The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. Mar 17, 2014 at 5:54 AM
    #41
    Large
    Large Red
    DF42 & DF67 are the same rear axle (e-locker rear), DF68 & DF69 says with rear e locker but it (the pic) doesn't have one.
  2. Mar 18, 2014 at 7:54 AM
    #42
    DirtyTaco24
    DirtyTaco24 Well-Known Member
    Greg
    Ottawa
    '12 TRD DCLB Black
  3. Mar 18, 2014 at 3:25 PM
    #43
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Yup, that what I gathered from it as well. I think Toyota just screwed up with the Page/Chapter names. Same as with the U-Bolt Torque Spec. = 73ft. lbs NOT 37 :)
  4. Mar 19, 2014 at 6:22 PM
    #44
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Great info, thank you for sharing!!!
  5. Mar 19, 2014 at 6:24 PM
    #45
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    I was just going to mention this too. I wouldn't feel safe torquing them down to 37 ft lbs. On a 2007 Tundra, it took like 90 something ft lbs of force to move the nut on the u-bolt so 73 sounds better.
  6. Mar 19, 2014 at 6:26 PM
    #46
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Looks like I have a lot of crap to re-torque
  7. Apr 2, 2014 at 10:15 PM
    #47
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Great thread OP .....:thumbsup::thumbsup:
    Just curious as to any updates or changes in specs. The Ubolt torque is what I'm getting at, does the FSM still say 37 ft lbs ??
  8. Apr 2, 2014 at 10:36 PM
    #48
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    Sub
  9. May 6, 2014 at 7:22 PM
    #49
    Bee22971
    Bee22971 Well-Known Member
    Garth
    Sacramento
    2011 DC TRD
    King 2.5 C/O, DSM UCAs, all pro leafs, and AllPro Sliders
  10. May 7, 2014 at 7:07 AM
    #50
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    nope
    that is the correct Torque....37 for u-bolts
    there is no printing error in Toyota u bolt specifications
    if it was, they also got newtons and kg incorrect for the same amount of force
    also been researching techinfo.toyota.com and the U-bolt spec is
    exactly what is stated.
    If you get TSB 0008-14 done it goes up to 44ft/lbs
  11. May 7, 2014 at 8:16 AM
    #51
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    As I've stated before, I don't give 2 shits about what "the experts" at Toyota say or print about it , anyone who thinks 37 ftlbs. (or 44) is enough torque to hold a 400lb+ axle assembly to the rest of the truck is a fool...
  12. May 7, 2014 at 8:48 AM
    #52
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    I understand that.
    it is a setting that
    a) safely holds the vehicle together and
    b) provides the ride quality toyota wants for a specific setup
    sure it is pretty low setting. I cranked mine to 80 before getting a vibe tsb
    done and it reduced the vibe a bit...
    but jus sayin...37 or 44 not a typo or error. intentionally done by toyota
  13. May 7, 2014 at 8:55 AM
    #53
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    & consider this... up to 2004 (end of 1st gen production) The FSM states clearly that the torque for Ubolts is 90ftlbs.
    In 2005 the 2nd gens began....
    Now you tell me what technological break through in Ubolt technology occurred that would REDUCE the recommended amount from 90ftlbs. all the way down to 37ftlbs. ?? Does this make any sense to anyone ??
    Also keep in mind that 1st & 2nd gen. Ubolts/hardware are the same....
    & lastly , this vid shows that they aren't tight AT ALL....
    http://www.youtube.com/watch?v=X8Sg8dCtXnI&feature=player_detailpage#t=14
  14. May 7, 2014 at 9:47 AM
    #54
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    this thread is torque specs, right ?
    the actual toyota engineering specs say one thing, 37 or 44 depending on the
    2005-2014 u bolt and flange nuts installed
    everyone is free to throw in your own deviations from the specs however you want....the ubolt diameter is beef enough to crank to 80 without issue, so go ahead. it makes the ride a bit stiffer by acting as a spring compressor
    Now if everyone followed the -->actual Toyota maintenance manual<--, it states that when going off-road you tighten the chassis nuts and bolts DAILY. If you did this then the ubolt 37 or 44 spec is a non-issue. Otherwise you check every 5000 miles. Skip this at your own peril. There is nothing inherently wrong or dangerous with the spec or the maintenance schedule when done correctly. You want them to stay tight forever so you never have to check then whang them down to 80 or 90...but specs are specs and this is what it is. 90 to 37 is safe.
    I just got done with discussing all this rear leaf spring and related bits with Toyota engineering in California to get a full understanding of everything related to driveline and rear suspension and how and why toyota does things. There is no error in the docs. that is all I am saying...not a typo so please stop calling it a typo or ridiculous. it is a setting carefully thought out by people who build and then crash these vehicles, and they know a lot about it. I cannot answer from a vehicle engineering standpoint on every last bit of this...but bottom line a soft setting is not harmful or dangerous and it improves ride quality. crank them down all you want, it stiffens the leafs a bit.
  15. May 7, 2014 at 10:01 AM
    #55
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Great info. and thanks for doing the research and citing sources. As well all know, the U Bolt torque specs (according to the FSM) have been a topic of debate for years across every forum (pirate4x4, ttora, customtacos, toyotanation, IH8MUD etc.) and the general consensus is that 37 (even 44) is way too low as compared to 99% of leaf spring u-bolts.
    While the FSM and TSB show that to be the correct torque, it is at the discretion of the owner/mechanic to use those specs. As I stated previously, and linked to the OME/Dakar install guide from (reputable Toyota enthusiasts) Slee Offroad they advise to torque to 89ft/lbs, which is what I did since I do have Dakar leafs and aftermarket U Bolts.
    I didn't print the FSM and I am not an ASE certified Toyota mechanic, nor do I claim to be. I may have been too hasty to "assume" that it was indeed a misprint or error, but I will continue to torque my U Bolts to 80+ ft/lbs, as will about 99% of 2nd Gen owners who have serviced their own leaf packs.
  16. May 7, 2014 at 10:11 AM
    #56
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No offense but theres so much fail in your statements dont know where to start..
    Hahaha, ok dude, you go with you're "Toyota engineers" & I'll stay on the side of commonsense & logic... This isn't my first rodeo with Toyota Ubolts, I've R&R'd probably 150 truck axles in the last 2 years alone, most are 2nd gens. & how can you say tightened/torqued Ubolts are going to make the ride stiffer?? Your springs are afixed to the perch on axle, your springs aren't cycling on the perch, how is this compressing the spring ??
    So what was the answer you got from Toyotas people other than you saying "specs are spec. , they're right just do it." ??
    No, I think you should go with the info you get from the same people that bring you the same TSB's year after production year, at your own peril of course..
  17. May 7, 2014 at 10:13 AM
    #57
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    & sorry Benson , I wont turn it into a pissing match...;)
  18. May 7, 2014 at 10:23 AM
    #58
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Lol, no apologies needed Doug. :)
    I just wanted to clear my name, since I was the one who stated it as "fact" that it was a typo ;)
    Still, my question remains about the Rear Diff. Diagrams (E-locker vs LSD) why they show different diagrams and exploded parts views. To me, that seems like a definite misprint/typo/error on Toyota's part.
  19. May 7, 2014 at 10:40 AM
    #59
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Maybe because they're different ??...:notsure: just throwing it out there..haha, i haven't looked at the diagrams you speak of but pretty sure a major difference is the Elocker is mechanical locking & the LSD is a torque/pressure within the diff. type of app IIRC So I'd expect to see some differences if I'm understanding you right..
  20. May 7, 2014 at 10:45 AM
    #60
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Oh they're different?!?! J/k j/k.
    My concern is that in the FSM, the diagram they show for the E-Locker is actually for the LSD diff and vice-versa...no biggie. Just wanted to point out the error to avoid confusion.
