The Lumpskie Build - '96 5-speed
Discussion in '1st Gen. Builds (1995-2004)' started by Lumpskie, May 17, 2013.
  1. May 19, 2013 at 4:48 PM
    #41
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea looks I retesting..not sure what coils would fit them tho..I might look into it more. Would be cool for sure. I could sell my 5100s in a heart beat on here to help offset cost a bit. As could you. But not sure I'd want to if the jeep shocks didn't work! Haha
    And shit sorry. I forgot yours were 12"
    Extended is 27.68 collapsed is 16.10
    I doubt your at the bottom of 27" I know I'm pretty close if not maxing out my 10" ones.
  2. May 19, 2013 at 8:03 PM
    #42
    Lumpskie
    Lumpskie [OP] Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Yeah, I'm in the same boat with the jeep shocks. I know there are a couple of other guys out here that might give it a try. If they prove it works, then I'll let you know:cheers:
    As far as the rear shocks go, it's good to know that I should still have some length to play with... just in case I decide to do something drastic down the road. (I'm sure you know what that feels like):spy:
  3. May 19, 2013 at 8:08 PM
    #43
    Blackdawg
    Monte
    Wyoming/St. Louis
    Honestly I dont think it would be worth it. The cvs will bind horribly with at much droop. Why the arms are longer too in LT.
    Drastic..I like drastic..:D
  4. May 20, 2013 at 12:44 PM
    #44
    Lumpskie
    New Hampshire
    ^That's why you need to get your dual cases and a rear ARB. Go big or go home!:evil:
  5. May 20, 2013 at 12:54 PM
    #45
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    nice build you have going on here :thumbsup:
  6. May 20, 2013 at 12:55 PM
    #46
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    :drool: I really want a crawl box. But, in the constant muddy terrain around here, I'm not sure it would make much of a difference.
    Don't forget the front ARB! It makes for a CV snapping good time!
  7. May 20, 2013 at 1:49 PM
    #47
    Lumpskie
    New Hampshire
    Thanks man! If you're ever near chatfield lake, you should check it out!
    That's why I'm not locked up front... I'm skerred:tinfoilhat:
  8. May 20, 2013 at 3:17 PM
    #48
    Lumpskie
    New Hampshire
    Ok, back to work on this thread. So, building a dual transfer case setup comes in three major sections...
    #1 Drilling and prep (includes removal of stock t-case and driveshafts)
    #2 Dry fitting process
    #3 Final Install
    So, the Inchworm adapter plate (t-case to t-case) comes with a 0 degree and 10 degree clocking option. This is the clocking for the crawl box. I chose the 0 degree option. With the help of a drill press owning buddy, I got 7 holes drilled into my front adapter plate. These holes will have the crawl box clocked at 0 degrees. We also filed down some burrs, and flattened out a section that wasn't quite flat.
  9. May 20, 2013 at 3:20 PM
    #49
    Lumpskie
    New Hampshire
    Step #2
    The truck went beyond the point of no return, thanks to the the help of my buddy, Gerdo. Pulled off the driveshafts and dropped them off at Rocky Mountain Driveline. Then we got busy on the crawl box stuff. We pulled my transfer case off, split it, and resealed it. (it had a slow leak) Then we bolted the two cases together and started the dry-fit process. After some banging on the floor, we got the cases into what will be their final position. (~15* clock)
    Pictures:
    Gerdo removing coupler from the stock t-case
    Floor Clearance done.
    On the jack, rolling under the truck (we ended up just bench pressing it)
    View through the floor
    View from under the truck. Clocked ~15 degrees, the T-case is almost flush with the frame rails. Close enough for me.
  10. May 20, 2013 at 3:24 PM
    #50
    Lumpskie
    New Hampshire
    Step #3 Finish Floor mods and final install
    Dual cases sealed.
    Floor cut for shifter.
    Drive shafts modified and reinstalled.
  11. May 20, 2013 at 3:26 PM
    #51
    Lumpskie
    New Hampshire
    So, that left me with an interior looking like this:
    But not for long... It was time for triple sticks....
  12. May 20, 2013 at 3:41 PM
    #52
    Blackdawg
    Monte
    Wyoming/St. Louis
    More like front and rears. Your even manual hubs!! Lucky. Great for front lockers.
  13. May 20, 2013 at 3:58 PM
    #53
    Lumpskie
    New Hampshire
    You're right. They dual cases actually really help too. But... fixing that rear bind is objective #1 right now.
    A wise man once said Oh my... the plans... the money. He's right.
  14. May 20, 2013 at 4:34 PM
    #54
    Lumpskie
    New Hampshire
    Ok, so before I installed the triple sticks I modified them a bit. First, I bent the levers away from each other, then cut the levers to match the height of the crawl box shifter.
    iraked back the shifters 20 degrees or so and one of the lever arms underneath had to be re clearanced.
    Then I fit everything into the bezel. It have to be moved backward about 2 inches, but everything fit.
  15. May 20, 2013 at 6:39 PM
    #55
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    sweet truck!!!!
    Did you use 2nd gen tundra shocks and coils?
    I will be watching about the jeep shocks as well!!
  16. May 20, 2013 at 7:13 PM
    #56
    Lumpskie
    New Hampshire
    So, I used the Toytec coilover collars with 2nd gen tacoma 16" Toytec (eibach) coils. The shocks are from a first gen tundra. (I believe) What I like about this setup is that there is no spacer involved and my coilovers are set only about a third of the way up for about 3" of lift. This reduces the preload on the springs an allows them to flex really well.
    If you end up using the JK shocks, post up you experiences. I'm eager to hear how they work out!
  17. May 20, 2013 at 7:15 PM
    #57
    Lumpskie
    New Hampshire
    So, after I installed the triple sticks, I had to come up with a way to hide the linkage. Most people have a center console to cover it all up but I do not. So, I decided that making a raised section of floor was the best solution. Once again, Gerdo to the rescue with his hammer on bean bag skills:
  18. May 20, 2013 at 7:23 PM
    #58
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    so what sold you on the twin stick upgrade?
  19. May 20, 2013 at 7:32 PM
    #59
    Blackdawg
    Monte
    Wyoming/St. Louis
    A wise man indeed :spy:
    i love that triple stick setup man..seriously so sick :drool:
    whats not to like? Have low range and low low range in 2wd drive so you can take sharp corners without the CVs binding. Freaking sweet.
  20. May 21, 2013 at 5:56 AM
    #60
    Lumpskie
    New Hampshire
    So there were a couple of reasons I liked the Twin stick. The first one was related to my bench seat. The rear t-case shifter popped out just in front of the seat when I drove the truck. My wife needs the seat closer to the steering wheel to reach the pedals and she couldn't do that with the shifter there.
    The second reason was for the ability to choose 2-wheel high, 2-low, 4-low, low-low all independant of one another. I can choose where the loading in my drivetrain goes now. Also, if I choose to upgrade to 4.7 gears for the front case, I can go 2.57:1, 4.7:1 and 12.1:1 however I want.
    Finally was just aethetics. I think it looks nicer with all the shifter lined up in the stock bezel. I wanted it to look as stock as possible... I'm a nerd like that!:anonymous:
