The Truth About Spark Plugs....
Discussion in 'Technical Chat' started by chris4x4, Apr 20, 2011.
  1. Apr 20, 2011 at 8:10 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thought you all should read this.
    Another thing that wasnt mentioned, Electircity follows the path of least resistance. So, "E", "V", etc. plugs STILL are only going to generate 1 spark.
    Recomended plugs:
    First gen.
    2RZ-FE & 3RZ-FE engines:
    Denso K16R-U11
    NGK BKR5EYA-U
    Gap .043"
    5VZ-FE engine:
    Denso K16TR11
    NGK BKR5EKB-11
    Gap .043"
    Second gens:
    2TR-FE engine
    Denso SK20HR11
    NGK ILFR6C11
    Gap .039" to .043"
    1GR-FE engine
    Denso K20HR-U11
    NGK LFR6C-11
    Gap .039" to .043"
  2. Apr 20, 2011 at 8:19 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Damn good info! I'll be replacing mine this weekend, thanks Chris!
  3. Apr 20, 2011 at 8:20 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  4. Apr 20, 2011 at 8:22 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    Where did you find this?
  5. Apr 20, 2011 at 8:26 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Nice!!!
  6. Apr 20, 2011 at 8:56 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I agree with everything except
    Hmmm I dont know about this. He is recommending AC, Motorcraft as more reliable then "other guys" ?
    AC Delco and Motorcraft are $hietest spark plugs person can buy. And I mean if there was award for crappiest quality spark plug those two would probably get it every year. Thats my experience with them.
    Dwb212 likes this.
  7. Apr 20, 2011 at 8:58 AM
    mjp2
    NJ
    What specific issues have you had with them relative to other brands?
  8. Apr 20, 2011 at 8:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im sure its his opinion for his application. I doubt he is recomending them for Toyotas.
    Csmith1999 likes this.
  9. Apr 20, 2011 at 9:01 AM
    medic2230
    Murph
    Bama! Roll Tide
    I put the toyota platinum ones in mine and the damn thing is skipping now. Should have just gotten the cheapo $13 originals.. :(
  10. Apr 20, 2011 at 9:10 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Good info!
  11. Apr 20, 2011 at 9:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What was the gaps? Did you make sure the coil packs were installed securly?
  12. Apr 20, 2011 at 9:17 AM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    It doesnt matter how many reviews and data there is, people still wont believe it. Just about everyone on TW says you MUST use the dual electrode plugs or your tacoma will get 2mpg and may possibly explode. BS
    I bought the NGK copper plugs that were on sale. Work great, no mileage or performance issues whatsoever.
  13. Apr 20, 2011 at 9:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For the first gens, the ignition is designed to be used with the dual electrode plugs. Best performance is achieved with these. Some have had issues useing single electrode plugs, while some havent.
    Jimmyrace and Csmith1999 like this.
  14. Apr 20, 2011 at 9:20 AM
    medic2230
    Murph
    Bama! Roll Tide
    Going to pull them and check the gap. Coil packs were on good. Got me???? It didn't start till I put them in.
  15. Apr 20, 2011 at 9:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    may have a bad plug. Worst case, Swap in the OEM Denso's
  16. Apr 20, 2011 at 9:26 AM
    scocar
    scocar hypotenoper
    Is this an attempted pre-emptive strike on all the retarded spark plug threads that haven't yet been (but inevitabely will be) posted?
    No offense meant to the retards.
    Oh, while I am at, should I change my synthetic oil every 3,000 miles?
    OK, on a more serious and constructive note, since this is a sticky, you may consider adding the stock spark plug models/numbers for all the Tacoma engines, since I imagine you can proabably do it off the top of your head in about 2 seconds.
    That is, if you aren't too busy or something, like chasing off OZ or deleting "I am asshurt and sicking my lawyers on TW" threads. Or making virtual sammiches. Sir.
    cruiserguy likes this.
  17. Apr 20, 2011 at 9:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I might, But all that info is in everyones owners manual.
    Jimmyrace, Csmith1999 and Stryker420 like this.
  18. Apr 20, 2011 at 9:31 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    :anonymous: I like the plugs that are $30 each with diamonds and gold and titanium to make them lighter weight for better weight saving performance, higher HPs (whatever those are) and more MPGs (like a Prius!).
    JK. I get 6 stock NGKs from the dealership and they work flawlessly!
    Speedo and cosmicfires like this.
  19. Apr 20, 2011 at 9:37 AM
    scocar
    scocar hypotenoper
    Yes, but there are lots of first genners who buy used trucks that didn't come with the OM (because I have responded the same way to similar questions, from octane to grease type to capacities).
    Just a thought. I won't even mention "search." That's just too hard.
    jim1234 likes this.
  20. Apr 20, 2011 at 9:42 AM
    Lord Micron
    Lord Micron Montani Semper Liberi
    Dorsey
    MD/WV
    07 TRD Sport DC/Short
    Grillcraft Upper, Lower and Side-Vent Grills, Anzo Blacked Headlights
    Good read, which pretty much covers common sense!
    Though something of note that I've dug into since I'm in need of a plug change soon:
    Enerpulse, makers of Pulstar, who proclaim everywhere they're Made in the USA may have been made in New Mexico at one point... now they've just dropped the "New" and have Autolite make them south of the border. Their proclaimed Sandia National Laboratories collaboration has yet to be quantified... They claim it was spurned from Z-Machine research, which Sandia's site says nothing of their collaboration -- And everything they try to make claims of falls directly in the snake oil category. :crapstorm:
