The Truth About Spark Plugs....
Discussion in 'Technical Chat' started by chris4x4, Apr 20, 2011.
  1. Oct 10, 2013 at 7:18 AM
    #141
    talisker
    talisker Well-Known Member
    Scott
    Vermont
    06 TRD Off Road SR-5 W/1 Ton wood pellets
    Firestone Ride Rite airbags
    I think I posted my update in the wrong thread. To keep it short, last night I changed my left side plugs and found they were NGK's while the rights were not. I'm thinking my truck had the original factory plugs still in it at 100k! Toyota apparently assembles with different plugs in each side. I read that somewhere on tacomaworld. They were worn but not too bad. If this is the case, that is pretty awesome for a non-iridium plug!
  2. Oct 10, 2013 at 7:31 AM
    #142
    BamaToy1997
    Bill
    Navarre, FL
    They did make then with different plugs on each side. Strange to me, but oh well. Most everyone that comes to my shop just asks to get NGK for their Toyota, no matter what is in them at the time. Never heard a single complaint from them since either.
  3. Oct 10, 2013 at 7:33 AM
    #143
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Efficiency as in replacing, yes. Efficiency as in mileage, no. Also, as the plugs get higher and higher in mileage, will need to regap them to keep them in their most efficient range...
  4. Oct 10, 2013 at 8:49 AM
    #144
    garyods
    garyods Member
    Roseville CA
    05 DC SB SR5 4X4
    air bags rear
    I beg to differ with you. I put 110K on my last set of Platinum plugs with no problem and the mileage was consistent from mile 1 until I replaced them.
    I don’t make this statement based on my personal feelings or random tank mileage. I have a log (I maintain for both tax purposes and for personal history) in which I have recorded every fuel stop, oil changes and lubes, tire changes and all maintenance and parts since I picked it up new.
    I don’t pull plugs to adjust the gap, if I’m going to do the work to remove the plugs I’ll just put new ones back in.
    I replaced the Platinum plugs with Iridium the last time, so I’ll see if they last as long as the old Platinum ones did.
  5. Oct 10, 2013 at 11:38 AM
    #145
    SpacemanSpiff
    James
    08 TRD Off-road
    As we all can. By efficiency, meaning an increase in mpg over the standard plugs - which is no. My mileage has been consistent with the use of normal plugs, too. But others will know more though.
  6. Oct 10, 2013 at 12:18 PM
    #146
    garyods
    garyods Member
    Roseville CA
    05 DC SB SR5 4X4
    air bags rear
    I didn't notice a bump in mileage when I changed to Platinum, my mileage increased until I hit about 40k and then it has held steady (not at a little over 190k). It's been a great truck, I swear that I wipe more oil off the dipstick checking the oil level than it uses between changes.
    Other than the HVAC fan resistor and rear springs it's been solid.
  7. Oct 10, 2013 at 6:49 PM
    #147
    BamaToy1997
    Bill
    Navarre, FL
    When using platinum or Iridium plugs you do not ever need to remove and re-gap them. The older copper tips would wear, requiring a re-gap, but the platinum or iridium ones do not wear like the copper tips did. I have seen thousands of platinum plugs at 100k that were still perfectly gapped.
  8. Dec 9, 2013 at 6:42 PM
    #148
    30coupe
    30coupe Well-Known Member
    Russ
    Iowa
    '04 SR5 TRD 4x4 ExCab 5 spd.
    I'm thinking I should change the plugs in my new-to-me Tacoma, so I read this entire thread. It was both informative and entertaining. Obviously, I haven't changed the plugs on a Tacoma yet, so I was a bit concerned to hear it took an hour and a half for one poster to change them...and he didn't think that was bad! Hmmm, I've changed more spark plugs than I care to count, but the only time it took that long was on a V6 Corsica my wife had. I had to loosen the motor mounts and jack the engine forward to do the back three plugs on that crosswise, front wheel drive, little beast. Oh, and you couldn't actually SEE the plugs even then.
    I certainly hope this won't be a similar experience. I also try to be economical (okay, I'm kind of a cheap bastard), so I did some tune-up math. O'Reilly Auto carries the NGK plugs for my 3.4 in both platinum and copper core. The coppers are $4.99 each. The platinums are $10.99 each. So, assuming a 30k mile change with the coppers, 90k miles would mean $89.82 worth of plugs. On the other hand, the platinums would theoretically last 100k miles and cost $65.94. Add to this the potential for 4.5 hours of labor versus 1.5 hours, and the platinums start to make sense to me, particularly if the performance is equal over the lifetime of either type of plug.
    Does this sound about right?
  9. Dec 10, 2013 at 6:02 AM
    #149
    garys05tacoma4x4
    garys05tacoma4x4 OneLife
    Agawam, MA
    05TRDSportLB4x4
    Synthetic oil/lubes used throughout. NGK Iridium Lazer 100K spark plugs. Rear differential breather extension modification. Toyota front skid plate, roof rack, bed mat, chrome exhaust exhaust. Runs like new!
    I used the NGK iridium plugs the 2nd time around. They are a 100k plug. Runs like new. About 25K on iridium plugs now. See my other posts for further detail. Why would I waste my time, money and inconvenience myself to have plugs replaced at 30K, ridiculous. Toyota dealers looking for your money!
  10. Dec 10, 2013 at 10:42 AM
    #150
    30coupe
    Russ
    Iowa
    Yeah, that's kind of my take on it too. They will be looking a long time to get my money though...service and maintenance happens in my garage! :devil:
  11. Dec 10, 2013 at 6:14 PM
    #151
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Copper = Better conductor of electricity (better spark)
    Iridium, Platinum, Boronidium, Lasers = Longer life, but not a hotter spark.
  12. Jan 13, 2014 at 10:14 AM
    #152
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
  13. Jan 13, 2014 at 4:42 PM
    #153
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  14. Feb 3, 2014 at 6:42 AM
    #154
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    When i purchased my new to me Tacoma I serviced the diffs, T-case, synthetic motor oil, fuel system cleaner, and Denso plugs with the ones Toyota recommends, and air filter replacements. I do all service on any used vehicle I buy, in this case my Tacoma had 38k miles. My question is I am at 50k miles and drive mostly city stop and go should I replace them its been 12k miles. I mean they are cheap enough and easy to do. I also own a Mustang Cobra and I know many who replace the plugs every other oil change :eek:.
  15. Feb 3, 2014 at 6:48 AM
    #155
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If it makes you feel better to replace them, then go ahead, the recomended interval is 30k. Maybe do it when your odometer reaches 60k and see how you make out.
    SJC3081 likes this.
  16. Feb 3, 2014 at 6:54 AM
    #156
    Marcoc
    Connecticut
    good call. 20k it is.
  17. Sep 24, 2014 at 7:07 PM
    #157
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    sorry to revive a dead thread, but what is it that they sell at the dealerships? the NGK's or the Denso? I'm guessing Denso.
  18. Nov 21, 2014 at 2:19 PM
    #158
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    01' Tacoma 4x4 3.4l 5 spd
    I just picked up 4 plugs for my 98' 2.7 from the dealer for $2.22 each. At that price it wouldn't make any sense to not buy the oem plugs straight from the dealer. Part# 90919-01176 & on the actual Denso plugs it says K16R-U.
  19. Mar 30, 2015 at 5:23 AM
    #159
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    denso
  20. Dec 15, 2015 at 6:13 PM
    #160
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    When I bought mine with 120,000 on it I put in NGK iridiums. Only because they last so long. I'll pull them at 50,000 and see how they look. I suspect copper is a better performer but I like the idea of less maintenance. They seem to work fine for me so far with 20,000 on them.
