The Lifting Your 5 Lug Guide
Discussion in '5 Lug' started by Kavik, Nov 6, 2017.
  1. Nov 19, 2019 at 10:22 AM
    #181
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Are you looking for more load capacity? Do you have an aal?
    I wouldn't suggest going that method. It's alot of work. I have 2016 6 lug leafs and a 2008 trd off-road rear end. It was wayyyyyyyy too stiff and tall. I removed the overload spring which made it softer and lowered it an inch but then had to use leaf spring clamps to reduce axle wrap because it's very common with spring over. It rides good now but is no way good for heavy loads lol.
  2. Nov 19, 2019 at 10:29 AM
    #182
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    No, not looking for more load capacity necessarily. Mainly looking for better ride quality, if possible. I have Fox 2.0 shocks which are a major upgrade from stock, but I don't know if they'd work even better paired with a higher quality set of leaf springs.
    Yes, I have an aal as part of my lift.
  3. Nov 19, 2019 at 10:34 AM
    #183
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Do they possibly have deaver's that may work? could be a possibility if you're not looking to go stiffer
  4. Nov 19, 2019 at 10:35 AM
    #184
    Das it mang
    Az
    1996 T100 SR5 MT
    I take back my recommendation then lol
  5. Nov 19, 2019 at 11:56 AM
    #185
    5 Lug Fury
    Kenny
    Knoxville, TN
    You could always do a shackle flip. It'll make the ride alittle softer but will allow more flex. It will also add about an inch in the rear though so keep that in mind if you want to be level.
  6. Nov 19, 2019 at 2:05 PM
    #186
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Yes I have a aal
  7. Dec 5, 2019 at 11:38 AM
    #187
    pwrslide2
    pwrslide2 Well-Known Member
    AZ
    07' 2.7 2wd auto
    In process
    Off the wall question. Can you run the Bilstein 5100 on the rear if you run stock ride height on a 07 base model?
    Was thinking I could run them for a while at stock height and once I find a rear diff setup to raise the truck up and run larger tires, I'd already be ready for the AAL.
  8. Dec 5, 2019 at 12:09 PM
    #188
    Das it mang
    Az
    1996 T100 SR5 MT
    You should be fine, yes. Shocks may be a lil compressed but I've heard they work
  9. Dec 5, 2019 at 12:19 PM
    #189
    5 Lug Fury
    Kenny
    Knoxville, TN
    Check out my suspension thread. It fits but you can bottom out if you're giving it a hot supper.also what diff setup are you talking about?
    https://www.tacomaworld.com/threads/my-lift-progress-with-photos.446409/
  10. Dec 5, 2019 at 1:23 PM
    #190
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    Got it. might not want to run them then. bottoming out shocks is a no no.
    idealy, I'd like to get a 3.73 LSD rear end at some point. trying to also learn what it'd take to get others in there. I'm not married to keeping this truck for a long while so I dunno. not gonna spend top dollar to do stuff. My 98 M3 needs work as well as I'm refreshing many thing on it for track duty.
  11. Dec 5, 2019 at 4:10 PM
    #191
    5 Lug Fury
    Kenny
    Knoxville, TN
    Keep in mind I'm running 2 pairs of wheels because I'm 6 lug rear and 5 lug front. The 3.73 lsd rear end you want as a second gen will be out of any 2nd gen 6 lug trd sport.
  12. Dec 5, 2019 at 4:14 PM
    #192
    Das it mang
    Az
    1996 T100 SR5 MT
    I'll prolly be in the same boat when I do 6 lug rear end with two spares. But, out of curiosity is it possible to do a spacer/adaptor in the front for 6 lug, or vice versa to make rear 5?
  13. Dec 5, 2019 at 4:25 PM
    #193
    pwrslide2
    AZ
    07' 2.7 2wd auto
    In process
    is there no 30 spline 3.73?
  14. Dec 5, 2019 at 6:16 PM
    #194
    5 Lug Fury
    Kenny
    Knoxville, TN
    I ran adapters for a little bit and had to destroy both of them to get them off to do a brake job. They always seize up at some point
  15. Dec 6, 2019 at 6:47 AM
    #195
    Das it mang
    Az
    1996 T100 SR5 MT
    That's the answer I needed to hear, thank you lol. Ill be running 2 spares then lmao. Sorry you had to deal with that
  16. Dec 6, 2019 at 6:53 AM
    #196
    5 Lug Fury
    Kenny
    Knoxville, TN
    It was one of those days where you bring all your destructive tools out. My grinder burned out in the first 5 mins. I think it was the aluminum dust. I'm currently not rotating but also I'm currently dropping a V8 in so converting the front to 6 lug is a battle for another day
    Das it mang[QUOTED] likes this.
  17. Dec 6, 2019 at 7:07 AM
    #197
    Das it mang
    Az
    1996 T100 SR5 MT
    probs hasn't crossed ur mind with the v8 swap but u gonna try and make the 4x4 spindles and stuff work with fabbing? or find a way to make LT kit with 6 lug in the front? really hyped to see ur progress my man
  18. Dec 6, 2019 at 7:41 AM
    #198
    5 Lug Fury
    Kenny
    Knoxville, TN
    Not sure I already have a set of 6 lug hubs. Im either going to modify a stock 6 lug spindle or make a boxed lift spindle.
  19. Jul 8, 2020 at 5:07 PM
    #199
    Gyuto
    Gyuto Member
    98 5lug v6
    Picked up a 98 v6 5 lug with a 3" body lift and a shade under 200k miles. It is my first Taco, Seems like with a little love she will still be up to the task. Needed a ball joint, springs, and a wheel bearing so i figure while im in there...
    Looking in to adding Doetsch spindles, an alcan leaf pack, and some new shocks/springs to put some life back in to her suspension right now. There are what looks like over sized coils in front flexing the arm about as far as it wants to go and leaving me next to zero down travel.
    Couple of questions out of the gate after poking around - Im sure this has been answered but my eyes are bleeding at this point and - help -
    Will the mentioned upgrades offer me some more travel front and back (about how much?), or am I going to have to go further pretty early on?
    I am assuming I can get shackles from alcan in the process of getting the leaf pack [Correct?] and if so, will the mount(s) also then need to be relocated?
    Is it worth Springing for some billstein and new springs after spindles?
  20. Jul 8, 2020 at 6:18 PM
    #200
    Das it mang
    Az
    1996 T100 SR5 MT
    Adding a spindle lift will not increase your suspension travel sadly. It only puts ur wheel 3 inches lower to the ground with the same suspension geometry.(do get lift from it) U might have the doestch lift coil then. Adding a new leaf pack might gain u travel with the lift in the rear, tho. Billies are good but u can get kybs for cheap on Amazon and theyre good too
    Gyuto likes this.
