The Newest OME Dakar Leaf Packs
Discussion in 'HeadStrong Off-Road' started by HeadStrong Off-Road, Jun 17, 2020.
  1. Feb 3, 2021 at 8:15 AM
    #61
    D.W.B
    D.W.B Well-Known Member
    Dennis
    Mar Vista, CA
    TRD OFF-ROAD
    I'm running Fox 2.0 (985-26-118)
    CygnusX191[QUOTED] likes this.
  2. Feb 3, 2021 at 8:28 AM
    #62
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    The EL46XL was made for the leaf pack you are currently running. I would pick those up and the anti squeak pads, and maybe shims while your at it.
    Maybe the Icon add a leaf would work, but my preference would be to keep it the same as a matched set. The OME leaf is just the extra leaf that you would have received if you purchased the heavy pack to start with.
    As soon as my cap is delivered I’m probably going to do the same thing.
    CygnusX191 likes this.
  3. Feb 3, 2021 at 11:27 AM
    #63
    D.W.B
    Dennis
    Mar Vista, CA
    TRD OFF-ROAD
    Thank you for the advice @minium
    I'm not sure what would work better to bring the arch back because the Icon has 3 leafs (shorter) vs the OME with 1 leaf (long).
    If I had known about my bed carrying so much weight I had order the heavy duty pack from the beginning and plus, I know I'll have to replace also my Fox 2.5 Coilover springs, but that's another topic I'll look for it.
    What would be the anti squeak pads? Do you mind sending me a link?
    Thank you. Appreciated.
  4. Feb 3, 2021 at 11:59 AM
    #64
    minium
    Yup, here are the shims you might need to get rid of any vibrations in the driveline:
    Here is a link to the pads:
    https://www.headstrongoffroad.com/store/p606/OME_Dakar_Replacement_Anti-Squeak_Pads_-_ARBSRBC60B_(PACK_OF_4).html
    C41n and D.W.B[QUOTED] like this.
  5. Feb 3, 2021 at 2:05 PM
    #65
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    depending on the wear factor of your fox shocks, you might be able to have them rebuilt for a lot cheaper than replacing them.
  6. Feb 22, 2021 at 9:02 PM
    #66
    jdubyat2
    jdubyat2 Well-Known Member
    Josh
    Scottsdale AZ
    2021 Tacoma TRD OR DCSB
    Question for you all. I bought the EL112R heavy duty and I have some forward rake on my truck. I have ADS on all the corners. I visited ADS today and they suggested I take out a leaf I. The back. The one he suggested is the thick flat one 2nd from the bottom (I think). Is this the leaf you guys would pull. Just want a consensus before I pull the leafs apart. Thanks.
  7. Feb 23, 2021 at 4:53 AM
    #67
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Nah. Forward rake is normal. Gona look real awkward if you go level and then it settles a bit or you carry a load. Imo
  8. Feb 23, 2021 at 4:08 PM
    #68
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    What do you have on the front?
  9. Mar 26, 2021 at 3:41 PM
    #69
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    Anyone have any reviews of these springs now that they’ve been out for a minute?
  10. Mar 26, 2021 at 5:55 PM
    #70
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    mine (OME Dakar Medium) flattened out a bit but the ride hasn't suffered if anything, it's gotten better. Went wheeling pretty hard last weekend at Shamrock Shakedown in Oliver springs Tennessee and they were fantastic. Truck still maintains it's lifted stance.
    xLOGREx[QUOTED] likes this.
  11. Mar 26, 2021 at 7:01 PM
    #71
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Right on! Think they’ll hold up? Kinda unsure about it settling on you already.
  12. Mar 26, 2021 at 7:04 PM
    #72
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    like I said my ride height hasn't really changed noticeably, they ride great, plus I wheel the crap out of this thing. I also tend to put a bunch of stuff in the bed regularly. Nothing super heavy otherwise it would have got the heavier pack. I guess we'll see how it holds up over time, although my buddy has the same pack in his truck and he's been wheeling harder than me for a lot longer. And his are just fine.
  13. Mar 30, 2021 at 12:21 PM
    #73
    fourwhlcrzy
    fourwhlcrzy Member
    Daren
    08 taco, 93 hilux
    lifted
    Just got my Heavies installed. Sitting 2" higher than my old worn out factory pack with AAL. 24.5" center to wheel well on a fully loaded truck, camper shell, drawers, ect. The springs are double arced like wet noodles, but holding height so far. I had to grind the ends down to fit in shackle, which I though was bullshit. The leaves are notched on the front end but not the back? I would have ran them backwards ( arrow pointing back) but the double wrap on one of them wouldn't fit in the shackle.
  14. Mar 30, 2021 at 2:26 PM
    #74
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's wild, mine are notched at both ends
  15. Mar 31, 2021 at 3:37 PM
    #75
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    I’m seeing conflicting info on this so I’m curious which U-Bolts are needed for the EL111R (MD) springs, is it the OMEU53A or OMEU53B?
  16. Apr 5, 2021 at 4:49 PM
    #76
    trypset
    trypset New Member
    2015 Silver Tacoma 4x4 V6
    Double wrapped end on the rear or forward part of the truck?
  17. Apr 5, 2021 at 6:13 PM
    #77
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Does your leaf pack not have giant yellow arrows?
  18. Apr 5, 2021 at 6:45 PM
    #78
    trypset
    trypset New Member
    Mine did not. I had to look on a few video tutorials and saw the side with 2 full clips was going to the rear/shackle. The side with the open and single clip forward.
    was just double checking
  19. Apr 6, 2021 at 8:59 PM
    #79
    WarChild07
    WarChild07 Active Member
    Austin
    Wyoming
    2016 TRD OR
    Wheels, tires, OV tune, grille, bed cover, Clazzio covers, remote start, purdy stuff
    I have had the new medium packs for about a year and they are squeaking pretty bad. Can’t even get out of my truck without a squeak. Solution for this to replace the pads or to the grease points work on these?
  20. Apr 7, 2021 at 5:10 AM
    #80
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Sorry I don’t know the answer to that but do you have the old version or new version of leafs? New ones are EL111r and EL112r.
