The Getaway...Crom's build and adventures
Discussion in '2nd Gen. Builds (2005-2015)' started by Crom, Feb 11, 2015.
  1. Jan 23, 2017 at 9:27 PM
    #3401
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Actually I tried. But it wasn't enough. In fact it used to be much worse. lol If I ever have a good reason to pull the coilovers I'll try again.
    I like camber close to zero and I like Caster above 2 degrees closer to 3 if possible and just a little bit of toe in. I also like it when the technician makes both sides match. Depending on who does my alignment sometime they listen and sometimes they don't. They're under contract, and if it's in the green they don't have to make any adjustments at all. But I'll bring them treats pizzas bagels and tip them and then they listen to me hahaha
    You need a spacer to stop hitting the top of the wheel well on your Bump Stop and probably chop the cab mount back
    Soul Surfer and ChadsPride like this.
  2. Jan 23, 2017 at 10:53 PM
    #3402
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Curious to know what the part number of the ES bushing kit you used - this looks like a nice addition when I go ahead and do my suspension. Just spent the last 2 hours reading the last sections of your thread - amazing wealth of knowledge here. Thank you for taking the time to write all this up!
    Crom[OP], Soul Surfer and ChadsPride like this.
  3. Jan 23, 2017 at 11:19 PM
    #3403
    Crom
    Nick
    San Diego, CA
    Millions
    Welcome. Yeah it got crazy in here! lol. Glad you found it useful!
    I'll post the cores tomorrow.
    The OEM shackle takes the same sized bushing as the leaf eyes. 40mm diameter. This will work.
    http://www.headstrongoffroad.com/store/p125/Poly_Bushing_and_Sleeves_for_Leaf_Pack_-_05__Tacoma.html
    Or this.
    I've bought from both vendors and compared both products side by side. They are both quality.
    I'll be running the headstrong ones but prefer the ones that wheelers sells.
    @GHOST SHIP
    scocar, GHOST SHIP and ChadsPride like this.
  4. Jan 24, 2017 at 3:31 AM
    #3404
    Styx2015
    Styx2015 Well-Known Member
    Paul
    2008 White Tacoma DCSB TRD Off Road
    Back to shocks....haha.
    So I found this information on the Bilstein 5125 that you were talking about @Crom.
    http://www.shockwarehouse.com/site/product.cfm?id=1460957
    This is the part # 33-230375
    17.11" compressed x 28.33" extended
    http://www.shockwarehouse.com/site/product.cfm?id=1582662
    This is the part # 33-230429
    Both are 5125 series shocks, so what is the difference?
    Here: http://www.shockwarehouse.com/site/bilstein_5125.cfm
    Their valve rates are different, as can also be determined by the first two links.
    Part # 33-230375
    Valving: 255/70
    Part # 33-230429
    Valving: 360/80
    The valving corresponds to how "firm" the dampening ability of the shock is.
    See here for explanation: http://www.eshocks.com/bil_ORgd.asp?Manf=All
    If you scroll further down the page to "Determining Which Shocks to Use",
    whether you classify the Tacoma as "full size with IFS" or "mini truck with IFS" it still recommends a 255/70 valve setup on the rear shocks.
    All this in a roundabout way of saying, Crom is right...again. The 33-230375 would be a great fit on the truck!
    The reason I am asking so many questions about your setup specifically is that I have an identical rear setup:
    - full Dakar leaf pack with D29XL ready to install
    - 3* shims to correct angles
    - All pro U-bolt flip with Wheeler's Superbumps
    - Goodridge extended rear brake lines (sold by one of the TW members)
    - ARE CX (not MX) shell
    I will need to measure accurately when I return to the US to be sure of all of this, but as it stands, I am onboard with your idea of going with the 5125 versus the RCD B110.
    While I am away from my truck, I am doing research vicariously through you!
    I will also order the spacers from Wheeler's as well to make sure I have what I need to complete the job and keep my shocks safe.
    Disclaimer: The Wheeler's website lists a Bilstein 5125 rear shock for the 05-11 Tacoma. This is not the correct shock or part number as described in this thread.
    The compression and extension lengths are vastly different. Be sure to do your research!
    As far as the fronts go, I think I will eventually end up with the 6112's with the 700lb coil option, as I have a lot of extra weight on the nose.
    BDub, Crom[OP], HB Taco and 2 others like this.
  5. Jan 24, 2017 at 5:35 AM
    #3405
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    OK - I'll buy that. I need to study materials a little bit more...
    To me, the ideal shackle set up would be a tension shackle, but at least twice as long as the one we have now (with the appropriately lowered mounting point.) A shackle pivoting forward (all the way to the horizontal position) yields a large amount of droop travel.
    I had a setup like that in my Ranger, and got an incredible amount of rear axle travel. Maybe someday...
    ChadsPride likes this.
  6. Jan 24, 2017 at 6:41 AM
    #3406
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    This thread has my brain spinning. Savage status
  7. Jan 24, 2017 at 8:31 AM
    #3407
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    This is great. I see now that Wheelers (and most sites) list the 33-230337 part number for the 5125 rear shock for the 2nd gen Tacoma's. Good on you for finding the 33-230375 part number. wish I new that before I did my suspension. Now I have a new part number when I go and change them out.
    REAR 5125 BILSTEIN
    33-230337
    Collapsed Length: 15 in
    Extended Length: 24.4 in
    Travel: 9.4 in
    REAR 5125 BILSTEIN
    33-230375
    Collapsed Length: 17.11
    Extended Length: 28.33
    Travel: 11.22 in
    and for reference:
    REAR TRD FACTORY SHOCK
    Monotube Shock Absorber
    Series: 4600 Series;
    Collapsed Length: 13.98 in / 355 mm
    Extended Length: 22.94 in / 582.7 mm
    Travel: 8.96 in
    REAR 5100 BILSTEIN
    24-186728
    Collapsed Length: 14.02 in / 356 mm
    Travel: 8.92 in
    REAR 5100 extended BILSTEIN
    F4-BE5-B110-T5
    Collapsed Length: 16.34
    Extended Length: 27.28
    Travel: 10.94 in
    REAR 5160 BILSTEIN
    25-24379 / 25-24539
    Collapsed Length: 14.22 in
    Extended Length: 24.06 in
    Travel: 9.39 in
    OME N182 Nitrocharger
    Internal Design: Twintube
    Collapsed Length: 13.86 in / 352 mm
    Extended Length: 23.94 in / 608 mm
    Travel: 10.08in
  8. Jan 24, 2017 at 12:12 PM
    #3408
    Styx2015
    Paul
    I didn't find the part number. @Crom mentioned it in a post a couple pages ago. But I decided to delve a little deeper into the issue.
    Nice work putting all of this together. Makes it very clear for folks who are shopping for a rear end upgrade. As long as everything is measured properly for correct tolerances, the 5125 (33-230375) will provide the maximum amount of travel (with the Dakar leaf pack).
    DaVikes and ChadsPride like this.
  9. Jan 24, 2017 at 12:27 PM
    #3409
    BDub
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
  10. Jan 24, 2017 at 12:29 PM
    #3410
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I looked a bunch of times at the pics for the 4xinnovations "replacement rear shackles." Don't they look like shackle flips with stock length shackles with bonus greasable bushings?
  11. Jan 24, 2017 at 12:33 PM
    #3411
    scocar
    scocar Patron of the Farts
    I've asked them for several clarifications. Apparently they bought out ATO, and they need to improve on some of these details on their product descriptions.
  12. Jan 24, 2017 at 1:06 PM
    #3412
    Crom
    Nick
    San Diego, CA
    Millions
    Good luck with your work. Welcome. You got a great alignment tech from the sounds of it. I have a guy like that but he is in the neighboring city and haven't been there in almost a year now.
    Roger on all that you wrote. Looks good.
    My only comment would be that the 6112 shock was tuned with a 600 or 610 coil. So changing the spring rate will affect the dampening / vehicle handling. What that will actually look like on your truck? I have no idea, talk to Bilstein on that, or someone well versed in shock tuning.
    Copy that. Sound like quite the project. Maybe not to different from the Chevy 63' leaf spring swap thing. I've been casually gathering details of that to understand it better. From what I've read, it's good for wheeling, but maybe not so good with Expo weight.
    I was able to compare my travel numbers with Frank's @Rattletrap66 in this thread over here wheen he went to 14" travel shocks.
    What I learned was that the Chevy springs will get you about 18" of wheel travel. Compared to Dakar, (with a non-binding shackle), 13.75"
    I'm done building my truck for suspension. Once the modified OEM greaseable shackles go in, that it!
    :goingcrazy:
    I've have other stuff to share, will wait until next week. :)
    Just wanted to clarify, that the F4-BE5-B110-T5 shock is an RCD shock, Race Car Dynamics, not an extended 5100 Bilstein as is often mentioned. Even vendors selling it don't know and label it wrong.
    Good link! Thanks.
    Here is a link to the full off-road catalog I've been using to do my research:
    http://cart.bilsteinus.com/pdfs/off-road.pdf
    Yes.
    Visualize taking the shackle in this picture, unbolt the top bolt, and rotate it about 180* backwards and it should bolt right up to our stock shackle hangers. You can't see the grease fitting because it's on the other side. That pisses me off when I can't see shit I want to see. lol
    I know Scott emailed them and curious to hear the responses he got. His Q's are in his parts shelf, I mean build thread. :D
    :thumbsup:
  13. Jan 24, 2017 at 1:21 PM
    #3413
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  14. Jan 24, 2017 at 2:26 PM
    #3414
    bski22
    Rob
    Toyota
    @uurx our next project. Flipped greasable stock length shackles... see above... my money tree is bare though
  15. Jan 24, 2017 at 3:03 PM
    #3415
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    crom has really done some nice work on this one no doubt... i do think though for me it will be leave it just as is until taking the plunge and doing the Archive fit. I do wanna take on the any time rear view camera and fog light mods though, and i really need to cut out rear sun shades for the cap windows.
    been said before but say it again, thank you Crom for documenting these things for us to use.
  16. Jan 24, 2017 at 3:59 PM
    #3416
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Excellent! So the 337 represents an upgrade if like me your running the stock leaf pack and aal's with 5100's which are stock length. An extra 1.5" extended over stock and 1" longer compressed. With the 3 smaller aal's do you think its okay to run this with the stock bumps as is? Add longer brake lines or modify bracket. Actually I want to do u bolt flip and upgrade the bumps then put overload back in so then it should be fine for sure with 2" lift. I'm not looking to replace the leaf pack at this time but may be interested in this shock since it helps over what I have now. I'll have to do some measurements and have a look. Is the valving the same as 5100's? Id like them to be a little more firm. Hmm Thanks
  17. Jan 25, 2017 at 1:57 AM
    #3417
    Styx2015
    Paul
    Hey, I seem to remember in reading through this entire thread that someone posted about some leaf spring isolators that were like a foam insert to go between the upper leafs of the Dakar pack. I think a link was posted as well. They looked somewhat like what a garage door seal would sit on on the floor.
  18. Jan 25, 2017 at 3:41 AM
    #3418
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    They are on my truck. Could have looked at them last night Floyd
    Crom[OP] and ChadsPride like this.
  19. Jan 25, 2017 at 8:30 AM
    #3419
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    There's a few different "fixes" for this problem. Here's the link where several were discussed:
    https://www.tacomaworld.com/threads/squeaky-dakars-any-advice-from-others-with-the-dakars.156353/
    The method you're referring to are the leaf spring liners. You can buy them from various sources, but here's one from speedway:
    http://www.speedwaymotors.com/Leaf-...gn=CSEGOOGLE&gclid=CJHXz77a3dECFUuSfgodaXEBbg
    I think Nick has come up with and applied the cleanest solution if you haven't installed yet:
    https://www.tacomaworld.com/threads...-and-adventures.362772/page-139#post-13393533
    If there's ever anything you want to reference from this thread, check the first post. Nick has done an amazing job of organizing everything and providing links to the posts with his how-tos and pictures.
    ERMB, samiam, Crom[OP] and 1 other person like this.
  20. Jan 26, 2017 at 12:07 AM
    #3420
    Styx2015
    Paul
    Thanks for the links! I searched through the first page posts, but couldn't find what I was looking for. I think it's because someone other than Crom posted the link.
