The Truth About Spark Plugs....
Discussion in 'Technical Chat' started by chris4x4, Apr 20, 2011.
  1. May 4, 2018 at 12:17 PM
    #201
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Thanks for the reply! I cannot seem to find denso copper spark plugs anywhere.. anyone have a source?
  2. May 4, 2018 at 12:21 PM
    #202
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Everyone says that the coppers work better. My Butt Dyno couldn't tell any difference in running Iridiums and I don't have time to change coppers every 30k.
    jsi likes this.
  3. May 4, 2018 at 12:25 PM
    #203
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    scocar likes this.
  4. May 4, 2018 at 12:41 PM
    #204
    scocar
    scocar Patron of the Farts
    In going there, I found this helpful info on resistor plugs, of which the K20HR-U11 (1GRFE) is. It provides insight as to why some other plugs that fit may cause other issues. Also note that the ground electrode has a distinctive U channel. I have no idea why (but I imagine its engineers do), but this feature may also be lacking on some aftermarket Neat-O plugs.
    At the moment the spark jumps the gap it causes a high frequency burst of energy, known as RFI (radio frequency interference). RFI, as its name suggests, creates static on your radio and interference with other electronic equipment, including the vehicle’s on-board electronic control units (ECUs).
    Resistor plugs were developed in the 1960s to suppress some of the spark energy, thus lowering RFI to an acceptable level. Most resistor spark plugs use a monolithic resistor, generally made of graphite and
    glass materials, to filter the electrical voltage as it passes through the center electrode.
    Since resistor type plugs actually “resist” some of the spark energy, non-resistor type plugs actually deliver a more powerful spark. It is for this reason that most racing plugs are non-resistor types. However, in most automotive applications, a resistor plug is required for proper vehicle operation. Use of non-resistor plugs in
    vehicles that call for a resistor type can result in rough idling, high-rpm misfire, and abnormal combustion.
  5. May 4, 2018 at 1:41 PM
    #205
    BillsSR5
    bill
    2014 SR5
    I think thay are called U Groove(standard copper core plugs) my 3.4l always ran better I thought using the standard denso copper core dual electrode
  6. May 4, 2018 at 2:01 PM
    #206
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    What part number did you use if you dont mind my asking?
  7. May 4, 2018 at 2:02 PM
    #207
    scocar
    Yep, U groove:
    Denso 3381 K20HR-U11 U-Groove Plug
    • U-Groove Ground Electrode
    • Copper Core
    • Machine Rolled Threads
    This is for the 1GRFE, not the 5VZFE, which is dual electrode.
    Norton, BillsSR5[QUOTED] and DoorDing like this.
  8. May 4, 2018 at 2:04 PM
    #208
    scocar
    DoorDing likes this.
  9. May 4, 2018 at 2:09 PM
    #209
    scocar
    Frankly, I didn't realize (or remember) plugs were due at 30k until I checked my list the other night. I was pulling out tools and stuff last night to get ready to hit it hard and fast Saturday. I also blew by the cabin air filter at 20k, even though I had it in the garage with the intake filter, and clearly could have used a change at 20k. Lots of brain farts lately. This will be the first plug change on the 15. Fumoto will allegedly arrive Saturday via USPS, but who knows? USPS certainly won't.
  10. May 4, 2018 at 2:17 PM
    #210
    scocar
    I just bought a case (10) of D3 filters, and I still have bags full of useful crush washers from the 1st gen diffs etc. that will work on the 2015. Bought 4 gallons of Pennzoil Ultra a few months ago too. 5 quarts is such a pain. Also grabbed a bottle of Toyota ATF when I was at the dealer getting plugs. Just because.
  11. May 4, 2018 at 8:14 PM
    #211
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Thank you! Just ordered a set of 6 and a 5/8 spark plug socket from advanced for 25 bucks! Whats the consensus on using antiseize on the new plugs, and does anyone have any tips on removing the plugs if they are stubborn?
  12. May 4, 2018 at 11:31 PM
    #212
    scocar
    https://www.tacomaworld.com/threads/spark-plug-makers-say-no-anti-seize.175558/
    In that discussion, you'll find many varying opinions. It was interesting to see the manufacturers recommend against it. I use a very sparing amount of the aluminum type antisieze. Some people like to get long life plugs. I think it's a better practice to replace them routinely to reduce any chance of seizing and for the sake of reading the plugs to check the condition of each cylinder and any arising issues, moreso in higher mileage engines. It is a valuable glimpse of what's going on inside. It's also a chance for general inspection and discovery for any system sitting on the top end.
  13. May 7, 2018 at 6:20 PM
    #213
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I put Iridiums in 50,000 miles ago. I did pull them at around 30,000 just to check them out and because I didn't have a torque wrench when I installed them. In any case, I may go back to the copper for the exact reasons you stated. Not only that, copper is the best conductor out there.
    fökai671 likes this.
  14. Jul 1, 2018 at 12:00 PM
    #214
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    I am shopping here... so, what brand spark plug do you use? Assuming you are 1GR-FE engine. Thanks!
  15. Jul 2, 2018 at 8:06 PM
    #215
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    denso same part number as I pulled from 1/2 my motor
    dborrer[QUOTED] likes this.
  16. Aug 16, 2018 at 4:47 PM
    #216
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    Not sure if mentioned in previous pages but it's not on the main post! What is the part numbers for the 3ed gen plugs!
  17. Aug 17, 2018 at 5:36 AM
    #217
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    look in the owners manual online or in your glove box
    here
    I'll google it for you....
     2TR-FE engine DENSO FK20HR-A8  2GR-FKS engine DENSO FK20HBR8
    scocar likes this.
  18. Aug 17, 2018 at 2:16 PM
    #218
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    What about the NGK?
  19. Aug 20, 2018 at 12:41 PM
    #219
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    where in my post do I mention NGK ? I don't.
    Toyota builds them with 50/50 ngk/denso but they service/replace them strictly with denso
    if you want to deviate from the owners manual and dig up the NGK part number, fine,
    it's the same functionality
    find a search engine in the web and look it up
  20. Aug 20, 2018 at 4:07 PM
    #220
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    OP post provided part numbes for denso and NGK for every engine on Gen 1 and gen 2 but not the gen 3, it will be a good idea and Resource to add.
    I could go to the dealership and just pay whatever for their spark plugs but I prefer to get the exact same denso or NGK equivalent for a bit cheaper.
    Sorry I didn't think owners manual will have anything but the Toyota part number MY BAD!
    Not many people have changed their plugs on the 3ed gens yet and the search function brought me to this thread!
    If It's too much for you to answer a question without being an ass Than you should probably just navigate away.
