The NorthStar AGM Battery + Voltage Booster Upgrade
Discussion in 'Technical Chat' started by crashnburn80, Apr 14, 2019.
  1. Apr 24, 2020 at 7:19 AM
    #621
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Should edit topic and add 2nd Gen ONLY
    cytocycle likes this.
  2. Apr 24, 2020 at 7:21 AM
    #622
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Haters, Crash has always shared the wealth. Glad he is not an ass hat.
  3. Apr 26, 2020 at 6:17 PM
    #623
    3Tacomasthecharm
    3Tacomasthecharm Member
    2017 Sport, Quicksand
    I've had some recent email communicationes with the guys over at Off-Grid Enginering and they say there are no "issues" with using their dual battery systems for AGM batteries on the Gen3. They said theyv'e been installing these since 2017 and no complaints. Anyone do jut a straight forward install with the system and AGM batteries?
  4. Apr 26, 2020 at 6:41 PM
    #624
    Glenn_R
    Glenn
    I got my dual battery kit from Off Grid in 2017 and installed two Northstar AGM batteries in Dec 2016 on the 2017 Tacoma. No issues at all. I just ran them through the test and recondition on my CTEK charger and it went right past the desulphation step and that can take up to 8 hours.
    Landpirate likes this.
  5. Apr 26, 2020 at 7:14 PM
    #625
    3Tacomasthecharm
    Good input Glenn. Just to confirm, you don't ever have to put your AGM batteries on a charger?
  6. Apr 26, 2020 at 8:00 PM
    #626
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I started this thread as a reference to what is "the best battery" and to make people aware of the charging differences required by AGMs, and the solution I came up with to correct the issue. Not to be 1st/2nd/3rd Gen specific, hence posted in the technical section. In speaking with reps at NorthStar, they called out Toyota specifically as being notoriously bad for their batteries as Toyota charging voltages are lower than other manufactures (I have not substantiated that claim, but it was interesting to hear that when I had not mentioned anything Toyota specific). It is basic chemistry that the life and performance of an AGM will be reduced if not charged at the specified voltage, as the battery will slowly sulfate and reduce in performance over time. This doesn't mean that it won't work for years, but if you are paying top dollar for a premium battery, you'd expect the premium long lasting performance. To get that requires charging the battery as the manufacture specifies.
    While I like the HKB booster as a purpose made product for my truck, it unfortunately doesn't work for 3rd Gen. It sounds like OVTune may finally have something in the works, which would be great. I think it is helpful to include all the Gens, even if the current answer for 3rd Gen is a wall charger. I should update the original post with a wall charger recommendation for 3rd Gen as recommended by NorthStar, I dropped the ball on that phone call with them on that topic a while back. While many 3rd Gen owners may ask if it works for their truck, labeling the thread 2nd Gen would make it so 3rd Gen owners wouldn't read it and may be unaware of the charging differences or the relevant battery information provided. Hopefully OVTune has a solution for 3rd Gen, and when they release such a fix the original post will be updated for an on-board 3rd Gen solution.
  7. Apr 26, 2020 at 8:25 PM
    #627
    Glenn_R
    Glenn
    I bought the CTEK with the intent to put my batteries on the charger ones a month and run it through the recondition profile. I have not done that until this month. They both went through the cycle without a hitch. If I get over 5 years out of these I will be happy. I knew when I put them in I was not going to be charging them at the preferred voltage. My truck puts out about 13.8 volts at 2000RPM and higher. I hope @OVTune will look at making away to updating the ECU to 14.6 volts, selectable.
    @crashnburn80 thanks for your support on TW. No matter what we drive you have always been a great asset to the forum.
  8. Apr 27, 2020 at 3:28 AM
    #628
    3Tacomasthecharm
  9. Apr 27, 2020 at 11:38 AM
    #629
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Yes, very much appreciated.....even from us 3rd geners.
    mac_2_nite likes this.
  10. Apr 27, 2020 at 3:03 PM
    #630
    taco.matt
    taco.matt Well-Known Member
    2018 Quicksand TRD OR DCSB
    Looks like VF Tuner from OVTune will have options to modify alternator voltage and duty cycle (see link below). Thoughts on modifying these parameters for an AGM batt using the OEM alternator? Would you recommend a HD alternator?
    https://www.tacomaworld.com/threads/vf-tuner-for-the-3-5l-tacoma.662948/page-9#post-23245827
    ihatemytruck likes this.
  11. Apr 29, 2020 at 10:24 AM
    #631
    Glenn_R
    Glenn
    The tow package comes with a bigger alternator, I think? Will need to check that out as I can't remember for sure.
  12. Apr 29, 2020 at 11:09 AM
    #632
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not sure about 3rd Gens, but 2nd Gen Tow Package included a "130-amp alternator." As mentioned previously, however, the issue is one of voltage, not amperage.
    SR-71A likes this.
  13. Apr 29, 2020 at 11:13 AM
    #633
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    yep, that's the same on the 3rd gens w/ tow package
    Norton[QUOTED] likes this.
  14. Apr 29, 2020 at 4:12 PM
    #634
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Looks like you will need to modify duty cycle to increase voltage, which shouldn't be a problem as long as duty cycle does not exceed the OEM rating. I'm not sure what the OEM rating is. Based on some non-Toyota charge tables I've seen in HP Tuner threads, it looks like duty cycle needs to increase ~10% for a 0.5v bump. That is an apples to watermelon comparison as it isn't a Toyota alternator, but should help to give a ballpark of the values we are looking at.
    Trucks with the tow package already come with the factory HD 130A alternator. Non-tow 3rd Gen I believe use a 100A alternator, and 2nd Gen an 80A alternator. An HD alternator gets you more amps, not more volts. The only reason to go with an aftermarket HD alternator is if you want to pull some serious electrical loads for extended periods of time, like doing heavy winching without allowing battery recovery time. Your battery is the power reserve and with the NorthStar battery, that reserve is significantly improved over stock. So even winching off the stock alternator, you are using the power reserves from the battery that the alternator then replenishes at a slower rate. Most don't have high power draws long enough that the power reserve is depleted beyond what the alternator can replenish, requiring an alternator upgrade. If you've never seen the battery alarm come up on your dash while the alternator is in max charge, an aftermarket HD alternator likely isn't going to do much. And typically aftermarket alternators are less reliable than OEM. If my 2nd Gen came with an 80A alternator I'd certainly consider getting the OEM 130A one, but few need the typical 270A+ aftermarket HD alternators.
  15. Apr 29, 2020 at 4:19 PM
    #635
    taco.matt
    Great, thanks for the input!
  16. Apr 30, 2020 at 1:02 PM
    #636
    Pigpen
    Dan
    Northwest Montana
    I put in the diode from digikey and it threw up the dummy light that's a battery. I removed it immediately. Fortunately, I got my little package from Australia. I popped in the new booster fuse, and everything is good. I haven't put a volt meter on it. I'm just happy to know I'm doing right by my battery.
    BenMara, MattCowsmasher and Sna like this.
  17. Apr 30, 2020 at 1:18 PM
    #637
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you try reversing the digikey one? They only work one way, if you put it in backward the battery dummy light will come on.
    12TRDTacoma and buyobuyo like this.
  18. Apr 30, 2020 at 1:42 PM
    #638
    Pigpen
    Dan
    Northwest Montana
    That must've been it. I didn't try, but that would explain the arrow on it. The HKB unit was already on order so I just waited another week or so and it showed up.
  19. May 3, 2020 at 11:13 AM
    #639
    ihatemytruck
    Dave
    Southern California
    OVtune sent out a test file today, and successfully adjusted the setting in vFtuner where you can adjust it. So looks like 3rd gen guys with the tune and vFtuner will be stoked.
    mac_2_nite, SR-71A, Norton and 2 others like this.
  20. May 3, 2020 at 11:19 AM
    #640
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Be curious to see any posts from someone who has done it and validated the results. If there is a source page/post for the release I’ll update the original post with the info for 3rd Gen.
    ihatemytruck[QUOTED] likes this.
