The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. May 7, 2014 at 10:57 AM
    #61
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the ubolts are essentially an additional clamp
    when the leafs bend they slide along the entire length against each other, however slightly they still slide (bookleaf style) except directly at the centering pin. even 1/4 inch away from the pin there is some slide, very tiny amount....
    and if you tighten the bejeesus out of the ubolts the springs will slide against each other less, due to friction, making the whole assembly a bit stiffer. it ain't much stiffer but it is stiffer
    How did I speak to toyota california ? before I got a TSB done I spent time riding around in 2013 and 2014 tacomas with the shop foreman at a large dealership who wanted to know more from toyota California before he does my TSB, so we set up a webex meeting (dial-in) and we three spoke about everything on the new TSB and I brought up the low 37ft and 44ft lbs ubolts. The engineer said it is a non-issue and meant to be that way. He also said regarding the new TSB reports are coming back from the field that it is fixing some vehicles so that was the go-ahead to do mine. and ....that is the story
  2. May 7, 2014 at 2:56 PM
    #62
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Do you even read what others post ?? Your still out of gas with what you post as facts, oh well not going to debate you here... I'll do it here..
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/222674-ubolts-under-torqued.html
  3. May 7, 2014 at 9:04 PM
    #63
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Ahh, ok got it now ..i was a little confused.. still a great thread....
  4. May 26, 2014 at 5:22 PM
    #64
    Tbryson2
    Tbryson2 Well-Known Member
    Terry
    Central Florida
    05 PreRunner SR5
    The links to the pdf's are broken. Any other way to get the pdf's?
    Thanks for your efforts!
    TB
  5. May 27, 2014 at 12:29 AM
    #65
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Fixed the link. Thanks for the heads-up! :)
  6. May 27, 2014 at 6:09 AM
    #66
    Large
    Large Red
    I'm pretty sure chris4x4 called/emailed Toyota corporate and they told him it was a typo, I will find the post I read that on.
  7. May 27, 2014 at 6:24 AM
    #67
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    sub'd for further use
  8. May 27, 2014 at 7:12 AM
    #68
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    would like to see this, as all current docs are the oddly low-ass number
    I go to techinfo and can clearly see myself the gen1 settings are 'normal' (very tight) and gen2 suddenly low
    maybe it has to do with springs snapping in half from old-age ?
    anyhow stock still shows 37...and TSB 0008-14 shows 44ft lbs
  9. May 27, 2014 at 8:13 AM
    #69
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    Holy cow, great thread, thanks!
    Rear u-bolts are really 37 ft/lbs? dang, that seems like not much.
    I think the Land Cruiser spec is more like 65ft/lbs?
    I was looking for wheel to vehicle toruqes and see 83 ft/lbs, but see not spec quoted for alloy vs steel wheels? Is that right?
  10. May 27, 2014 at 9:32 AM
    #70
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    alloy 83 is correct and that is fine for steel too
    as a general rule for light duty trucks and cars 80 is where to set lug nuts
    steel or alloy...
    then re-check after a tank of gas or so....
  11. May 27, 2014 at 9:59 AM
    #71
    AlanLoshbaugh
    Alan
    Columbia, MO
  12. Jul 2, 2014 at 5:49 PM
    #72
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    sub'd for future reference. Thank you!
  13. Jul 2, 2014 at 5:55 PM
    #73
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    Subd...thanks for gathering the info OP
  14. Jul 7, 2014 at 3:36 PM
    #74
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Just a reminder to everyone...if you don't want to scroll through the whole OP, there is a LINK at the top to download a .PDF version that has a Table of Contents to quickly navigate to the section you need. Just make sure you download it rather than viewing it in Google Docs. :thumbsup:
  15. Jul 7, 2014 at 3:41 PM
    #75
    Manwithoutaplan
    ID
  16. Jul 25, 2014 at 11:09 PM
    #76
    eja12a
    eja12a Well-Known Member
    Ethan
    Tennessee
    2014 DCSB SR5 4x4
    OME Lift, LR UCAs
    this is awesome. thanks for putting the time in to do this
  17. Jul 26, 2014 at 10:24 AM
    #77
    Large
    Large Red
    Been using this for everything recently and has helped tremendously. Thanks again Ben
  18. Jul 31, 2014 at 4:03 PM
    #78
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Did you ever find out if the 37 lbs for the u bolts were correct?
  19. Jul 31, 2014 at 4:05 PM
    #79
    Large
    Large Red
    Even if it wasn't a typo and even if it is a typo I would still put 80 lbs on the u-bolt nuts. 37 ft lbs is rediculous.
  20. Jul 31, 2014 at 4:12 PM
    #80
    cstallings
    Arkansas
    I put 90 or 100...can't remember. My dakars started squeaking so I decided to find the torque specs since I didn't have them the day I installed.
