle so switch axle won't make a difference on my diff. I just swap my regeared diff over with the locker too.
    And i am hoping to boost or get more power to handle highway stuff better and go fast as well. But 33s was bad enough with my rig. I have to be in 3rd most the time going up hills if i want to maintain hwy speeds. Mostly not just due to the tires, but also the roof rack and just weight in general. Thats where i think ill benefit a lot from regearing.
    An 4 lo feels fast to me..way fast now for crawling. again, i thought 33s were bad enough..but again, big difference is weight here. You had a bobbed bed and like way less gear when you wheel vs me. I need lower range and mroe power one way or another..
    Crawl box is still in my plans..just not sure i want to do it before regear and a locker...Lot of money...its all a lot of money :frusty:
  2. Feb 20, 2014 at 12:24 PM
    #6262
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    WTF? You mean you're not going with the ford 9" like I suggested??:mad:
    :D
  3. Feb 20, 2014 at 12:25 PM
    #6263
    Blackdawg
    Monte
    Wyoming/St. Louis
    hahaha
    no...
    least...i doubt it. unless i decide to do 100% race truck....
  4. Feb 20, 2014 at 12:27 PM
    #6264
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Becauseracetruck
  5. Feb 20, 2014 at 12:30 PM
    #6265
    Blackdawg
    Monte
    Wyoming/St. Louis
    which i doubt..cause i still enjoy the long trip stuff a lot....unless the double cab ends up the comfort long trip trail rig...then..racetruck.
  6. Feb 20, 2014 at 12:53 PM
    #6266
    BradyT88
    BradyT88 Well-Known Member
    Maybe you can pick up Jason's gusseted Tundra axle when he goes to a linked 9" ;)
    I don't know if he is actually getting rid of it but I think links are going to show up on his rig sometime this year the way he has been talking.
  7. Feb 20, 2014 at 12:54 PM
    #6267
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea who knows..
  8. Feb 21, 2014 at 10:26 AM
    #6268
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    gearing is a whole different bag of worms with a manual. Personally I don't think a regear is necessary with the auto, but in 4lo with a manual I can totally see the need to regear.
  9. Feb 21, 2014 at 1:11 PM
    #6269
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea..a down fall of the manual i suppose. But not a horrible one.
  10. Feb 22, 2014 at 8:07 AM
    #6270
    Box Rocket
    Adam
    Syracuse, Utah
    Just an extra step needed for good control offroad. When I had my FJ40 the stock crawl ratio is not great. Something like 23:1. When I went to 35's on my 40 it was just not slow enough in 4lo and I had no control. Went to 4.88's and it helped but still wasn't great since that got it back in the same range as stock. Then I changed to an SM420 manual transmission with a 7:1 first gear. That jumped my crawl ratio to 82:1 and completely changed the game offroad. First gear was useless on the road and I just started out in 2nd gear which was fine. But man that 7:1 first gear was freakin awesome offroad. I could run entire trails without touching the gas or the brake. Just steer the truck and crawl over everything. When I had my 1993 SAS truck I had a Marlin Ultimate dual case crawler with a crawl ratio of 223:1. That was stupid slow in full 4lo. I could get out of the truck and walk along side of it over obstacles and reach in the window and steer a little when needed.
    Lower gears and/or a crawlbox is just a necessary part of the mod list for a manual transmission truck. I've been there and know the benefits. It hasn't been necessary in either of my Auto trans trucks (Tacoma and my FZJ80). Granted I can't crawl over stuff without ever touching the pedals, but the auto makes it easy to crawl with good control, even with big tires. Lower gears will still help get those big tires moving but aren't as necessary.
    There's really no point in an argument about which is better (auto vs manual) they're just different. Everyone has a preference which is fine, and the truth is that the type of terrain you wheel has a lot to do with which one will work best.
  11. Feb 22, 2014 at 7:01 PM
    #6271
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn!! I want a first gear like that haha
    Then I'd be happy..but I'm thinking a crawlbox and diff gears will be in the works for me. If I can come up with that kinda cash...
    Yea totally agree though. Both re great in their own ways. I like em both. Have no problem wheeling with either.
  12. Feb 22, 2014 at 7:14 PM
    #6272
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    There's a guy on pirate wow mated two sm465s together. You want to talk about gear ratio. Double reverse close to 47ish:1 and that's before the tcase.
  13. Feb 23, 2014 at 8:18 PM
    #6273
    BradyT88
    That would be awesome! My Dad had an old 73 GMC Sierra that had a 6.5:1 1st gear, but that was back when most trucks had the old Granny first gear and Shift knobs read L-1-2-3, instead of 1-2-3-4.
    Check this out. While I had my CV out rebooting it, Konsta pulled out his spare parts and the outer shafts on the 1st and 2nd gen CV's are the same size, but the actual outer joint is bigger. I think the main shaft is the same size as well. The inners are different though. The 2nd gen inner shaft is bigger so a 2nd gen CV won't fit into a 1st gen diff, but if the shafts are the same size you could just put a 1st gen inner on a 2nd gen CV and put it in your diff.
    There are 2 downsides though. Fully compressed and measuring off the back of the spindle, the 1st gen CV measured just under 19.5" and the 2nd gen measured 21.75", but that could mean they will work for a +3.5" kit on a 1st gen.
    The other downside is having the stronger CV's will probably mean you will just start snapping that ADD shaft all the time and that is a pain in the ass to swap... I helped Konsta when he broke his.
    But! If you get you hands on a 2nd gen diff, you might be able to run a +3.5" 1st gen LT kit on a 2nd gen diff using OEM 2nd gen CV axles. That would make finding spares cheap and easy! Hell Napa sells reman'd ones for about $80 with a core.
    2nd gen CV, 1st gen Spindle
    The shaft is a tad short since the shaft is a bit fatter right at the front, but Konsta said it looks just like his does with the spacers he has to run on his CV's for his drop bracket lift. Just put the red loctite on there and it should be fine. Konsta's have been.
  14. Feb 23, 2014 at 8:24 PM
    #6274
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea but also remember when we measured how wide the diff was with the axle tube and such it was like..1.5'' wider per side or something..so id need what..4.5'' wide kit?? and it would be the same travel as a 3.5'' due to the CVs limiting it..i think...right?
    I just remember the diff is wider. Otherwise id be down to try and swap one in..Be nice to not worry as much about breaking a diff on 35s.
    Tundra CVs hold up to 35s just fine though.
  15. Feb 23, 2014 at 10:33 PM
    #6275
    BradyT88
    I couldn't remember what we measured the diffs at, but I imagined they had to be pretty close to the same. A 2nd gen WMS to WMS is 4" wider than a 2nd gen, so 2" per side and the 2nd gen CV's are 2.25" wider when fully compressed. We should have stretched them out and measured to see how much difference there was there I guess.
  16. Feb 23, 2014 at 10:35 PM
    #6276
    Blackdawg
    Monte
    Wyoming/St. Louis
    http://www.tacomaworld.com/forum/2n...d-gens-who-have-removed-their-front-diff.html
    1.5'' wider per side not counting the CVs..
  17. Feb 23, 2014 at 10:45 PM
    #6277
    BradyT88
  18. Feb 23, 2014 at 10:49 PM
    #6278
    Blackdawg
    Monte
    Wyoming/St. Louis
    nope i asked about it and made a thread in the 2nd gen section when i was really thinkin about it..haha
    amazgingly took me no time to find..haha
    but yea. I still would consider this..be nice to have a stronger diff up front..
  19. Feb 23, 2014 at 10:53 PM
    #6279
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    you and monte were the thread. how did you forget that
  20. Feb 23, 2014 at 11:02 PM
    #6280
    BradyT88
    I remembered the conversation, just not the numbers. haha Besides we talk so much in this thread and the ID BS thread that I don't remember what was said where after like a week. haha
