The Lifting Your 5 Lug Guide
Discussion in '5 Lug' started by Kavik, Nov 6, 2017.
  1. Dec 6, 2017 at 11:43 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Great information and pictures! If you could add what suspension you used in the front and rear, that would also be helpful.
  2. Dec 6, 2017 at 11:48 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    i have the 5lug tacoma 2007 with tc long travel kit with 8" coilover and 550 pound springs on 18" coil
    rear i have icon add leaf with bed cage with 2.5 fox smothbodys and fox 2.0 bump stops with 2.5 inch of travel
  3. Dec 6, 2017 at 11:49 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    all my info on my profile
  4. Dec 6, 2017 at 12:02 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    I was hoping for part#s and such. It makes things easier when people want to go look up specific products on the manufactures page.
  5. Dec 6, 2017 at 12:04 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  6. Dec 8, 2017 at 1:07 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Updated leaf spring options.
  7. Dec 8, 2017 at 1:08 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  8. Dec 8, 2017 at 1:12 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    ICON 1.5″ Lift Rear Expansion Pack Add a Leaf for 1996-2015 Toyota Tacoma
    Description
    ICON 1.5″ Lift Rear Expansion Pack Add a Leaf for 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015 Toyota Tacoma
    Part: 51100
    Overview:
    This 3 Leaf Progressive Add a Leaf Kit comes complete with U-bolts and Center pins for an easy install. This add a leaf kit will give your Tacoma / Tundra 1.5″ of lift after installation. Just remove the factory overload and say good bye to that rough factory ride.
    $214.95 i got mine at offroadwarehouse $150 there Ubolts dont work for are trucks but taking out the big load spring you can use this kit with the stock Ubolts thats what i did.
    Jowles likes this.
  9. Dec 8, 2017 at 1:12 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  10. Dec 8, 2017 at 1:21 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    I was just letting people know I was updating the info on the first page. but that info helps too.
  11. Dec 8, 2017 at 1:23 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Also Updated the 1st gen section of the guide to include products. (see 2nd post on page 1)
  12. Dec 29, 2017 at 7:36 PM
    Jpsyoda
    Jpsyoda Active Member
    Jordan
    California
    02 Tacoma Prerunner
    2016 Tacoma wheels
    I have a question regarding first gen tacoma lift. I have a 98 with 3" fabtech spindles in front and 2" shackles in back. Running 235/75/15 Toyo Open Country AT II tires on 15x7 Jeep Canyon wheels. I use the truck for camping. With a load in back, she squats pretty good. Can I add the AAL in conjunction with the shackle and still have driveline and other components be ok? I know it will have a little rake, but that's ok. Maybe eventually add v6 coils in front. I searched, but didn't have time to read the entire lifted minis thread. Thanks!
  13. Dec 29, 2017 at 9:08 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I know very little about 1st Gens but from what I've seen with 2nd Gens your should be ok with adding an aal. It will increase you load capacity and like you said rake out more. I don't think you would have any issue with driveline either. As for the front I too have heard the v6 coil rumors and never really found any solid evidence. If you haven't changed out your front shocks I'd suggest that first as when I did it to my truck it stiffened out enough.
    Jpsyoda[QUOTED] likes this.
  14. Mar 23, 2018 at 11:30 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
  15. Mar 23, 2018 at 11:41 AM
    #35
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Kinda late but yes you can run shakles and a aal with no problems, i do it.
  16. Apr 3, 2018 at 2:14 PM
    #36
    5 Lug Fury
    Kenny
    Knoxville, TN
    TTT so the thread dosnt get lost
    SamGoingHam, Jpsyoda and Sperrunner like this.
  17. Apr 3, 2018 at 5:28 PM
    #37
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    Can't we ask for a Mod to Stickie this? 5 Lug doesn't have any stickies and this is usually the main reason any 5lugger comes into here and asks.
    5 Lug Fury and HackD like this.
  18. Apr 3, 2018 at 5:47 PM
    #38
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    @tcBob
  19. Apr 5, 2018 at 2:21 PM
    #39
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    That i would make a part number list for 5lug 95-04:
    Stock parts:
    Moog 81070 v6 coils
    Acdelco 45h0356 V6 coils
    Husky spring sc2050 4cyl coils
    Fcs 341513 front shocks
    Monroe 32292 front shocks
    Bilsten 24184991 front shocks
    Lift parts:
    Tco98420 tc billet cross shafts
    69079 doestch lift kit
    Fabfts41307 fabtech lift spindles
    Fabfts200 fabtech aal
    Fts7078 fabtech front shocks
    Fts7163 fabtech rear shocks
    41150-2wd-991 fatbob leveling kit
    Kto9113bk daystar spacer
    Fts2096 fabtech shakles
    Tt9551fekext jdjab LT kit
    Axel stuff:
    https://eastcoastgearsupply.com/i-788575-tacoma-8-4-non-eld-t100-tundra-3rd.html For regearing 8.4 rear end.
    Random parts:
    Novita ep35c (turn signal relay for corner light mod)
    Website:
    http://4x4.fatbobsgarage.com/articles/toyotatacoma5lugyears95.htm
    https://offroadwarehouse.com/i-1165...ross-shafts-96-04-2wd-toyota-tacoma-pair.html
    http://www.doetsch-shocks.com/22.asp
    https://www.rockauto.com/
    https://fabtechmotorsports.com/prod...a/1995-04-5-lug/3-inch-systems-1995-04-5-lug/
    http://daystarweb.com/productdetail.php?productID=543
    If you have any other part numbers for this list tell me and ill edit it in
    1st gen pics and some lift info available in my build thread:
    https://www.tacomaworld.com/threads...d-with-general-1st-gen-5lug-lift-info.536614/
    L1L_TACO and Jpsyoda like this.
  20. Apr 13, 2018 at 10:25 AM
    #40
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    @Kavik after doing some research ive not found any one who has lifted 6lug spings on there truck. And 6lug guys that go sua have to go pretty custom just to achieve stock hight. So i dont think adverting 6lug lift springs as a easy bolt on option for 5lug guy is a good idea. Now those springs combined with a flip kit yeah. But for sua no
