The FREE Blinker Light Relocation Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Nov 3, 2011.
  1. Feb 3, 2013 at 3:09 PM
    #201
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    looks great man!
  2. Feb 3, 2013 at 3:22 PM
    #202
    03tacoman
    03tacoman Well-Known Member
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    can't wait to test fit in the morning :D
  3. Feb 9, 2013 at 6:39 PM
    #203
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    I bought an extra set of colour matched Black Sand Pearl housings to do this. Does anyone have experience wiring in a dual filament socket? Mines an 01 and I'd rather just have one bulb and enlarge the factory hole for a dual filament socket. My only problem is finding a decent sized socket, one the same size as the factory signal socket.
    My factory signal got crushed by a snow drift, I tossed them before realizing I should just relocate the socket, or else I would do it this way too.
  4. Feb 13, 2013 at 4:32 PM
    #204
    RoyalThunder
    RoyalThunder Know Hope
    Orange County CA
    03 PreRunner V6
    With what kind of glue can i glue the mounting area to the light?
  5. Feb 13, 2013 at 4:34 PM
    #205
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'd use some sort of heavy duty epoxy personally.
  6. Feb 13, 2013 at 5:16 PM
    #206
    RoyalThunder
    Orange County CA
    03 PreRunner V6
    Any recommendations?
  7. Feb 13, 2013 at 5:20 PM
    #207
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm side JB weld would work.
    I can't remember what stuff I use..
  8. Feb 14, 2013 at 1:56 PM
    #208
    RoyalThunder
    Orange County CA
    03 PreRunner V6
    The pictures and video for 00-04 is missing on the OP where can i see those pictures?
  9. Feb 14, 2013 at 2:02 PM
    #209
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cody's post is empty but there are still pics of 01-04s right above it...
  10. Feb 14, 2013 at 3:05 PM
    #210
    RoyalThunder
    Orange County CA
    03 PreRunner V6
    Oh okay i see yeah those pictures will do i will be attempting this right now
  11. Feb 23, 2013 at 6:39 PM
    #211
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
  12. Feb 23, 2013 at 6:43 PM
    #212
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool man!
  13. Mar 13, 2013 at 6:13 PM
    #213
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    In regards to the original corner light, did you just plug that back into it's hole? So there would be 2 lights (corner & parking) in that corner light assembly...?
    I'm no good with wiring but I am fancy with a drill bit and dremel :D so I'm excited to get this done on my 99'
  14. Mar 13, 2013 at 6:54 PM
    #214
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. Two bulbs in the housing. Your just adding the blinker bulb. The marker stays there. Just plug it back in when your done.
  15. May 18, 2013 at 11:22 PM
    #215
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    Did this today. Totally worth it
  16. May 18, 2013 at 11:24 PM
    #216
    Blackdawg
    Monte
    Wyoming/St. Louis
  17. May 18, 2013 at 11:27 PM
    #217
    Razgriz
    San Jose, CA
    2013 White TRD 4x4
    On a side note, JB weld works. Its what i used.
  18. May 18, 2013 at 11:28 PM
    #218
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea for you on the 01-04 blinkers I bet it works to hold the mount on.
  19. Jun 19, 2013 at 11:51 PM
    #219
    yote
    Mark
    Tacoma, WA
    A WORD TO THE WISE:
    If you have a 98-00 and are doing this, I'd seriously consider getting LED bulbs for the turn signals. The incandescent bulbs give off a much higher temperature than LEDs would (twice as much).
    I say this because I left my hazards on for about 5-10 minutes to see the difference between this mod and the OEM way Toyota set em up. When I turned the hazards off I noticed a very very small spot on the corner light housing that was starting to get burned through due to the heat from the constantly flashing turn signals.
    It does not matter if you are just using the turn signals for switching lanes, stop lights, etc. but in the off chance that you are a space cadet that day or are testing your Tacos limits and run out of gas or break down and have to keep your flashers on for 30+ minutes then you better believe that you may have to end up replacing those OEM housings as well.
    My 2¢.
    Other than that, GREAT MOD!!!!!!!
  20. Jun 20, 2013 at 12:00 AM
    #220
    Blackdawg
    Monte
    Wyoming/St. Louis
    Interesting! Thanks for the info.
    Did you mount the bulb the way I did?? Just curious. It makes sense tho if you did it my way for the 98-00. The bulb does get close.
    LEDs are brighter anyways :p
