The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Aug 19, 2019 at 11:36 PM
    #2281
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    So that's good news for Canadian Tacoma's then as they should not require any special harness as all Tacoma's I've seen use the amber lights as their DRL
  2. Aug 20, 2019 at 8:11 AM
    #2282
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Amber DRLs are no problem. Canadian law requires DRLs. Some Tacoma’s have headlight DRLs, might only be 1st Gen, but I thought some 2nd Gens did as well.
  3. Aug 22, 2019 at 6:28 PM
    #2283
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    Does this harness really make stock wattage bulbs brighter? If so, how? I may build a harness if it really makes stock wattage bulbs brighter. I think I can build one for way less than most sellers get for them.
  4. Aug 22, 2019 at 6:33 PM
    #2284
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    On vacation and my new Superbrights are waiting for me. Also ordered TRD Pro Headlights
  5. Aug 22, 2019 at 7:03 PM
    #2285
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Yes, it does. Ohm's Law is how, as explained in Post #1 of this thread.
    With all due respect, if you couldn't take the time to read Post #1 and don't understand how reducing the resistance of headlight wiring results in higher voltage to the bulbs and therefore brighter light, you should probably leave harness construction to the experts and just buy one of their pre-made products.
  6. Aug 22, 2019 at 7:29 PM
    #2286
    1moonshine2
    I know ohm's law. I've been working with electricity for 40+ years, AC, and DC. I just didn't know that the stock wiring was so poor. Also, I don't believe anything I read on some aftermarket company's sales pitch website. They all claim everything they sell does miracles. That's why I asked on here, hoping some members who had actually tried a heavier harness, could say if it really made a noticeable difference, or not, on stock wattage bulbs, theories, and marketing hype aside. Not likely that I'm going to pay hundreds of dollars for a few dollars of wire, and a couple of relays, when I can make my own for way less, and it won't be a difficult task, at that.
  7. Aug 22, 2019 at 7:54 PM
    #2287
    Norton
    Your skepticism regarding Internet marketing claims is well-founded. As I said, however, Post #1 answers your questions about why/how the harness upgrade is worthwhile. Almost 2.3K other posts in the thread include countless testamonials from members who actually tried heavier harnesses, confirming they really make a noticeable difference. Links provided in Post #1 show the parts to assemble your own harness are available for $69 and assembled harnesses sell for $110/ea - both options considerably less than "hundreds of dollars."
    Good luck with your build.
    Tsinajinii likes this.
  8. Aug 22, 2019 at 9:37 PM
    #2288
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Halogen output has an exponential relationship to voltage, meaning very small increases in voltage will have noticeable increased effects on output. Using oversized 12awg wiring directly to the battery is more electrically efficient reducing the voltage drop over the stock circuit, meaning the voltage delivered is slightly higher. On a modern 2nd Gen you can expect about 15% more output from stock bulbs with a well made 12awg the harness, likely more on older trucks.
    You can also boost voltage with a voltage booster if running an AGM battery on a 1st or 2nd Gen As covered here:
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    FastEddy59, Norton and Tsinajinii like this.
  9. Aug 23, 2019 at 2:49 PM
    #2289
    1moonshine2
    I'm going to do some checking by running a heavy wire temporarily to one light, and check the change in voltage available as compared to stock. If I can't prove a difference for myself, I won't bother to build a harness for stock bulbs, but I'm still debating on higher wattage bulbs anyway. I don't have an AGM battery. I have no special need of one, and the price isn't worth it for general use, not to me anyway. I will probably need a new battery before winter, this one is 8 years old. Thanks for the info. If I do get a 15% improvement, I'll certainly upgrade the harness.
  10. Aug 23, 2019 at 3:53 PM
    #2290
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Mine didn't have either.
  11. Aug 27, 2019 at 11:36 PM
    #2291
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    So I read a lot of the replies on here but wanted to confirm some stuff. I have an 02 Tacoma that I ordered some new headlights, TYC CAPA Cert from Rockauto.
    Is this the wiring harness I need for a 1st gen Tacoma?
    http://www.headlightservices.com/4runner3.html
    Osram Super Bright? I couldn’t find the Allseasons mentioned.
    https://www.powerbulbs.com/us/product/osram-super-bright-premium-h4
    I read that this doesn’t work with DRL headlights which is fine because I was going to disable the DRL anyway by cutting the wire from the relay. If I go with the wiring harness from Headlight Services does that mean I don’t need to cut the DRL wire to disable it?
    Any other help info to do this mod for a 1st gen Tacoma would be appreciated.
    medjah likes this.
  12. Aug 28, 2019 at 8:36 AM
    #2292
    medjah
    medjah Volleyballing
    Blake
    Austin, TX
    09 Barcelona Red DCSB SR5 TRD OR
    OME 887 Springs OME 90000 Shocks OME Dakar Light Duty Leafs Wheelers SuperBump Bumpstops w/ u-bolt flip Sway Bar relocate Red Brake Lines Ultimate Headlight Upgrade Airflow Snorkel Rear diff breather mod CMC AtTheHelm Bed Stiffeners AtTheHelm Front Rail Chock System Hood Struts
    I cannot speak to 1st gen but I believe that is the current bulb people are running.
    TacoJohn4x4[QUOTED] likes this.
  13. Aug 28, 2019 at 9:56 AM
    #2293
    Norton
    You may want to consult this thread's 1st Gen Proper headlight upgrade companion.
    Before ordering, STRONGLY RECOMMEND you confirm your electrical ground system by following the steps outlined here... Many older trucks required Ground Switched harnesses. I was, therefore, surprised to discover my '04 was Conventionally Switched, requiring a Conventional Harness. I didn't care about DRLs and didn't want the function to further shorten my upgraded bulbs' already short lifespan, so I disabled them when when I upgraded. As I understand it, you need to disable your DRLs if you're Ground Switched, because they're incompatible with the upgrade.
    Osram Super Brights are what I've run since they discontinued their Hyper line of bulbs.
    crashnburn80[OP] and medjah like this.
  14. Aug 28, 2019 at 12:56 PM
    #2294
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Thank you. I’ll post my questions in that thread and I’ll confirm if I have a ground switch. Mine being 02 I would think so. I could see an 04 having the other type switch since it was the last year for the 1st gen, but I’ll confirm anyways.
    Norton[QUOTED] likes this.
  15. Sep 10, 2019 at 1:56 PM
    #2295
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    I am planning on installing the harness and lights here in the next few days to replace an hid kit( I know... it's the ) but was wondering if I should just keep the same adjustment I currently or is there some dimension I should adjust the cutoff and center to?
  16. Sep 10, 2019 at 2:42 PM
    #2296
    Norton
    Assuming your current headlight housings and adjustment are stock, no adjustment is required.
    medjah likes this.
  17. Sep 10, 2019 at 2:53 PM
    #2297
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    If your truck is not stock height I would adjust it. There are videos on Youtube showing you how to aim your headlights. It also doesn't hurt to check it again.
  18. Sep 11, 2019 at 8:30 PM
    #2298
    TacoTuesday1
    FL
    just got to page 2 of 115, woohoo
    this is similar to what many people do to old Mercedes E320's ("W210" chassis)
    putting brighter Osram bulbs (more watts) and sometimes thicker wiring
  19. Sep 11, 2019 at 8:34 PM
    #2299
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, the concept certainly isn’t new. Just seems to be overlooked with LED/HID being the buzz words in automotive lighting.
    To save you some reading time, I keep the first post constantly updated with the latest info, so no need to read all 115 pages for the latest info. :)
    FastEddy59, medjah and Tsinajinii like this.
  20. Sep 11, 2019 at 8:41 PM
    #2300
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Does anybody know of any major companies that do headlight aiming? Maybe with a beam setter machine?
