The taco LEAN!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stereo Intellect, Jun 7, 2008.
  1. Jun 7, 2008 at 9:57 PM
    Stereo Intellect
    Stereo Intellect [OP] Member
    mission viejo
    02 4wd extd cab tacoma
    Deaver rear spring pack, Icon(Donahoe) rear reservoir shocks, Icon(Donahoe) front extended travel coil overs , Icon(Donahoe) upper A-arms, cut air box w k+n air filter
    Anyone have a problem w their tacoma leaning down on the driverside. HOW do I fix this? It bothers me quite so!
  2. Jun 7, 2008 at 10:07 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    see if this answers anything for you: taco lean
  3. Jun 7, 2008 at 10:12 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    All 1st gens are notorious for the lean, not much you can do about it.
  4. Jun 7, 2008 at 10:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    There are shims on the market for fixing the lean. I belive Wheelers sells them. They work well. You can go a step further and have a spring shop re-arch your driver side leaf springs to help fix the problem, though in many times this step is not nessasary. :)
  5. Jun 8, 2008 at 12:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I had the lean on my 96.....
    Are you running stock suspension or no?
    My husband and I disagreed about where it was coming from - front or back. I believed it came from the front because of the side specific coils. On the older gens - the front coils were side specific. The one coil had an additional wrap than the other coil. I had a Rancho 1.5" coils which were not side specific. I ended up using a 1/4" thick leveling spacer that goes ontop the coil assembly that gave you 1/2" lift. That was years ago....
    Then, I switched to OME 881 coils and the lean wasn't nearly as noticable (without the spacer).
    Obviously, now-a-days there's other options depending on what you need and where you're lean is coming from.
    When was the last time you had your suspension removed or greased? Sometimes the rear shackles will *lock up* preventing free movement of the suspension. If you take them apart, clean them up, and regrease...you might feel & see a difference. Again - depends on your personal issue.
  6. Jun 10, 2008 at 8:06 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Not all-mine has NO lean front or back.....I hear the 2nd gen is more notorious for lean....I read it right here at TW! I should say this though-I didnt like the performance of the original shocks so I replaced them.
  7. Jun 10, 2008 at 9:04 AM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    Battery, gas tank and driver are on the same side, opposite of what other autos do. Carry over from the Hilux design?... where the driver is on the right side.
    My 2008 has a very noticeable lean.
  8. Jun 10, 2008 at 1:44 PM
    BlueSilver
    BlueSilver Wave rider
    this makes me think of the time I saw a 300 pound man cram himself behind the wheel of a mazda Miata
