The Official Gym & Fitness Thread
Discussion in 'Health' started by TyT, Jan 31, 2011.
  1. Nov 6, 2011 at 9:01 PM
    #1681
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    pullovers, t-bar rows heavy squating bent over rows and pull ups both close neutral and wide.
    this will increase the size of your lats rhomboids expand your rib cage at least thats what the old school guy's thought lol.
    also do not neglect your abs one of the easiest ways to look wider would be to bring in your abs and waist.
    sean would probably have some great advice for you as well that guy is a solid looking mofo :)
  2. Nov 6, 2011 at 9:08 PM
    #1682
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i have an 8 pack haha my abs cant change much i dont think haha
  3. Nov 6, 2011 at 9:14 PM
    #1683
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    just figured i would add that in there lol i wasn't sure what shape you are in.
    well then basic movements good form and volume that will put size on you quickly.
  4. Nov 6, 2011 at 9:16 PM
    #1684
    PLC721
    Patrick
    Chandler, Az
    oh ive been doin this for a while, i'm in shape and strong but just a little bit leaner than i want to be, lol i'll add pull overs into my work out and keep going heavier on my t-bar rows
  5. Nov 6, 2011 at 9:23 PM
    #1685
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    inverted row is an exercise i used to mix back up. switching it up to keep those muscles confused is important.. in addition to the above exercises, this may help w/thickness.. mostly to hit them at a different angle, use different muscles, improve your strength when you go back to the classic big muscle movements
    http://youtu.be/dvkIaarnf0g
  6. Nov 6, 2011 at 9:25 PM
    #1686
    PLC721
    Patrick
    Chandler, Az
    those look good ill give them a try!^^
  7. Nov 6, 2011 at 9:29 PM
    #1687
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol i do those on back day with a 50 pound weight vest :) they are killer.
  8. Nov 6, 2011 at 9:31 PM
    #1688
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    what does your back day routine look like
  9. Nov 6, 2011 at 9:36 PM
    #1689
    MotoTacoma
    Pencilveineeya
    let me know how you like/dislike them.. at first i felt like they were harder than they looked.. i do 4 sets of 12 and usually do them as my last back exercise or 2nd to last.. for good form (like most back exercises) you want to imagine your hands are hooks (i use a 4 finger grip with my thumb next to my kunckle (not around the bar) and the goal is to pull your elbows back as far as you can to lift your body up. that way you use as little bicep as possible. hopefully you like em!
  10. Nov 6, 2011 at 9:36 PM
    #1690
    PLC721
    Patrick
    Chandler, Az
    deadlift, pull ups behind the neck then close grip. then t-bar row, beant over dumb bell row and thats usually it, 4 heavy lifts.
  11. Nov 6, 2011 at 9:44 PM
    #1691
    MotoTacoma
    Pencilveineeya
    i have 3 versions of back day.
    1. all body weight
    2. all machines or cables
    3. combo (switching each exercise each combo)
    here's my body weight day
    pull ups. warm up w/body weight for 12 reps
    then 4 sets with weight
    1. 45 lbs for 10
    2. 55lbs for 8
    3. 65lbs for 8
    4. 75 lbs for 6
    Vbar pull up rows. 4 sets w/25 lbs ..10, 10, 8, 8
    inverted rows 4 sets of 12.. no weight.. i should get a vest..superset w/back extensions 3 of 10.
    then reverse flys w/dumbells or something random (i realize this isn't a body weight exercise so i guess there are some exceptions haha)
  12. Nov 7, 2011 at 7:07 AM
    #1692
    MotoTacoma
    Pencilveineeya
    Page 130 in the november 2011 issue. "inside the cult of crossfit"
    what i took from the article (easy crossfit fans, i've never done crossfit and i'm not bashing it, i'm just writing my reaction to the MH article) was basically that the instructors get minimal training, the potential for injury is high, and the end results are basically that you can perform better at crossfit, fat loss, and that it doesn't build muscle as accurately as a weightlifting regiment, which is what a lot of guys goto the gym for, to build muscle. they said the potential for injury is high b/c you are doing intense exercises after being really exhausted.. "fatigue and going to failure"..
  13. Nov 7, 2011 at 8:52 AM
    #1693
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    So then the injury would then be attributed to bad form because you are exhausted right?
  14. Nov 7, 2011 at 12:37 PM
    #1694
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Isn't that what you're supposed to do? Reps to failure...
    You can do anything with the possibility of injury, you can get hurt lifting heavy weights for low reps with bad form just as easily as you can get hurt lifting lower weights with high reps with bad from. There are many levels of instruction as well.
    M&F may not like crossfit because its not conventional....but it works for lots of people's goals, like P90X or Insanity.
  15. Nov 7, 2011 at 1:39 PM
    #1695
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I think the failure part is the fine line. Right? I mean how you define failure is the key. Is it the point where the risk of injury has increased? Is it the point you can no longer perform the exercise? For me, it's been the point just before I can no longer safely control the weight.
  16. Nov 7, 2011 at 6:27 PM
    #1696
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Haha thanks man! I'll help in anyway i can! Just post up
  17. Nov 7, 2011 at 6:30 PM
    #1697
    T-Rex266
    Elon
    Pull ups!! It's a staple movement! If this is a lagging body part for u, I would recommend begin EVERY workout with 30 pull ups. IMO, you can't "over due" self body weight exercises.
    -wide lat pull downs
    - press down with lat bar (hold for contraction)
    -db rows
    -cable rows
    ...I can go on lol
  18. Nov 7, 2011 at 6:32 PM
    #1698
    T-Rex266
    Elon
    In "off season" , like now I just maintain the abs. They're no where in competition shape obviously but they can be seen..with the right flex lol.
  19. Nov 7, 2011 at 6:35 PM
    #1699
    T-Rex266
    Elon
    There's a fine line of pain from
    Injury and pain from muscle sweat :) feel the difference and use common sense...#stillrehabinginjuries
  20. Nov 7, 2011 at 6:38 PM
    #1700
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hmmm might try to do the 30 pullups tomorrow on my back bi day
    i have to have abbreviated workouts due to my schedule the next two weeks, heck wednesday and monday tues weds next week im traveling a total of 4 hours just to work out
    also i didnt get to do the full arm workout, at my gym cops get priority over fire fighters so we got run out mid way through the workout and had to go to another gym
