The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Oct 11, 2015 at 11:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Strange..yea Id replace the switch
  2. Oct 12, 2015 at 12:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think I'll try to find one of these toggle boots locally first. The switch may be fine as long as it is dry.
  3. Oct 12, 2015 at 1:42 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Hehe, a switch condom :p
    45acp, dakotasyota and Blackdawg[OP] like this.
  4. Oct 12, 2015 at 1:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    Thats the technical term and everything :p
  5. Oct 12, 2015 at 1:44 PM
    SconnieHailer
    Marc
  6. Oct 12, 2015 at 3:25 PM
    G.T.
    G.T.
    CONUS
    Have you considered using a "vandal proof switch?"
  7. Oct 12, 2015 at 7:18 PM
    Minnetacoma
    Minnetacoma Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    Nice to see your only on page 227 now lol... How long have you had the fiberglass front fenders?... How you like yours? Finally getting my sr5 back together
  8. Oct 12, 2015 at 8:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    227? haha more like 567..
    Ive had mine glass fenders since july 2012. They are good. They have seen better days now. Lots of spider webs on mine. Could use a new layer of glass on them to keep they from shattering. They are fiberwerx and i have been happy with them.
  9. Oct 12, 2015 at 8:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Is that so @m3bassman can't use it? :rolleyes:
  10. Oct 12, 2015 at 8:30 PM
    Minnetacoma
    Elliott
    Minnesota
    Well on tapatalk it's page 227 lol anyways I was thinking of linex on the inside of the fenders to prevent the spider effect... Mine are also fiberwerx... But I've been trying to get advice on how people have created inner fender wells but not much luck lol... I still plan on doing linex on the inside of my fenders even if I can figure out a way to create a custom inner fender well
  11. Oct 12, 2015 at 8:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well if you don't end up cutting them up like i did. You can make liners very easy. Id suggest some 1/4'' rubber mud flaps or similar. Then just attach them to the body of the truck in a way that the outer edge lays on the lip of the fiberwerx fenders. That way when the wheels come up they just get pushed out of the way by the tire as they are only really attached to the body but come down and rest on the lip.
    You could also just buy a sheet or two of abs 1/16'' or maybe slightly thicker and use a hair dry or heat gun to shape some.
  12. Oct 13, 2015 at 8:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
  13. Oct 13, 2015 at 9:04 PM
    SconnieHailer
    Marc
  14. Oct 13, 2015 at 9:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was just reading that in your build thread.
    It seems like I recall a 1st genner cautioning about going to solid mounts. Not because of the added vibes. That's to be expected. Naw, it had something to do with how high (or not) the engine sat afterward. Something about the radiator fan hitting the lower portion of the shroud.
    Does any of this sound familiar Monte?
  15. Oct 13, 2015 at 9:20 PM
    SconnieHailer
    Marc
    Yea theres bound to be some tweaking to get it all just right. He thought the motor would sit about 1/16-1/8" higher based on other 2nd gens he's put em on.
  16. Oct 13, 2015 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know my bomb proof TG mounts raised mine up. A lot.
    But I haven't had fan shroud issues. I can see it being an issue.
    Id like to get some of those mounts eventually. Before I fuck up my current ones. That and gusset the perches.
  17. Oct 15, 2015 at 7:20 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  18. Oct 15, 2015 at 7:23 AM
    G.T.
    G.T.
    CONUS
  19. Oct 15, 2015 at 7:43 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    if he had his lights on, there wouldn't be a photo, just sun glare
  20. Oct 15, 2015 at 8:09 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    how many motor mounts are there?
