The Lumpskie Build - '96 5-speed
Discussion in '1st Gen. Builds (1995-2004)' started by Lumpskie, May 17, 2013.
  1. Jun 20, 2013 at 7:32 PM
    #181
    Lumpskie
    Lumpskie [OP] Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Well, I decided to go with the Orbit eye bushings and new main leafs for my spring packs. I just need to wait for my bank account to build back up again.
    I other news: I'm getting an intermittent "clunk" from my front end during tight turns. My lower ball joint are a year old and my outer tie rod ends are about the same age... It almost sounds like it's coming from an axle... Any ideas?
  2. Jun 20, 2013 at 8:50 PM
    #182
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Original LCAs?
  3. Jun 21, 2013 at 5:12 AM
    #183
    Lumpskie
    New Hampshire
    Yes sir. Do you think it's time for new bushings?
  4. Jun 21, 2013 at 10:13 AM
    #184
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Just a thought. Mine are so worn out that my camber cant be properly adjusted. Pulls to the right when driving
  5. Jun 21, 2013 at 11:19 AM
    #185
    Lumpskie
    New Hampshire
    Those bushings have been on my to-do list for a while... maybe I should bump them to the top. That would mean I'd have to unseize my adjuster bolts too. That should be fun...
  6. Jun 21, 2013 at 11:34 AM
    #186
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I hear its easier to just replace the whole LCA :eek:
  7. Jun 21, 2013 at 1:33 PM
    #187
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This.
  8. Jun 22, 2013 at 9:42 AM
    #188
    Lumpskie
    New Hampshire
    Where do you get the LCAs from? (I imagine that they are expensive new...)
  9. Jun 25, 2013 at 7:28 AM
    #189
    Lumpskie
    New Hampshire
    In other news... I decided that I'm FINALLY going to take care of all the chrome on the truck. I'm going to Plasti-dip the badges and wheels in the anthracite color dip.
    http://youtu.be/cPVeeEzFQt8
  10. Jun 25, 2013 at 8:32 AM
    #190
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Anthracite should look awesome! Can't wait to see pics.
  11. Jun 26, 2013 at 5:59 AM
    #191
    Lumpskie
    New Hampshire
    ^Thanks man! I ordered up 4 cans of anthracite and 2 cans of glossifier last night. Now I'm wondering if that's going to be enough for a 4 wheels, the front grill, my side badges and handles...
  12. Jun 30, 2013 at 2:35 PM
    #192
    Lumpskie
    New Hampshire
    FYI for anyone interested in Anthracite Plasti-dip... It's back ordered out 1-2 weeks...
  13. Jul 14, 2013 at 12:09 PM
    #193
    Lumpskie
    New Hampshire
    For those looking to fit 33x12.5s, I had to do a little more trimming today.
    You can see where my last trimming job wasn't quite enough here:
    Here are some shots of my latest round of clearancing.
    Here's how much farther I cut back:
    Here's what it looks like all finished:
    Hopefully, this will be more than enough to keep the tires from rubbing. I'm going wheeling next weekend, so I'll know more then.
  14. Jul 14, 2013 at 1:40 PM
    #194
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'd take a hammer to the fire wall befor you go.
    Dd ou check by flexing while turning??
  15. Jul 14, 2013 at 3:54 PM
    #195
    Lumpskie
    New Hampshire
    Hey Blackdawg! So, I checked for clearance while flexing and turning, like you said. On your rig, did you just beat back the corner of the firewall or did you have to go farther?
  16. Jul 14, 2013 at 7:28 PM
    #196
    Blackdawg
    Monte
    Wyoming/St. Louis
    Like farther in??
    I beat the corner and where the pinch weld was on my first body.
    Second body I just cut all the damn pinch weld off. Then beat it down but not as much. Still banged the corners just a bit too.
  17. Jul 15, 2013 at 6:20 AM
    #197
    Lumpskie
    New Hampshire
    ^Ok, I think I understand. So, I cut my pinch welds off entirely. (ground them flat). I, also, cut back the quarter panel a bit. So, I'll beat back the corner of the firewall next. Would you think that a half inch off the corner be enough?
  18. Jul 15, 2013 at 6:42 AM
    #198
    Blackdawg
    Monte
    Wyoming/St. Louis
    Half inch off what? Haha
    It'll just take you a few times really. Took me 4 times of cutting and hammering. And it still rubbed a tad..haha
  19. Jul 15, 2013 at 12:48 PM
    #199
    Lumpskie
    New Hampshire
    It's good to know that you had to re-trim a few times. I think I'll run my this coming weekend as is and see where I rub. Then I'll pound/cut accordingly.
    Also, look what showed up today.
    I've never plasti-dipped anything, so I think I'll start with my side badges. Hopefully, this anthracite color looks as good as it does in pictures.
  20. Jul 15, 2013 at 4:34 PM
    #200
    Lumpskie
    New Hampshire
    So I Plasti-dipped my side badges and handles today. Here's a quick pictorial overerview of the process.
    1. Get a good assistant. This one is in training:
    2. Clean the area you are about to dip
    3. Tape around the area. (In hind sight, I should have left a bigger section inside the tape. This would have given me a better place to peel from later on)
    4. Spray your dip. Light coat first, then heavy coats after that. I did 3 coats of anthracite and 2 coats of glossifier.
    P1050302_zpsde7d7f68_49c6dd5cbb89408f5ef27788b64ba85aae8d0ef5.jpghttp://www.tacomaworld.com/forum/newreply.php?do=newreply&noquote=1&p=7165187
    5. Peel off tape after it has dried.
    6. Peel the "background" dip away:
    I did the same with the door handles. This pic show the dip wet, but you can see the metal flake in it really well:
    Here's the handle dry. The flake isn't as apparent, but you can still see it. (You can see it much better in person)
    Here's the finished product:
    There you have it, anthracite plastidip
