The purpose of the transmisson cooler
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Feb 12, 2008.
  1. Feb 12, 2008 at 4:04 PM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    What are the posittive aspeects of installing a trans oil cooler? On a 02 dblecab yota v6 with aut trans?
  2. Feb 12, 2008 at 4:14 PM
    11secgt
    11secgt Well-Known Member
    most vehicals with automatic transmissions already have coolers on them, most are part of the radiator..take a closer look at your truck, if you have a tow package on it you probably already have an additional cooler on it from the factory...
    positives of an addtional cooler include:
    extra fluid capacity
    lower trans temps
    longer life out of fluid and trans
    its a must have if you do a lot of towing or off roading..
  3. Feb 12, 2008 at 5:12 PM
    evstacoma
    evstacoma New Member
    2004 Ext Cab 4x4 TRD
    It helps to cool the transmission, ha ha ha ha.
