The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. Sep 30, 2018 at 6:24 AM
    #261
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    It is a mistake. Someone suggested it was flipped and should be more like 73 ft lbs. I followed the torque chart and had driven my truck around with the u-bolts at 37 ft lbs after swapping leaf packs for a couple of days (nothing happened) but yeah frickin typos.....
  2. Nov 15, 2018 at 7:14 AM
    #262
    TacomaCZman
    TacomaCZman Well-Known Member
    San Antonio, Texas
    2022 Tacoma SR5 Pre-Runner 3.5L 4x2
    Getting ready to change spark plugs(first time for me on this vehicle). Was double checking on torque specs for coil pack bolts and spark plugs. Excellent post. Thank you!
    No problem loading here.
    Those first pics look like coil pack bolts. They don't take much tightening for sure.
  3. Nov 15, 2018 at 7:44 PM
    #263
    SJMTRD2015
    SJMTRD2015 New Member
    2015 Red Tacoma TRD
    This weekend I am changing the oil, front and rear differential and transfer case fluids in my 2015 TRD for the first time. Also adding SumoSprings to the rear axle, and SuperBumps to the front. I sat down tonight to research what torque settings for each of these, and one search later I find this great post. Tacoma World is truly a wonderful place!
  4. Dec 12, 2018 at 10:52 AM
    #264
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
  5. Feb 14, 2019 at 11:49 AM
    #265
    Hoangde
    Hoangde Well-Known Member
    Thanks for the info.
  6. Mar 5, 2019 at 9:46 PM
    #266
    safes0c
    safes0c Member
    2003 Toyota Tacoma Pre-Runner V6
    After years of lurking and referencing this thread, I finally created an account just to thank you.
  7. Apr 15, 2019 at 7:52 AM
    #267
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I'm replacing my lower control arms today, since the balljoints were preinstalled I just have to torque the castle nut (103 ft lbs), is it best to do this with the weight of the vehicle on it? That's my understanding for the LCA cam bolts, so I'm assuming I should torque everything once it's down.
  8. Apr 15, 2019 at 9:33 PM
    #268
    Tsinajinii
    Tsinajinii Black Wood Streak People
    Jamin
    AZ
    2011 DCLB 4x4 TRD Sport
    OME 885's paired to Bilstien 5100's, LR UCA's, OME Dakars w/ 5160's, Debadged Tailgate, TRD Stickers Removed, ARE Topper, Tailgate Theft Deterrent Mod, Mobtown Tailgate Skin, Light Bar in Hood Skewp, VIAIR OBA, Diaz Fabrication - T.H.R.B., Always on Cig. Outlet, BAMF behind the grill light mount with KC HiLites Pro Halogens, KC HiLites Flex ditch lights
    @Benson X you are a saint!
    I had a laundry list of things I did on my truck this weekend:
    • I had the front and rear diff’s out (regeared from 3.73 to 4.56)
    • Had the lower control arms off to service the ball joints
    • Swapped out the CV axles (leaky boot)
    • Installed the ECGS bushing
    When I was getting everything back together your post was a life saver. This gave me so much confidence when it was all coming back together.
    I wish “rep” was still around so I could send some your way!!
    Benson X[OP] and rollin904 like this.
  9. Apr 15, 2019 at 9:46 PM
    #269
    Tsinajinii
    Jamin
    AZ
    I think you should be fine to torque everything else down while you’re up in the air.
    My understanding is that you only want to torque the LCA bolts when your truck is under its’ own weight because the bushings of the LCA are going to be “locked in” once you torque them down, so you want to do it when the truck is at ride height in order to prevent placing a constant strain on the bushings.
    If the LCA bolts are torqued down when the front end is jacked up and at full droop the bushings will have a “home position” at full droop resulting in the bushings being constantly twisted when at ride height.
    I’m getting an alignment tomorrow and will be checking the LCA bolts when I get home. And having just done a gear swap, I am going to be draining & refilling the diff’s in 500 miles. When I do that I am also going to revisit every nut & bolt that I touched to make sure they are still torqued correctly.
  10. Apr 16, 2019 at 7:40 AM
    #270
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    I put some kind of ink/paint/etc mark on each bolt that's been touched on the truck after the factory and if possible write the torque spec next to it. Silver or gold metallic pens from Milwaukee are fantastic so is Sharpie's big white paint pen. On top of that keep a spreadsheet or highlight the torque values on the print outs from the FSM and keep it in a folder. This makes pre-trip and post-trip inspections a snap.
    /edit for wording
    Requital and Tsinajinii[QUOTED] like this.
  11. Apr 16, 2019 at 9:31 AM
    #271
    Tsinajinii
    Jamin
    AZ
    :boom:
    You just blew my mind, that's a great idea!
    I'm thinking I will need to employ some of these methods. :thumbsup:
  12. Apr 16, 2019 at 12:00 PM
    #272
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    i also mark a line on the nut to the mating surface so when you are on the trail/run its easy to see if you are are loosening.
    Requital likes this.
  13. May 20, 2019 at 11:05 AM
    #273
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Dude, such an awesome resource. Thanks for putting all this together!
  14. May 20, 2019 at 11:35 AM
    #274
    DrFunker
    DrFunker Well-Known Member
    Will be using this guide to torque a few bits and parts soon. :anonymous:
  15. May 26, 2019 at 11:10 PM
    #275
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Thanks for taking the time to assemble all this! So many links and info saved for future use. Suspension upgrade DIY coming up next month. I assume these values are still valid for 3rd gens?
  16. May 31, 2019 at 5:02 PM
    #276
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Ok so I’ve got a few questions. Tq for the hub bolts to the spindle is 59ftlbs, should be the same tq for maxtrac’s too, right? Also, is there any type of seal I need between the spindle surface, dust cover, and hub before installing? anyone else use Detroit axle brand prerunner hubs before?
    And lastly, 2wd hubs have that center cap installed, is it easier just to pop out the old one from the old hubs and install on the new hubs or can they be bought from dealership?
  17. May 31, 2019 at 5:10 PM
    #277
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    I installed a ready lift 2 inch rear block and the torque for the u bolts per manufacturer were 140 ft lbs.
  18. Jun 6, 2019 at 10:28 PM
    #278
    PapaBear
    Austin
    SIN CITY
    bump on this anyone know? ^^^^^
  19. Jul 4, 2019 at 9:31 AM
    #279
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    TACOVRD likes this.
  20. Jul 25, 2019 at 2:46 PM
    #280
    a0865251
    a0865251 Well-Known Member
    Patrick
    Dallas, TX
    2016 Black Tacoma TRD Off Road
    Still the best thread
    kidsmoke likes this.
