The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. Jun 11, 2024 at 8:33 AM
    #361
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I’ll have a look when I get home. Far too busy to do it during work.
    crashngiggles[QUOTED] likes this.
  2. Jun 11, 2024 at 10:36 AM
    #362
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I looked again and was unable to find that specific "sub-assy." part listed.
    The stock skid plate bolts up to those cross-member braces, so the torque for the skid plate will be the torque for those pieces.
    Take a look at these diagrams and you'll see the torque spec listed @ 22 ft/lbs for all the bolts that connect to the sub-assy. braces:
    One the attached PDF - page 11/16 shows the Sub-Assenbly* and bolt that connect to the sub-assy. pieces you're asking about.
    Black97v6MT[QUOTED] likes this.
  3. Jun 11, 2024 at 10:57 AM
    #363
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Here is a pic of how big the bolts with washers are
    Perhaps Frame and lower radiator support section?
  4. Jun 11, 2024 at 11:57 AM
    #364
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Sorry dude - perhaps someone with better resources or a searchable FSM will have better luck than myself.
    I checked all the Radiator, Front Bumper assy., Suspension, Exterior and Engine assy. guides and could not find those specific brace pieces listed anywhere. There are over 1,400 individual pages in the FSM with no easy way to search through without opening each page.
    You could also measure the bolts and cross-reference any marks on the bolt head to determine what "class" it is using the attached FSM guide, then set your torque settings on the class rating. From what I could find (so far) with the skid plate diagrams, I'm guessing you'll be between 20-25 ft/lbs (which is not a lot).
  5. Jun 11, 2024 at 2:24 PM
    #365
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That torque isn't listed in the collision repair manual.
    What is he looking for exactly?
  6. Jun 11, 2024 at 2:37 PM
    #366
    Black97v6MT
    iMA0
    tacoLand USA
  7. Jun 11, 2024 at 4:02 PM
    #367
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  8. Jun 11, 2024 at 4:50 PM
    #368
    Black97v6MT
    iMA0
    tacoLand USA
    Thank you much!
  9. Jun 12, 2024 at 11:07 AM
    #369
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Awesome - thank you for digging that up, Harry!
  10. Jul 15, 2024 at 5:31 AM
    #370
    Black97v6MT
    iMA0
    tacoLand USA
    i just watched a how-to video on steering rack replacement where the front suspension member braces sub-assy had to be removed to get the rack out and back in
    perhaps the torque #s for that brace is located within the FSM instructional for the rack replacement :confused:
    nevertheless i did get it back together properly thanks to everyone help
    TY!
    Benson X[QUOTED][OP] likes this.
  11. Aug 16, 2024 at 6:30 PM
    #371
    Maffee88
    Maffee88 Active Member
    Michael
    Calimesa, CA
    2018 Tacoma SR5 DCLB
    3" Bilstein 6112 and AAL 265/70/17 OVTune and CGS Exhaust
    Thank you for this! It made it easy for me to torque my lower ball joint bolts!
  12. Aug 22, 2024 at 7:10 PM
    #372
    OME20
    OME20 New Member
    Thanks for this useful thread
  13. Sep 18, 2024 at 5:32 PM
    #373
    Lakeabilene
    Lakeabilene New Member
    Why is the simple brake caliper bolt torque so hard to find anywhere? I have a 2007 Tacoma with 2W drive, four cyl. basic truck. The torque spec that are for a 2006 model are here on the site, but look, it shows 80 ft/lbs for the caliper bolts. These are two small bolts with 14 mm heads. No way they get 80 pounds.
  14. Sep 20, 2024 at 6:40 PM
    #374
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
  15. Jan 10, 2025 at 2:03 PM
    #375
    Project4
    Project4 New Member
    David
    2013 TRD Sport
    Sketchy 3 inch suspension lift and 33 inch tires previously installed. I am returning the vehicle to stock.
    Thank you Benson X. I just finished removing all the components of a sketchy 3 inch suspension lift kit and am now reassembling the truck as completely stock.
  16. Apr 27, 2025 at 1:26 AM
    #376
    Trove Rover
    Trove Rover New Member
    Michelle
    2014 Toyota Tacoma
    OME 3” lift, decked system, Leitner ACS rack, RTT, rear power bank, lights, Genesis dual battery system.
    Great info! Thanks for sharing!:thumbsup:
  17. May 8, 2025 at 12:41 PM
    #377
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Doing some work on my truck the past few days and was trying to search for things. So here is an OCR'd text searchable version.
    BRFab likes this.
