The Torque Spec. Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Mar 1, 2014.
  1. Mar 9, 2016 at 5:51 PM
    #161
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I snapped off a wheel lug last weekend , most likely do to over torqued wheel lug nut. I didn't use a torque wrench.used my impact gun. Then just muscle to insure tight.when I removed it , it was stuck, well. With a little force it snapped.
  2. Mar 9, 2016 at 6:24 PM
    #162
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    If you stretched one you probably stretched them all. I had had four out of five lugs on an old Toyota pickup snap while driving within a few seconds of each other due to being over tightened. Thankfully I was going slow and it happened right at my house. Personally, If I were you I would replace all of them.
  3. Mar 12, 2016 at 3:06 AM
    #163
    Rattlejay65
    Rattlejay65 Well-Known Member
    J.R.
    2015 Tacoma TRD Off Road
    Thank you so much. Very helpful info!
  4. Mar 27, 2016 at 12:15 PM
    #164
    the taco crna
    the taco crna Well-Known Member
    Tim
    South Texas
    2016 Quicksand TRD OR 4x4 AC
  5. Mar 30, 2016 at 9:12 AM
    #165
    jasonct
    jasonct Well-Known Member
    CT
    2021 F150, C7 Grand Sport
    Thank you very much!
  6. Apr 13, 2016 at 10:54 AM
    #166
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  7. Apr 13, 2016 at 12:03 PM
    #167
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I noticed you put me on the list, i never said i wanted on the list. I only said i wish i didnt just spend $2200 on gears and locker.
    I would love to buy one at this price but i just dont have the funds.
    Crom likes this.
  8. Apr 13, 2016 at 12:35 PM
    #168
    Sandman614
    Tim
    '06 SR5 Off Road
    something for sale here lol?
    DrFunker and Crom like this.
  9. Apr 13, 2016 at 1:11 PM
    #169
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    :rofl:
    DrFunker and Sandman614 like this.
  10. Apr 16, 2016 at 10:14 PM
    #170
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Oops wrong thread.
    Crom likes this.
  11. Apr 27, 2016 at 3:11 PM
    #171
    pdederko
    pdederko Member
    Peter
    2015 Tacoma PreRunner SR5 Access Cab
    I just got back from the dealer to have my U joint torque specs checked, and they tightened to 65ftlbs. The center support bearing to 27ftlbs. Hope this helps you guys out. I was just reading about this yesterday and made an appointment for this morning; glad I did.
  12. Apr 27, 2016 at 3:16 PM
    #172
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Nice post, great to have it all together!
    pdederko likes this.
  13. Apr 27, 2016 at 6:14 PM
    #173
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    By u joints do you mean the bolts that hold the driveline to the pinion flange? I just swapped my diffs so im curious. U jionts themselves dont have anything to tighten as far as i know.
  14. Apr 27, 2016 at 9:42 PM
    #174
    pdederko
    pdederko Member
    Peter
    Rear U bolts that hold suspension links to the axle.
  15. Apr 28, 2016 at 8:21 AM
    #175
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Oh, u bolts , not u jionts. And i think you mean leaf springs not suspension links. Terminology is key as thise are completely different things.
  16. Apr 28, 2016 at 8:38 AM
    #176
    pdederko
    pdederko Member
    Peter
    Yes, you're correct. The U bolts holding down the axle to the leaf springs. Thanks for clarifying.
  17. Jun 21, 2016 at 6:04 AM
    #177
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
  18. Jul 2, 2016 at 6:33 AM
    #178
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    goblue82 likes this.
  19. Jul 12, 2016 at 7:21 PM
    #179
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    As pointed out by @Chickenmunga, there were no diagram(s) or detailed torque specs for the Power Steering components. I updated the OP to include the Power Steering Diagrams for 2WD and 4WD - thanks for the heads-up Mike!
    :cheers:
    Also, @tcBob must've increased the attachment size limit on the (new) forum - so I was able to add the updated .PDF file here and at the bottom of the OP!!! Rejoice!!!
    :yay:
    Crom and tcBob like this.
  20. Jul 12, 2016 at 8:15 PM
    #180
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    oh nice, those are better pictures than the ones I had found
