The story & concerns regarding catalytic issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, May 15, 2012.
  1. May 15, 2012 at 11:15 AM
    prerunnerSD
    prerunnerSD [OP] "I Brake for Tailgaters"
    Northeast USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Check engine light was on.. code determined to be: PO420, "Catalyst system efficiency below threshold Bank 1"
    Took truck into Firestone and after spending $100 for diagnostics which they said would be more in depth than my code checker they gave me an invoice for $2,500 saying a needed both 2 new sensors and 2 new catalytic converters.
    I'd like some advice on how to proceed?
    Should I purchase all the parts as they say and where? Are the part numbers on this invoice accurate?
    Are they just overcharging me and could it be as simple as changing one sensor??
    I've cleared the code and it stays off for a couple days but then comes right back on again so I know its not just a fluke.
    Here is a copy of the invoice they gave me.
    Anyone know a good place to get these parts or do one step better and get parts better than stock?
  2. May 15, 2012 at 11:23 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would switch out the O2 sensors first and clear the code. If the code comes back then I would look towards the cats.
  3. May 15, 2012 at 11:29 AM
    aportis72
    aportis72 Well-Known Member
    Austin
    Supercharger
    I would almost guarantee its just the sensors. Look them up on rock auto they are cheap. replace them and if you throw a code after replacing them then get some O2 simulators and dont worry about it that is way to much money IMO
  4. May 15, 2012 at 11:32 AM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Be sure to buy Denso sensors, thats what came OEM, and what works the best.
  5. May 15, 2012 at 11:34 AM
    prerunnerSD
    Northeast USA
    both sensors right? where can i get denso sensors?
  6. May 15, 2012 at 11:39 AM
    prerunnerSD
    Northeast USA
    went to rockauto and they have a lot available.. should i get both sensors or just upstream or downstream?
  7. May 15, 2012 at 11:44 AM
    jsmarine
    Jeff
    Dallas, TX
    I would replace both at the same time, but the upstream one for sure.
    edit: And check Amazon for denso sensors.
  8. May 15, 2012 at 11:53 AM
    prerunnerSD
    Northeast USA
    thanks, not to seem helpless but im on Amazon.com looking for denso sensors and they have hundreds of them and no good way to input what kind of car you have to help indicate which sensors do you need.
    http://www.amazon.com/s/ref=sr_nr_scat_15735801_ln?rh=n%3A15735801%2Ck%3Adenso+sensors&keywords=denso+sensors&ie=UTF8&qid=1337107801&scn=15735801&h=348eda178390937a8703018c3aff62364f8e7fd6#/ref=sr_nr_p_4_0?rh=n%3A15684181%2Cn%3A%2115690151%2Cn%3A15719731%2Cn%3A15729591%2Cn%3A15729601%2Cn%3A15729701%2Cn%3A15735801%2Ck%3Adenso+sensors%2Cp_4%3ADenso&bbn=15735801&keywords=denso+sensors&ie=UTF8&qid=1337107819&rnid=49681011
    Heres a link to the listings on amazon... could you recommend the model numbers? I appreciate it.
  9. May 15, 2012 at 12:20 PM
    prerunnerSD
    Northeast USA
  10. May 15, 2012 at 12:25 PM
    jsmarine
    Jeff
    Dallas, TX
  11. May 15, 2012 at 12:33 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    You should also get the socket head for O2 sensors...it has a whole side cut out of it so the cable harness can stick out and not interfere. I allows the use of a socket wrench or breaker bar to remove instead of a some short open ended wrench that can slip off. Its a cheap tool when I looked one up.
    After replacing the sensors and if needed, you can try removing the Cat and dropping it in some heavy detergint cleaner, let to soak and try to clean the honeycomb. Once dry, re-install and see if the code stays away. or look into those O2 simulators
    Stupid emissions crap is all a racket...
  12. May 15, 2012 at 12:46 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '94 FZJ80
    Triple locked and 35s
    I second the o2 sensor wrench or "crow's foot" wrench.
    As to how to fix it, there are ways that won't pass emissions, do you have emission programs where you live? Or do you want it to be perfect? (if the sensors don't fix the issue)
  13. May 15, 2012 at 2:25 PM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    He won't need a o2 sensor socket... both sensors are held in place with 2 12mm. nuts FWIW
  14. May 21, 2012 at 12:00 PM
    prerunnerSD
    Northeast USA
    Thanks for all your help. ive added the OEM denso upstream 02 sensor and reset the code and hours later the same code came back on.. could this just be a fluke or is there something else wrong, could the sensor be bad?? original code was: "PO420, "Catalyst system efficiency below threshold Bank 1"
    what else code be wrong?
  15. May 21, 2012 at 12:35 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    The up-stream sensor is for air-fuel mixture, the downstream sensors are for making sure the cat is working properly. 2 completely different sensors. If you get the wrong sensors you may get the P0125, P0133, P0130 codes < this is happening to me.
  16. May 21, 2012 at 12:39 PM
    prerunnerSD
    Northeast USA
    hello thanks for your effort but i was not referring to the downstream sensor. i am getting a p420 bank 1 error and was told just to replace the upstream, sensor. i am not getting any of the codes you mentioned but thanks for your response anyway.
    hopefully someone else can help get to the bottom of this.
  17. May 21, 2012 at 12:42 PM
    goomba
    Josh
    San Antonio Fl
    Ment to say sensors. But good luck.
  18. May 27, 2012 at 5:24 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    $57 for the rear sensor (Denso oem) with free shipping.
    Link
  19. May 27, 2012 at 5:46 PM
    toy.tech21
    toy.tech21 Active Member
    Evan
    Lakewood CO
    2008 Doublecab 6 speed
    K&N intake, URD short throw shifter, toytec boss front coilovers, old man emu dakars, led's in gauge cluster, dome and map light led's
    The 3.4l engine is very well known for the p0420 cat code. Not much way around it but then to replace the cats. Its not the sensors and they wont fix the problem so i wouldnt waste your money. The price quote you got sounds about right. They are just expensive parts.
  20. May 27, 2012 at 6:33 PM
    koco
    Bay Area Ca.
    '01 Taco
    I have seen p0420 fixed by replacing the rear sensor with an oem denso unit. If it gets clogged or wears out, it will cause the code. The catalytic was soaked in laundry detergent overnight though.
