The "so easy a caveman can do it" abs disable mod with pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Btnewman, Apr 28, 2012.
  1. Jul 27, 2013 at 6:59 PM
    #81
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Power windows are no longer working, trying to figure out which fuse they are on.
    Damn it...
    Is there any way to test if one of the square 50A fuses under the hood is blown? I have used a test light on blade type fuses before but have no idea how to test the 50A square fuses.
  2. Jul 27, 2013 at 7:34 PM
    #82
    Btnewman
    Btnewman [OP] Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    They test pretty similarly to the balde type fuses... but it doesn't make a whole lot of sense as tobwhybthe e brake light and now power windows are going hey wire
  3. Jul 27, 2013 at 7:40 PM
    #83
    Mxpatriot
    reconnected wire to factory config.
    ABS light on. E-brake light on. Locker light on.
    No power windows.
    Fuses do not look blown.
    Shit.
  4. Jul 27, 2013 at 7:44 PM
    #84
    Btnewman
    Benjamin
    Grand Junction co
    I guess try disconnecting and reconnecting the battery, maybe a reset is what it needs, can you post pics of as far as you got such as wiring harness and other possibly usefull pics?
  5. Jul 27, 2013 at 7:50 PM
    #85
    Mxpatriot
    Have disconnected and reconnected battery everytime that I have worked on the plug; still not working.
    I tried to take a picture, it's dark outside so it's coming out poorly. It is the correct wire, I checked against your pictures a million times. It is now spliced together.
    At first the mod appeared to do nothing - I was flipping the switch and turning the truck on and off and getting nothing.
    I looked up at the dash and all three lights were on (e-brake, ABS, and locker). I then discovered that the power windows are not working.
    I cannot locate a blown fuse but I am certain that must be it. Must be a main fuse that feeds that block of fuses.
  6. Jul 27, 2013 at 7:51 PM
    #86
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Are there any identical fuses you can use to swap out and verify?
  7. Jul 27, 2013 at 7:57 PM
    #87
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Ign 1 no. 2 fuse
    Triple check it and replace it. Happened to me, I bet your air doesn't work either.
  8. Jul 27, 2013 at 7:58 PM
    #88
    Btnewman
    Benjamin
    Grand Junction co
    Might not hurt to start checking relays as well
  9. Jul 27, 2013 at 8:06 PM
    #89
    Sandman614
    Tim
    '06 SR5 Off Road
  10. Jul 27, 2013 at 8:06 PM
    #90
    Mxpatriot
    Turn signal blinks but blinks very fast.
    Checking all the fuses I can find, will go check ign1. fuse 2.
  11. Jul 27, 2013 at 8:10 PM
    #91
    Mxpatriot
    This fixed it. No homo, but I love you man.
    Haven't checked the mod yet to see if it works, but the windows work again.
  12. Jul 27, 2013 at 8:13 PM
    #92
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Yup, I went through the same shit when trying this version, kept popping that same fuse. I ended up using a simple On-Off SPST switch with NO ground. I know you tried the one in my write-up, but it may be the switch you are using.
  13. Jul 27, 2013 at 8:17 PM
    #93
    Sandman614
    Tim
    '06 SR5 Off Road
    :) your welcome!
    I was sitting at a rest stop along I40 doing this mod waiting for people to go to Hurricane creek near Asheville. Popped the fuse apparently, twisted the wires back together stock, and proceeded to try to figure it out every time we stopped.
    Lol no air, music, windows stuck up, and dash lit up like a Christmas tree. We were rolling through the trail with the doors open.. Held onto them tight so they wouldn't hit trees. :rofl:
  14. Jul 27, 2013 at 8:20 PM
    #94
    Btnewman
    Benjamin
    Grand Junction co
    Glad to hear things got worked out!
  15. Jul 27, 2013 at 8:33 PM
    #95
    Mxpatriot
    Did you ever get the mod to work using this method?
  16. Jul 27, 2013 at 8:34 PM
    #96
    Mxpatriot
    I have an older truck without vsc so I think that is why your mod did not work for me. I tried it using a simple two pole spst as well as an spst with a ground.
  17. Jul 27, 2013 at 8:48 PM
    #97
    Sandman614
    Tim
    '06 SR5 Off Road
    I used landphil's method. Mine's an SR5, none of that electronic "safety" stuff other than abs.
    There's details in my build page.
  18. Jul 27, 2013 at 8:57 PM
    #98
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I used a switch with two poles....works perfect for mw
  19. Jul 27, 2013 at 9:14 PM
    #99
    acdronin
    acdronin Well-Known Member
    Ok guys, I got' a problem, I tried a two pole and it didn't work, tried a three pole and the ABS and Brake lights will not go off, tried dis on the battery, tried putting everything back to stock, no dice, 07 sport, nolocker no atrac, no nuthin. Lights all work everything else works, tested/swapped primary 50 Amp fuse, no dice, what other fuses are in this circuit and where?
  20. Jul 27, 2013 at 9:18 PM
    #100
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Guess it's not so easy a caveman could do it afterall
