The Lair
Discussion in '2nd Gen. Builds (2005-2015)' started by EatSleepTacos, Jun 5, 2017.
  1. Mar 10, 2018 at 5:59 AM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  2. Mar 10, 2018 at 6:05 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    In the description it says they go on the fixed end of the leaf spring. How come u can't put it on both ends? Is it cuz the zerk will interfere with the movement of the shackle or something? I mean as long as u out it facing away from the frame u should be good?
  3. Mar 10, 2018 at 6:14 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    You can purchase 3 kits and put the 3rd kit where the shackle attaches to the mount. I don't see any problem with attaching it at both points on the spring. I think that is them more cya and getting a scape goat if the zerk were to break. Your assessment is spot on!
    Bocsy44[QUOTED] likes this.
  4. Mar 10, 2018 at 6:31 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    sweet. what would the true benefit to this be? don't these bolt pass thru a sleeve? so essentially you would be filling the void with grease keeping dirt out, might prevent the bolt from rusting and prevent the possibility of squeaks? would it really be beneficial with the oem set up or more for is your running poly bushings?
  5. Mar 10, 2018 at 6:57 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    So all it is really designed for is to prevent the bolt from seizing to the sleeve like you said. Yeah it can be beneficial in that manner even on a stock bushing. Now even my poly bushings have solid sleeves so no grease gets to the bushing but on a poly bushing you could drill a hole or two to allow grease to get to the bushing. Do you really need that not really. This is how I treat my poly bushings on install and have never had an issue. I put some moly grease on the outside of them and where the sleeve passes through. I see a benefit in this bolt for not having the possibility of seized bolts. But for every suspension bolt I install I coat the part that passes through a sleeve in antiseize to help prevent that, but eventually that will not be there hence a greasable bolt option. Trailer manufacturers especially boat trailer ones have been using these for a long time since they are constantly being submerged in water.
  6. Mar 10, 2018 at 6:57 AM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Put it together.
    Trump SZN
    BravesRunner likes this.
  7. Mar 10, 2018 at 6:59 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    ban
  8. Mar 10, 2018 at 7:06 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    I'm dealing with bolts being seized inside sleeves right now haha those bolts that go thru sleeves in those arm things that stick up and prevent the leafs from moving side to side (I think that's what they are for) hahaha well the bolts are stuck in the sleeve and I need them out for when I go to install my AAL lol I bought new bolts but I need to salvage the sleeves.
    Justanotherhemi likes this.
  9. Mar 10, 2018 at 8:02 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    2E8CDFD4-DB1E-49B5-BAAC-FD57001CE05C.jpg 6AB72376-C23B-4FBF-BB29-F68927D4F0C7.jpg
    Small morning project.
  10. Mar 10, 2018 at 8:02 AM
    Justanotherhemi
    Rick James
    Warm them up with a torch
    bski22 and Bocsy44[QUOTED] like this.
  11. Mar 10, 2018 at 8:06 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    they aren't mounted anymore, I have them in my living room, I should be able to get away with just soaking them or spraying them with some PB. they aren't like super seized, some of them I can turn kinda hahaha just stuck in the sleeve. worse comes to worse I will have to heat them but I will need a vice or something to hold them. I might actually buy a vice and mount it to the bench in the garage if I can find one for a good price.
  12. Mar 10, 2018 at 8:15 AM
    fatfurious2
    David
    Ashburn, VA
    I want to go to Florida. Can ship my truck there on the train for $200. @EatSleepTacos
  13. Mar 10, 2018 at 8:17 AM
    Justanotherhemi
    Rick James
    May be time to spend the $ on the vice
  14. Mar 10, 2018 at 8:44 AM
    Justanotherhemi
    Rick James
  15. Mar 10, 2018 at 9:13 AM
    EatSleepTacos
    EatSleepTacos [OP] Well-Known Member
    Randy
    West Valley, AZ
    2017 4Runner
  16. Mar 10, 2018 at 9:17 AM
    fatfurious2
    David
    Ashburn, VA
    I love hot weather! I would move to AZ if I could.
  17. Mar 10, 2018 at 9:18 AM
    fatfurious2
    David
    Ashburn, VA
    you dont realize that I dont use AC in my truck in the summer.. The only time I use it, is for defrost. And theres no AC on bikes either..
  18. Mar 10, 2018 at 9:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    HUGE difference between the two. AZ is a dry heat and totally awesome. FL not so much. You sweat all the time.
  19. Mar 10, 2018 at 9:21 AM
    fatfurious2
    David
    Ashburn, VA
    sweating is the way to lose water weight. You can see in the summer when hanging out/driving. Im not driving with the windows up, but you wont see me using AC when Im out
  20. Mar 10, 2018 at 10:41 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
