The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. Jul 12, 2016 at 8:31 PM
    #181
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
    @Mademan925 i should have bet you at the staircase. 83 for the wheels :p
  2. Jul 12, 2016 at 9:00 PM
    #182
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Well mine are at 85. :benchpress:
    BudMan[QUOTED] likes this.
  3. Sep 12, 2016 at 7:18 PM
    #183
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Thank you!!!
  4. Sep 15, 2016 at 5:33 AM
    #184
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    As a pressure vessel engineer I would NOT use that chart as blanket for all torque applications. Torque values are a very touchy subject even in the oil and gas industry because there are a lot things to take into consideration when torquing a bolt. That is just for static equipment besides cyclic wind loads but these are vehicles that see all types of vibrations at different frequencies. The spec you are quoting does not take into consideration the application of the members you are bolting together and preload. You just stated the U-bolts should be (with assumptions of material) ~93 ft-lbs when the diagrams calls roughly 73 ft-lbs. Did that 93 ft-lbs take into consideration of the 4 bolts properly aligned on the seat? The force of the bolt from the U bend of the U-bolts and/or formed from either cold or hot work? Did it take into consideration of the axle housing bearing the clamping stress? Maybe a different material is used from what you assumed and the factory wanted a preload on the U-bolt which is why they tend to yield.Thats why people say to never reuse U-bolts. A preload of 20% of the yield is usually lost the sec you pull the wrench off the bolt through the bolt, nut and bolted members. People lives are at stake driving there vehicles so if I were you I would leave the torque values up to the manufacture.
    Not trying to scare you but I hear way to many scary lawsuits in this industry being on the design side of it all.
    KRAMERICA likes this.
  5. Sep 15, 2016 at 7:39 AM
    #185
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Pretty reasonable advice, follow the manufactures specs whenever available. If you don't have them, use the general spec sheet to for a bench mark so you don't over due it. Lord knows I've over torqued more than one bolt in my days with a wrench...
  6. Sep 15, 2016 at 2:39 PM
    #186
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I think you're mistaken - the confusion comes from the fact the Toyota FSM calls for the rear U-Bolts to be torqued down to 37 ft./lbs. - Thirty Seven!!!
    That's why so many of us raise a stink about it.
  7. Sep 15, 2016 at 4:06 PM
    #187
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    lol circle jerk conversation going on here. I understood @AP-Tanner 's post. He was posting some useful info... No harm in that.
    Regarding the leaf spring misprint... That has been debated for years. And it's kind of dumb at this point. Anyone who works with threaded fasteners in that size, and spring shops especially, will laugh their asses off at the 37 ft.lb It's an obvious error.
    AP-Tanner likes this.
  8. Oct 27, 2016 at 11:57 AM
    #188
    TacoSauceHB
    TacoSauceHB Well-Known Member
    Brian
    Rathdrum, ID
    2017 _TRD Off-Road DCLB 4X4 Tech Package
    King 2.5 ext travel, Camburg uniball UCA, SCS Ray10 wheels, 285/75/16 Cooper STT Pro's, CMC , MBRP exhaust, K&N cai , OVTune 1.05 , T-rex billet grill, Rigid DS Pro ditch lights, SDHQ ditch light brackets, Leer 100XQ Shell, ShmellFab Sliders, Victory 4x4 Roof rack, LED headlights. SOS Concepts bumper, Smittybilt X20 Winch, Nitro 5,29 gears, ECGS clamshell bushing.
  9. Oct 27, 2016 at 12:40 PM
    #189
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I think I might make a poster out of that for the garage
  10. Oct 27, 2016 at 12:47 PM
    #190
    TacoSauceHB
    Brian
    Rathdrum, ID
    I'm trying to figure out how to save it bigger and more clear. I'm about to upgrade all 4 shocks + more upgrades to front and back so Im planning on printing this big and hanging it in my garage also for easy reference while my hands are greasy.
  11. Oct 27, 2016 at 2:22 PM
    #191
    Crom
    Nick
    San Diego, CA
    Millions
    That is for a 2WD truck. Never noticed this before but for some reason that diagram, shows LCA cam bolts / nuts at 155 ft.lbf. Not sure why. The 4WD cams which I think are the same part are specd at 100 ft.lbf.
  12. Nov 5, 2016 at 6:14 PM
    #192
    louiemak
    louiemak Active Member
    Elias
    BOSTON, MA
    2014 TACO 2.7L L4 SR5
    AFE intake and Magnaflow cat back exhaust.
    Thank you for the information
  13. Nov 5, 2016 at 7:08 PM
    #193
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    A few things to take into account with U bolts.
    1 The specs are for the factory hardware, acceptable torque may change if hardware changes. I.e. Bigger bolts, or different grade.
    2 a properly installed bolt stretches some at the threads,assuming it is shaped right for the application and mates to the top plate or axle properly.
    3 for this reason do not reuse them after repairs.
    4. because of this You gotta take into account with U bolts that the nuts are pulling against each other, yes you re only measuring torque on one thread but they play against each other.
    5. bolt nuts tend to be deep, allowing for the thread stretching.
  14. Nov 12, 2016 at 10:22 AM
    #194
    Tdkrum5
    Tdkrum5 New TRD OR P
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR P
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
  15. Nov 12, 2016 at 1:23 PM
    #195
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
  16. Nov 12, 2016 at 2:18 PM
    #196
    Tdkrum5
    Ted
    2024 TRD OR P
    Thanks.
  17. Nov 19, 2016 at 3:33 PM
    #197
    Jakeytaco07
    Jakeytaco07 New Member
    Jacob
    2007 Automatic Toyota Tacoma 4x4
    Front and rear Road Armor bumpers with 4 PIAA lights on the front and 2 ridged LEDs in the back black fuel rims
    I've noticed that these specs don't have the actuator bolt torque in here does anyone happen to know what the specs are? -thanks :thumbsup:
  18. Dec 11, 2016 at 7:22 AM
    #198
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Benson, thanks for posting the torque guides. Having this on the iPad during my suspension install made all the difference.
  19. Dec 13, 2016 at 9:19 PM
    #199
    Tylertms
    Tylertms Member
    Tyler
    San Diego, CA
    2008 4D Long-Bed 4x4 Tacoma
    TRD Cold-Air Intake, TRD Exhaust, Goodyear Wrangler Duratrac Tires, 3" Lift, rear Fox shocks and Deaver Leafs.
    Does this also apply to a 2008 Tacoma prerunner 4x4?
  20. Dec 13, 2016 at 9:30 PM
    #200
    BudMan
    Bret
    06 TRD Sport DC 4x4
    stuff
    o_O
