The Lifting Your 5 Lug Guide
Discussion in '5 Lug' started by Kavik, Nov 6, 2017.
  1. Apr 30, 2019 at 7:34 PM
    #161
    vicdeng
    vicdeng Member
    07 Tacoma Reg Cab RWD
    thanks, I also heard that if you lift your taco and go bigger tires, you have to regear. I want to know when we draw the line to regear. Above what size tire you need to regear. thx
  2. Apr 30, 2019 at 8:01 PM
    #162
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Depends on how much you're willing to suffer. It's already geared high(MT is 3.31 and auto is 3.56 or therabouts I think) there's a sticky with a tire size/gear ratio calculator that allows you to input different tires sizes and/or gear ratios. You can get higher final drive ratios but larger wheel/tire combos will be offset by less range so you'll be filling up more frequently. Too high and the pinion gear gets tiny and more prone to failure. Back in a few to post a link to the gear rstio calculator.
  3. Apr 30, 2019 at 8:03 PM
    #163
    bagleboy
    Scott
    Norcal, Santa Rosa
  4. Apr 30, 2019 at 8:33 PM
    #164
    vicdeng
    vicdeng Member
    thanks for the info. I plan to go 29 or 29.5" to be safe. I daily the truck and drives 70mph on the freeway.
    I am debating the fat bob or ready lift, exactly how good is the fat bob shock that comes with the kit? I like the idea of long AAL, but I would prefer the 5100s in the rear rather than the shocks that comes with the fat bob kit. Any thought?
  5. Apr 30, 2019 at 9:11 PM
    #165
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    The fat bobs shocks will work but they're not 5100s also don't forget the 4600s in the front
  6. May 1, 2019 at 10:40 AM
    #166
    vicdeng
    vicdeng Member
    Thanks for the fast reply. yah, i plan to go with Fat bob spacers and long AAL, then 4600s in the front and 5100s in the rear. But if i got that, i will have no use of the shocks that i got from the fat bob kit.
    Just thinking about the most cost effective way to lift the taco
  7. May 1, 2019 at 11:15 AM
    #167
    5 Lug Fury
    Kenny
    Knoxville, TN
    That's why many people do the eBay spacer. I did the eBay spacer with a fat bobs long aal and ubolts. Don't use fat bobs ubolts though mine rusted pretty quick and I'm in South Florida.
  8. May 1, 2019 at 7:14 PM
    #168
    vicdeng
    vicdeng Member
    that's the exact suggestion I need. Thanks a lot for the heads up on the ubolt. Which ebay spacer do you use? any vendor recommend? if you order the fat bobs all, what u bolts did you end up getting? Thanks
  9. Jul 23, 2019 at 2:28 PM
    #169
    07TacoStormTrooper
    07TacoStormTrooper Member
    San Diego
    2007 white tacoma 2wd 2.7L
    3” ebay spacer 31x10.50x15R BFGK02’s
    Hey guys!
    Im doing a 2.75 spacer in the front with 1.75 aal lift in the rear & new front & rear shocks. Looking to throw on some BFG 265/75/16 with procomp 16” series 252 wheels. They are a 16X8 5 on 4.5 bolt pattern with -6 offset & 4.25 backspacing. Will i need a spacer to clear my brake caliber or should i be fine? Has anyone tried to run the procomps? Thanks
  10. Aug 6, 2019 at 7:27 PM
    #170
    Taco Shepherd
    Taco Shepherd Active Member
    Walt
    2009 Tan Tacoma Base Model
    Interior Mods: custom cluster, accent lights, wired stock backup camera to aftermarket radio, dye carpet and trim black Exterior mods: Headlight lenses and bulbs, fog lights, 3rd brake light, tail lights, bull bar, sport bar, restored sun damaged trim, more to come
    Been doing a lot of reading and there's a lot of good info on this thread. That said, before I hit the buy buttons, I want to clarify everything I need before I start.
    2009 5 lug tacoma. The front shocks and coils are brand new so not replacing those. Right now I'm looking at Readylift spacer and AAL. For the rear shocks I'm thinking Bilstein 5100 is what I want.
    Is this all I need to lift the truck? Is what I'm looking at a good choice? Should I get anything else?
    My brother does suspension so I'll be making the 6 hour drive for his help on installation. Is there anything he or I need to know before doing this?
  11. Aug 6, 2019 at 8:10 PM
    #171
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    6 hours is quite a drive for a spacer n aal lift. But hey you get to see your bro
  12. Aug 9, 2019 at 10:12 PM
    #172
    the macf
    the macf Well-Known Member
    Daily Driver - 09 RCLB Barcelona Red base, Sold - 08 BSP X-Runner TRD SC 332rwhp
    Go 30’s or 31’s. I have 29’s on 16’s and wish I had 30’s. Reg cab 2wd stock.
  13. Sep 26, 2019 at 4:23 PM
    #173
    maverick4x2
    maverick4x2 Well-Known Member
    2013 Tacoma 5 lug
    All,
    Looking to price out lifting my rc 5 lug, ebay spacers seem the way to keep cost down in the front if i'm not mistaken. wondering what a good price would look like for aal and bilsteen 4600/5100. seen some wildly different pricing. also why are there like 20 different shocks labeled as 4600's when i look at them online, a smidge confused at that.
  14. Oct 4, 2019 at 6:52 PM
    #174
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
  15. Oct 4, 2019 at 7:48 PM
    #175
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    I'm pretty confident that the 6 lug leafs and the 5 lug leafs are interchangeable.
  16. Oct 15, 2019 at 7:53 AM
    #176
    5 Lug Fury
    Kenny
    Knoxville, TN
    Yes and no. We have spring under leafs which have a large Arch and 6 lugs use spring over which are more flat. You can fit both but the arch really is the killer.
  17. Oct 19, 2019 at 3:24 PM
    #177
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  18. Nov 13, 2019 at 6:00 PM
    #178
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    What’s a good set of replacement leaf springs? Mine are pretty flat at 52k
  19. Nov 19, 2019 at 7:43 AM
    #179
    Early B.
    Brad
    metro Atlanta
    I was looking for a set of upgraded leaf springs for the 2nd Gen 4 cyl. a couple of months ago, but didn't find anything.
  20. Nov 19, 2019 at 10:01 AM
    #180
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    No clue about your generation but have you looked to see if you can just get 6 lug springs on yours? Or tried flipping your springs if they are sagging? IDK
