The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Nov 11, 2019 at 3:48 PM
    #2481
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I agree, my cutoff is very clear and i like it a lot. I think the '13-15 headlights make it even better
    crashnburn80[OP] likes this.
  2. Nov 12, 2019 at 6:26 AM
    #2482
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Sound like my wife. :argue:
    b_r_o[QUOTED] likes this.
  3. Nov 12, 2019 at 11:02 AM
    #2483
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    100%, I’m actually impressed by it!
  4. Nov 14, 2019 at 3:58 PM
    #2484
    gonzo048
    gonzo048 Member
    david
    2013 Toyota Tacoma TRD Sport
    I just want to ask, if anyone is running these bulbs (like osram H4 100/90w superbright) without the wiring harness? And if so, what is your experience. I get a little nervous with wiring. (even tho it seems like plug and play) Also, I am seeing wiring harnesses on Amazon for $30-$40. Are those any good? $100+ for a wiring harness seems pretty steep.
  5. Nov 14, 2019 at 6:17 PM
    #2485
    jet123
    jet123 Well-Known Member
    Ft Collins
    2013 DCLB
    Electricity is a black box to me...I get you!
    The harness really is plug and play and this thread can answer any question...
    The harness seems simple and it is. But the difference is quality and if you read back a bit, you'll hear people 'got what they paid for'.
    Can't comment on running just the better bulb as I also have the harness.
    But installing the better bulbs and using the better (ie - longer lasting) harness is tied for the best mod I have done. I say that considering how much I use my lights.
    crashnburn80[OP] and b_r_o like this.
  6. Nov 14, 2019 at 6:30 PM
    #2486
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Those bulbs will draw a lot of current for the stock wiring. Too much current draw causes the wires to heat up which raises resistance which makes the wires even hotter. That leads to potential fire danger.
    Cheap harnesses use poor quality items especially relays.
    Norton, crashnburn80[OP] and b_r_o like this.
  7. Nov 14, 2019 at 7:59 PM
    #2487
    gonzo048
    gonzo048 Member
    david
    Thanks guys. I'm going to hold of till spring to pull the trigger. Being that its 20° out here in Chicagoland area and being I don't have a garage to install the harness. But I think this is the mod I will end up doing. Harness and osram super brights. Is the link for the hardness on page 1 of this thread still good to buy it from??
  8. Nov 14, 2019 at 8:02 PM
    #2488
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    You can install the harness in 10-15 min easy, and it is such a useful mod for the dark winters. Yes, the Headlight Services harness is the way to go, I keep all links in the original post up to date.
    whatstcp, Norton and FastEddy59 like this.
  9. Nov 14, 2019 at 8:17 PM
    #2489
    gonzo048
    gonzo048 Member
    david
    Ok, awesome. Might just buy then now then after a little more research on the install. Would be helpful now that it gets dark by 4 out here. Thanks everyone
  10. Nov 15, 2019 at 11:47 AM
    #2490
    gonzo048
    gonzo048 Member
    david
    Last question, any recommendations on yellow fog lights? Specic brand?
  11. Nov 15, 2019 at 12:17 PM
    #2491
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Rigid Selective Yellow D-series are the best performers by far with the Rago 12-15 mounts. The new 360 series does mount a lot nicer, looking like stock, but lacks the wide angle and higher intensity.
    You can see the 360 vs D-series SAE pattern differences in the SAE fog thread here:
  12. Nov 15, 2019 at 1:18 PM
    #2492
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    The Rigid D-Series (in white) are sick! Insanely bright...makes me want to do the Fog Light Anytime Mod:anonymous:
  13. Nov 15, 2019 at 1:19 PM
    #2493
    FastEddy59
    Eddie
    Does anybody know the part number for the rubber boot on the back of a Second Gen. ('13-'15) housing? Lost a headlamp comin' home last night & when I went to replace 'em today the drivers side boot was gone. Likely replaced before as they were mismatched lamps as well. Any issues with higher lamp temps and this rubber boot? I really don't want to clean up a bunch of melted goo.
    MattCowsmasher likes this.
  14. Nov 15, 2019 at 2:29 PM
    #2494
    gonzo048
    gonzo048 Member
    david
    Those rigid d series look sick but was looking to just swap the bulbs
  15. Nov 15, 2019 at 5:38 PM
    #2495
    Green Jeans
    Oregone
    '13 TRD Off-Road
    There are brackets that you can mount into the stock fog housing IIRC...
  16. Nov 15, 2019 at 10:55 PM
    #2496
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I don't think I have any spare boots but, FWIW, I've run the Ultimate Headlight Upgrade for almost 4yrs (both Osram Hyper 85/80w and Super Bright 100/90w H4s) with no melting issues.
  17. Nov 18, 2019 at 12:12 PM
    #2497
    ctkr808
    ctkr808 Well-Known Member
    What bulbs are these?
  18. Nov 19, 2019 at 3:37 PM
    #2498
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Hello all, first post here. @crashnburn80, I was linked your foglight thread from the automotive section in candlepowerforums a whike back. Very informative. From there, I found your 3rd gen tacoma upgrade thread, and now this thread. I read the entire 3rd gen tacoma thread looking for answers for a friend of mine who just picked up a '19 trd pro. He was looking at some of the LED options available, but was happy to see that there was significant upgrade potential with H9s in his lowbeams. The comparisons you posted really sold it (and thankfully he won't be going with LED now).
    I have a 3rd gen 4runner, a 1999 with the original headlamps still installed. They're starting to show some dulling of the reflector cups, so I'll be looking for some new, hopefully OEM koito assemblies in the near future. For now, I'm running Phillips +130 H4's.
    I've been messing with my lamps since I got the vehicle in 2014, trying different bulbs. For the past few years, I had to do a considerable amount of night driving, and had about an hour commute each way on windy backroads with tons of deer. And TONS of fog, especially in the spring/early summer.
    I found that the best foul weather performance I got (all anecdotally, which I understand is flawed) was using philipps +100 h4 (no bulb tint) and 3 coats of duplicolor metalcast anodize yellow on my lenses (transparent yellow, effecticely tinted the output to "Selective Yellow." This worked really well in heavy fog/rain/mist, and also made signage on the side of the road (blue metallic base paint) less reflective and blinding.
    I got popped multiple times for tinted lenses, which were illegal under PA law. So after about 18 months I stripped the lenses bare and got those selective yellow bulb covers that Candlepower/susquehanna motorsports sells. They did the job for lowbeam, but the curvature of the filter is right over the lower 1/3rd of the highbeam filament. I got fewer tickets for this, and was able to get them all thrown out in court (PA requires white headlights but makes no reference to a definition of white, I used the federal standard and a buddy's lightmeter which showed the clear bulb and yellow clip on filter resulted in a borderline federal white output. Technically correct, the best kind).
    I'm looking for better fog/rain/foul weather lighting at this point. I thumbed through this thread earlier and saw someones post about Lunex "plasma yellow" H4 +80 bulb. I have a set on order, but they wont be here until mid/late december. Have you tested these out? I haven't come across that post, if you have. I did see in your H11/H9 upgrade thread that you stated they are an indian company trying to pass themselves off as a UL startup, but Im hoping they're half decent.
    **Edit** went back over the H11 uograde thread, your post #48 showed a soectrum comparision between the GE +130's and also the XD rebased HID. You stated that the lunex h9 put out "almost as much light" as the GE's, but I didnt see the intensity comparisons. Still thumbing through This thread if anyone has posted about the Lunex H4s. **/Edit**
    I have run hella "3000k" yellow bulbs, which were basically amber, Philips colorvision (standard bulb, just a *Bare* touch of yellow filter) which were not very good imo, and tried a few other brands. None have been nearly as effective in fog/bad weather as my tinted lenses. I'm half hoping these lunex bulbs are at least "ok" performers.
    If anyone has been running these, can you give me your assessment of their performance in bad weather? Appareciate it.
  19. Nov 19, 2019 at 3:46 PM
    #2499
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Unfortunately, nobody will be able to tell you what bulbs those are by looking at the outside of the vehicle / light housings. We need to see the back side of the housing and / or the bulb itself.
    Norton likes this.
  20. Nov 20, 2019 at 4:23 PM
    #2500
    Tanginator
    Tanginator Member
    Dallas TX
    2006 Tacoma 4x4 SR5
    So, if I'm reading this correctly. I will need both the "Conventionally switched wiring harnesses AND Ground switched wiring harness", and I can get it from either Rallylights or Headlight Service, correct??
