The Newest OME Dakar Leaf Packs
Discussion in 'HeadStrong Off-Road' started by HeadStrong Off-Road, Jun 17, 2020.
  1. Jan 15, 2022 at 3:18 PM
    #101
    WoodsEdt
    WoodsEdt Member
    Tyler
    Missoula, MT
    2020 OR
    Arb bumper Snugtop topper Spacer lift :( Customer drawer system
    @Spectre_6MT how the new HD Dakars holding up? Im trying to figure out if I want the medium or heavy set. I have a topper and drawer system (usually filled with items) on the truck all the times. When I go wheeling or camping the bed is mostly full and I soon will be getting a RTT. Again just curious what you have attached to your truck with your HD Dakars as comparison.
    DuffyBank and CygnusX191 like this.
  2. Jan 15, 2022 at 3:26 PM
    #102
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sounds like you need the heavy set.
  3. Jan 15, 2022 at 3:46 PM
    #103
    WoodsEdt
    WoodsEdt Member
    Tyler
    Missoula, MT
    2020 OR
    2 part follow up:
    Will I need shims? I already have the cb drop
    Shock recommendation? I don't wheel hard enough, and my budget is limited, so getting a high end shocks is not worth it. Im looking at the 5160/6112 set up. I ran the 5100 set up on my old Taco, nothing crazy good about them but got the job done. Hoping the 5160/6112 set up may bring some cheap thrills.
    CygnusX191 likes this.
  4. Jan 15, 2022 at 5:07 PM
    #104
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If you're getting OME leaves just go ahead and get a full suspension from them. Nitrocharger shocks are just as good as 5100s, if not a little better.
  5. Jan 16, 2022 at 7:31 PM
    #105
    Spectre_6MT
    Spectre_6MT Member
    Decked system and RSI Smartcap. Mine are still working great for me, and I think the mediums might have me about level (2" lift in the front), but I think they would sag if I carried much more or if I towed anything. HD's give me about a 1" rake.
  6. Jan 16, 2022 at 7:33 PM
    #106
    Spectre_6MT
    Spectre_6MT Member
    I didn't need shims, but did install the CB drop spacer kit.
  7. Jan 17, 2022 at 9:28 AM
    #107
    WoodsEdt
    WoodsEdt Member
    Tyler
    Missoula, MT
    2020 OR
    Thanks for the info! Have you measured hub to fender, front and back? Curious where your sitting.
  8. Jan 23, 2022 at 2:53 PM
    #108
    optifree
    optifree Well-Known Member
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Hey all. A few weeks ago I bought a 2010 Access Cab TRD. It already has OME pack, but they are making noise so I want to replace them. I believe currently, it is OME model 12b15, which is what it says on the top of the leaf, I can't make out the white sticker as the print is gone. I can't find any information on the ones that I have now but would like to replace them and I see that this new pack is the EL111R a direct replacement for what I believe is 12b15?
  9. Jan 23, 2022 at 4:14 PM
    #109
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If they're just squeaking, all leaves squeak. If it's still holding the truck up, no need to replace
  10. Jan 23, 2022 at 4:27 PM
    #110
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    I don't have much squeak, it's more so leaf shifting causing thud sounds from the rear.
    CygnusX191[QUOTED] likes this.
  11. Jan 23, 2022 at 4:58 PM
    #111
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Wonder if your spring retaining bolt is missing.
  12. Jan 23, 2022 at 5:06 PM
    #112
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Is that the one that goes through the center of the leafs?
  13. Jan 23, 2022 at 5:22 PM
    #113
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yup
  14. Jan 23, 2022 at 5:28 PM
    #114
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Ok. I'll have to check tomorrow. I did re-torque the unbolts but that did not seem to help.
  15. Jan 23, 2022 at 7:19 PM
    #115
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's a bit of work, but if you don't have grease circs on your shackle bolts you might have to take the leaves out and regrease those poly bushings.
  16. Jan 23, 2022 at 7:28 PM
    #116
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    It's not the squeak that I'm worried about, it's the clunk. I found a video of the same sound I have. When shaking the truck side to side this is the noise I get.
    https://youtu.be/8P5ddiKhB1U
    I had a suspension tech look a at it and found the leaves are shifting which is causing the noise. He isolated it by using vice grips on the leaves and the noise went away.
  17. Jan 23, 2022 at 7:43 PM
    #117
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Well damn lol
    At that point it might be easier just to order a new set of medium leaves and call it a day
  18. Jan 24, 2022 at 8:17 AM
    #118
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Yup that's what I'm thinking. They're old leaves anyway and I can't even find information about the model number I see listed on the top leaf. Is the EL111R a direct bolt in?
  19. Jan 24, 2022 at 8:42 AM
    #119
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yup. Just make sure you grab new 7 and 1/2-in u-bolts
  20. Jan 24, 2022 at 8:52 AM
    #120
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Awesome. Thank you.
