The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. Jan 28, 2023 at 1:15 PM
    #341
    retired_librarian
    retired_librarian Member
    Theo
    2006 Toyota Tacoma
    This is terrific, thanks so much!
    Black97v6MT and Benson X[OP] like this.
  2. Mar 11, 2023 at 10:42 PM
    #342
    bullpen58
    bullpen58 Well-Known Member
    Peoria, AZ
    2021 Tacoma PRO 4x4
    Lift, wheels, tires, sliders, and skidplates...so far.
    This is probably a dumb question but when doing a torque check on suspension components, is it necessary to raise the truck off the ground or can they be torqued with weight on the springs?
  3. Mar 12, 2023 at 1:56 AM
    #343
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Some request that the vehicle be on the ground
    bullpen58 likes this.
  4. Mar 12, 2023 at 4:56 AM
    #344
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Example: leaf spring / shackle attach bolts. Should be torqued with the vehicle sitting fully on the ground.
    bullpen58[QUOTED] likes this.
  5. Mar 12, 2023 at 10:24 AM
    #345
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    General rule of thumb, if it’s load bearing, torque on the ground esp if it has rubber bushings (ex - UCA, LCA, lower shock mount).
  6. Mar 12, 2023 at 10:29 AM
    #346
    smikski
    smikski Well-Known Member
    2016 4x4 2.7 - 3 pedals
    skid plates , leer cap , thule roof rack , tires 1 size up
    Thank you great information
    Benson X[OP] likes this.
  7. Apr 7, 2023 at 9:24 AM
    #347
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Z is ft./lbs.
    There is a legend key at the bottom of each diagram to show what the numbers are:
    H3llRid3r likes this.
  8. May 23, 2023 at 1:29 PM
    #348
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Helped me yet again. Thanks to everyone who has contributed
  9. Sep 18, 2023 at 3:23 PM
    #349
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Some items are missing from the 1st page. Let me know if I missed something and can we get a mod to add the images to the first post?
    2WD
    4WD and Prerunner
    Hook78 and Benson X[OP] like this.
  10. Sep 18, 2023 at 3:45 PM
    #350
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Good catch - you're the first person in 9.5 years to catch that! :thumbsup:
    Those image links were broken from when the diagrams used to be hosted on DropBox. I updated and re-linked them to my TW Media Gallery, so the images/diagram should be working now.
    :cheers:
  11. Sep 18, 2023 at 4:55 PM
    #351
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Had a mod day yesterday. I helped a friend replace his steering rack and saw the torque specs were missing so I had to add them.
  12. Jan 29, 2024 at 11:56 AM
    #352
    johnnytwotimes
    johnnytwotimes Well-Known Member
    SoCAL
    2021 TRD OR DCSB
    Torque specs for u bolts? I know it’s not 37 ft lbs can someone chime in?
  13. Jan 29, 2024 at 11:58 AM
    #353
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    It's been a topic of debate for years. 37 does seem way too low.
    I think the consensus is they must've transposed the numbers (should be 73 ft/lbs??) but I just tighten them down to about 80 ft/lbs, or 4-5 ugga-duggas and call it good.
  14. Jan 29, 2024 at 12:03 PM
    #354
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yep 73. Blame dyslexia?
  15. Jan 29, 2024 at 12:03 PM
    #355
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The 2021 FSM says to use 52 ft/lbs
  16. Jan 29, 2024 at 12:06 PM
    #356
    TnShooter
    Deogee
    STOCK
  17. Jun 10, 2024 at 7:37 AM
    #357
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
  18. Jun 10, 2024 at 9:27 AM
    #358
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I can't find them in the FSM guide.
    I did find the install PDF for the OEM Skid Plate (PT212-35075) which uses that same sub-assy piece(s) and stock bolts for installation.
    The install PDF (attached herein) lists the torque specs for those bolts at 21ft/lbs.
    TnShooter likes this.
  19. Jun 11, 2024 at 4:28 AM
    #359
    Black97v6MT
    iMA0
    tacoLand USA
    is there a spec manual that an autobody tech might use?
    perhaps it is listed in something such as that?
  20. Jun 11, 2024 at 6:57 AM
    #360
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    @super_white Harry might be able to help with this......Tagging him
