The Truth About Spark Plugs....
Discussion in 'Technical Chat' started by chris4x4, Apr 20, 2011.
  1. Apr 11, 2012 at 10:13 AM
    #81
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    ColtsTRD ran those, then switched to the OEM Nickle/Copper plugs, and the OEM Nickle/Copper ran smoother, and seemed to have more "pep".....
  2. Apr 11, 2012 at 10:15 AM
    #82
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I just switched mine out the other day. They were at .55 gap. Whoops...
  3. Apr 11, 2012 at 11:02 AM
    #83
    scocar
    scocar Patron of the Farts
    Did you remember to pour coolant into the cylinders before you put the new plugs in?
  4. Apr 11, 2012 at 11:45 AM
    #84
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only use coolant with Iridium/Laser plugs. Window washer fluid works on the OEM Copper/Nickle plugs...
  5. Apr 11, 2012 at 12:07 PM
    #85
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I went one step further and just shit in the combustion chamber.
    Jimmyrace, Micbt25 and Stryker420 like this.
  6. Apr 11, 2012 at 12:08 PM
    #86
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Be sure to pound it in with a hammer....
    Stryker420 likes this.
  7. Apr 11, 2012 at 12:10 PM
    #87
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Jack right?
  8. Apr 11, 2012 at 12:13 PM
    #88
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    i got a first gen 4 banger and i use NGK and gap it .032
  9. Apr 11, 2012 at 12:38 PM
    #89
    scocar
    Alternatively, use some Mobil 1 stool softener and let it sit overnight.
  10. Apr 11, 2012 at 12:54 PM
    #90
    oldstick
    oldstick Medicare Member
    GA
    Interesting thread. A spark is a spark that's true. Regarding the AC and Motocraft plugs, I can't explain why, but I swear this happened.
    I put new plugs in an '84 Isuzu Trooper one time. It was running fine, bu I think it was around the time the "new super platinum" plugs were getting popular. They had Bosch platinums on sale so the guy looked up the model and gave me a set of 4.
    Ran smooth for a few days then started skipping. Pulled the plugs out and several had a big ball of brownish carbon on the tip. Cleaned and put them back in. A week later, same thing. So I grabbed some old Motocrafts I had lying around and put those in. Never had another problem after that for years.
  11. Apr 29, 2012 at 6:59 PM
    #91
    WiscTaco
    WiscTaco Well-Known Member
    Wisconsin
    Sr5 Trd 23.42 mpg
    Grey Wire, AFE Pro Dry S
    Just replaced the spark plugs in my 3.4L with Denso K16TR11. So far no complaints, however I did have a "D'oh" moment when I went to put on some new NGK 4412 wires. I failed to take note of where those handy wire clips were specifically located. Just a quick peek at the old ones helped narrow it down, but a pen and paper would have been even faster.
    Side question. I assume everyone uses anti seize on the spark plug threads. What is everyone's feeling about dielectric grease on plugs and connectors? Is this something where a little goes a long way, or more the merrier?
  12. Aug 15, 2012 at 9:00 AM
    #92
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    Heys Guys,
    Just what I know. I have a '82 Harley FXRS that I bought new that I had a problem with the back cylender gas fouling pretty quickly after with changing with standerd plugs.
    After changing to " Split Fires " I never fouled another plug since.
    Big O
  13. Aug 15, 2012 at 9:42 AM
    #93
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Just changed out the plugs in my 2010 v6 with the OEM Densos at 30k. The old plugs had good wear but they were noticeably worn. For $30 I am very happy with the results.
  14. Sep 17, 2012 at 10:32 PM
    #94
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    The reason behind why toyota uses Denso on one side and NGK on the other side was driving me crazy. I asked ten people (even automotive experts / retired racers) and got ten differnt anwsers. I finally asked the head parts tech(the counter guys didn't know) at a large Toyota dealer here in San Diego and he said it was for warrenty purposes. If you blow your engine under warranty, and Toyota finds something different then stock plugs, they know it's been modified or worked on.Out of all the theories put foward, this seems the most plausible.
  15. Nov 2, 2012 at 2:35 PM
    #95
    Big Ed5150
    Big Ed5150 Active Member
    Ed
    Bella Vista, Ar
    Cd player thats it
    I feel retarded asking this, ngk says for my 97 tacoma 2.7L i need to gap the plugs at .032, is this right. Please, i'm doing this tomorrow.
    thanks all.
  16. Nov 2, 2012 at 3:51 PM
    #96
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. Thats correct.
  17. Dec 16, 2012 at 9:40 PM
    #97
    3RZforme
    3RZforme Active Member
    Arizona
    98 4x4 4cyl
    The first post on this thread confuses me...
    OEM plugs for my 98 Tacoma with the 3RZ are listed as:
    NGK BRK5EYA .032 gap, they are "v power" plugs
    The '01-'04 Tacomas are listed at .044" gap on NGK's site.
    Strangely enough NGK also lists the OEM plug for a '00 3RZ at .044"
    I just replaced my plugs with the BRK5EYA NGK's last week and they were the same plugs the previous owner had been running. So far as I can tell the gap for a first gen Tacoma with a 3RZ would be:
    '95-'99 @ .032"
    '00-'04 @ .044"
  18. Dec 31, 2012 at 5:29 AM
    #98
    gbarrigar1
    gbarrigar1 Member
    Glenn
    statesboro, ga
    09 PreRunner SR5 2wd Reg Cab 5sp Taco
    really? i was a mechanic at a gm garage for years. AC was the only thing you ran in a gm. anything else made it skip like crazy. Also our brother Ford dealer next door didn't put anything but motocrafts in a ford,lincoln, or mercury. same as the gm's, wouldn't run right without them. most dodge owners and shops i have talked with tell me champion is the only thing they recommand for those.
    this thread was very usefull for me chris. i'm a fairly new(and proud) tacoma owner was was looking for this very info. thanks for the intel!
    brand specification for the plug really depends on the vehicle and application as chris stated. its really best to go with the oem parts. or talk with someone that has done there homework as chris has done and find out what other options you have.
    location, weather, and driveing habits all play a huge factor in this as well. hence again, you can't go wrong with oem parts which have been designed and tuned in conjuction with the engines and ignitions to handle a variety of drivieng.
    some may have luck with other brands and some not. bottom line. oem will get the same results each time across the board.
    thanks again for the info chris. and all the laughs from the other posters. lol :)
    Jimmyrace likes this.
  19. Dec 31, 2012 at 7:25 AM
    #99
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    I remember when the Splitfire plugs were coming out. I tried a set on a 600cc Yamaha motorcycle. The bike had a 10,000+ RPM redline but would not rev past 6,000 RPM. The Yammie ran BETTER with the old OEM NGKs ( one spark plug crapped out and was running on only 3 cyls ) than with four good Splitfires.
  20. Feb 6, 2013 at 9:14 AM
    #100
    Lagunito
    Lagunito Deceased
    South Florida
    Pre Runner
    Say what you want, don't cry when you get bitch slapped in real life, these forums are moderated by your make believe friends of your alter (troll) ego.
    My opinions lean toward research and what past experience has shown.
    Most of the time what designers use has already been used in different applications.
    The stock spark plugs are plated and they need not to be coated with anti- seize grease because depending on the type you use the torque specifications are changed (reduced) yet I have found that the only time I have had a spark plug backout has been when using anti-seize.
    Effectively NGK does not want you to use ant-seize on their plated spark plug threads.
    I would recomend checking the torque settings of your spark plugs before a long trip or if you have used any type of lubricant on the threads when installing them.
    Some of my friends are engine performance buffs (gearheads) and everyone at one time or another brings up the ignition subject, hotter plugs or, colder plugs, design variances, wire sizes, timing, sensors, computers, etc...
    With spark plugs there are several determining factors surounding design and applications but they follow a few basic guide lines that should be considered.
    Combustion chamber design.
    Engine compression ratios.
    Fuel octane
    Driving habits.
    I use the phrase "driving habits" in a broad sense; to cover where and how you drive, and that includes traffic and terrain.
    With Toyota the Japanese business ethic doesn't compete domestically but internationally and abroad.
    It is nothing new for them to obey restictive emmision laws and follow another countries regulations because Japan's own laws have been shown to be demanding in compliance.
    The spark plugs that come in their vehicles are in compliance to fulfill
    regulation testing standards and warranty standards, and the brands that are used also cover the regulations for fair economic practice laws set in place by their country.
    Anytime an ignition component is changed from what is common design in a vehicle, the ECM to recognise the change should be reset if it is desirable to expedite the behavior and adaptation process. (disconnect the negative battery cable from the terminal for 3 to 5 seconds)
    It then takes appoximately 50 miles of drive time for the ECM to adjust efficently.
    One of the steps that is outlined when either testing or replacing
    electrical and ignition components is to disconnent to battery for the duration of the job performed.
    Touching the negative cable to a common ground for a few seconds after disconnection from the battery also helps capacitive discharging of the system.
    One of the reasons spark plugs don't last longer than we wish they would is because they loose their efficentcy from wear on the electrode edeges from the stress of the electrical currents ability to jump from the center electrode to the side electrode and the right angles that are manufactured into the plugs design.
    Through the convection of heat by compression in the combustion chamber and the rapid cooling from the air fuel mixture over repeditive cycles, the plugs litterally loose their edge.
    When the electrodes designed efficentcy is compromissed the electric current has a natural tendancy to find the path of least resistance in order for the current to travel to it's polar end.
    The current when facing resistance finds other points of collection to travel to and the direction of the spark developed can retard the combustion cycle and cause an incomplete burn and build carbon deposits which the carbon itself can retain heat and prematurely ignite the fuel mix causing pre-ignition/knock which further retards the ignition sytem causing fuel to be wasted in a effort to correct itself by restricting the spark plug from firing, cooling the affected chamber .
    Jimmyrace and Stryker420 like this.
