The mystery of loose steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Mar 1, 2019.
  1. Mar 3, 2019 at 5:42 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Do you have bigger tires or anything like that? Or just all stock
    Do you have the alignment printout?
  2. Mar 3, 2019 at 5:48 PM
    toyodajeff
    jeff
    06 reg cab sr5
    I had an alignment done once when I had 33s on my truck. I think they didn't put enough caster in and it wandered over the road pretty bad. Maybe your experiencing that.
  3. Mar 3, 2019 at 9:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Did you change the tires? Long story, but I've had my steering rack replaced due to some play in the gears, had the tires swapped at the same time and have always thought something was just a bit off. Well, I just went from Michelins back to an all terrain tire and can't believe how much straighter the truck drives now. Steering feels tighter as well. The exact opposite that you usually hear from folks, wish I'd done it sooner.
  4. Mar 5, 2019 at 4:56 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Nope, tires are the same, I've had them for 4 years now. I didn't change anything except the suspension parts
  5. Mar 5, 2019 at 7:46 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2. Doesn't 3rd gen suspension on a 2nd gen result in a lift? Alignment can be done correctly or quickly. Hard to find a tech who wants to spend the time to get the best possible result.
  6. Mar 10, 2019 at 10:19 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
  7. Mar 10, 2019 at 10:47 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    In my opinion that's not a great alignment and could be better. The problem with computerized alignments is the tech has stock parameters they shoot for (in the green), which doesn't always mean a good alignment. I think they overshot your camber and took away some caster. I would aim for 0 camber, 3-3.5 caster and 0-0.05 toe.
    I would ask you to put it back on the rack and redo the camber. First, check to see if your numbers are the same as the final alignment you had. If they changed considerably (look at Cross toe) then you either have a loose suspension/steering component or a problem with the person doing the alignment.
    Weissenheimer and tcjacado like this.
  8. Mar 10, 2019 at 10:52 AM
    Nixinus
    Oregon
    2010 4x4
    OP is listed as living in CT
    tcjacado[QUOTED] likes this.
  9. Mar 10, 2019 at 10:53 AM
    tcjacado
    tcjacado Well-Known Member
    Oppps my bad... I saw your screen name and location:oops:
    I need more coffee or sleep.
    *Poof *gone
  10. Mar 10, 2019 at 11:03 AM
    Nixinus
    Oregon
    2010 4x4
    Ive had a few of those mornings. Now I never TacoWorld before coffee.
    Toms2Yotas and tcjacado[QUOTED] like this.
  11. Mar 10, 2019 at 12:17 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Yup, CT, used to live in Manhattan Beach, though! Miss it
    The place i brought it to is a small shop. Some good, local guys who i have put on tires for me and stuff. I have an appt to bring it back in tomorrow and have them look at it again so I'm interested in if the numbers will read the same
    Thanks for the input
    tcjacado likes this.
  12. Mar 10, 2019 at 6:35 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Yep I've had an alignment before and they didnt out enough castor in and it wandered over the road. Took it to one of the quick lubes my buddy works at and he took his time and got both sides to about 2.5 castor and it helped alot.
  13. Mar 10, 2019 at 6:36 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    I heard about this, is there a photo or something showing where to do it? Mine has a bit of wiggle, but it would be cool to solid-it-up.
  14. Mar 10, 2019 at 7:23 PM
    tcjacado
    jross20[QUOTED] likes this.
  15. Mar 10, 2019 at 7:55 PM
    #35
    jross20
    Georgia
  16. Mar 10, 2019 at 7:59 PM
    #36
    tcjacado
    Yeah i am not sure... having a hard time locating a thread on it. Pretty sure it's the bushing by the floor where steering goes through the fire wall, dont quote me on this as i am going off of memory of a photo I saw on here. You shove a few zip ties in to snug up the play.
  17. Mar 10, 2019 at 8:01 PM
    #37
    jross20
    Georgia
    I vaguely remember a photo of some steering rod with an arrow or something showing where to put the zip tie... haha.
    :confused:
  18. Mar 10, 2019 at 8:05 PM
    #38
    tcjacado
  19. Mar 10, 2019 at 9:33 PM
    #39
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Your caster needs to sit around 2.3-2.5 on both sides, that'll help with a tighter steering feel and less wandering at higher speeds, your caster on your left tire and right tire have too much of a variance between the two, this may be causing what your feeling now, best they need to be close or equal to each other.
    Your Camber is too much positive, you're going to be off-spec once the suspension moves up or down. You need to be sitting at -.3 to +.3 to account for keeping camber within specs during suspension travel. The closer to 0 the better, but without aftermarket upper control arms it can take some time to adjust it correctly. I manage to get mine to .03 on my right side and .02 on the left side, once I was lifted about 2 inches up front, Caster for mine was 2.3 on one side and 2.4 on another, which was acceptable to me. You can adjust to have more Caster but I would only recommend going more if you have much larger tires since larger tires tend to cause more wandering at higher speeds.
    Toe needs to be more positive, not to a huge degree but just enough that way when the vehicle is moving, considering bushing flex it'll push the front tires outwards, zeroing out the toe during vehicle movement, this improves tire wear and helps with cornering. Think of it this way, when the rear wheels push the vehicle forward, the front tires will tend to want to pull toe out or negative toe. Adjusting to have a little positive toe helps zero it out so when your driving your close to 0 toe or at it. a total toe of .05 would be ideal. However having it at Zero is fine too.
    This is just from my experience and personal knowledge.
    Campingcarrier and Weissenheimer like this.
  20. Mar 11, 2019 at 9:18 AM
    #40
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Damn dude, you know your stuff. I didn't realize how uniquely each car is for their specific alignment and how every shop needs to be aware of it. I didn't think finding a good alignment place would be such a PITA
    Weissenheimer likes this.
