The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Feb 10, 2023 at 5:58 AM
    #4761
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    I guess the thinking (right or wrong) is that LED bulbs produce less heat and so would be less likely to burn/melt the reflector housing which is an issue on the Gen 2 Tacomas.
    TacoFergie[QUOTED] likes this.
  2. Feb 10, 2023 at 6:35 AM
    #4762
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Remember, power consumption (watts) is not the same as heat generation (degrees). It's the heat that caused problems with melting lenses. Running LED bulbs in that location should (theoretically) solve the heat problem.
    TacoFergie likes this.
  3. Feb 10, 2023 at 6:47 AM
    #4763
    Michigan Nick
    Michigan Nick New Member
    Nick
    2015 Black TRD Pro
    Big thanks to crashnburn for providing detailed instructions, photos, and up-to-date links! Just ordered the recommended harness and bulbs for my '15.
    Norton and Toy_Runner like this.
  4. Feb 10, 2023 at 9:02 AM
    #4764
    mushx
    mushx Member
    i have the v3 and yes, best aftermarket LED ever
  5. Feb 10, 2023 at 1:39 PM
    #4765
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Thats a good point. I may have mistook the way it was worded.
    In the 05-11 Tacoma's that was an issue melting the inner lens piece. I suppose I wasn't looking at it from that perspective. I thought that Toyota revised the light's because of that?
    dirtnsmores likes this.
  6. Feb 10, 2023 at 2:52 PM
    #4766
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Yes they did. But the revised light is no longer available, so now they are selling only the original ones with the melting DRL issue.
  7. Feb 10, 2023 at 4:05 PM
    #4767
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Ok crash how do we avoid the melting issue?
  8. Feb 10, 2023 at 4:11 PM
    #4768
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Short of finding a pair of the updated lights without the melting issue or not running DRLs, run an LED instead. The optic that melts is immediately in-front of the DRL bulb. The incandescent bulbs are hottest at the filament in-front of the bulb. An LED still produces heat, though less, but the heat is at the base/back of the LED bulb safely away from the meltable optic, at least in theory.
    wdb likes this.
  9. Feb 10, 2023 at 4:19 PM
    #4769
    Tiedie
    David
    WFOY
    So the 2nd gen part numbers you have listed on page 1 are the updated ones correct?
    And thanks for all the effort on keeping this thread going.
  10. Feb 10, 2023 at 4:28 PM
    #4770
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. But when you put in those part numbers now, Toyota sites may take you to the old part number because the old part number now replaces the updated one since there are no updated lamps available. It will still show it is the old part number, but you just need to be extra observant. All the part numbers for both smoked and chrome, original and updated units are available in the TSB here.
  11. Feb 11, 2023 at 8:28 AM
    #4771
    mikkydee
    Doyle
    Florida
    Ok for all of us novice light guys, bottom line, how do I correct the lense burning issue on the DRL's so I don't mess up my new OEM lights? I see some say replace the DRL bulbs with LED bulbs. But then you get hyperflash, so you have to install special resistors or grind down something or other. Is there a video somewhere on how to do this?
    I mean that is like my wife telling me to go cook dinner, I am completely lost on how to do that. Not that I am unwilling but I don't know what a dash of salt is or what temp to set the oven. Where do you get these resistors and how do you install them? What about this grinding down the flasher or whatever? If you said rebuild the motor at least I would know what to do but this light business has me completely in the dark. I finally figured out a few minutes ago what a DRL was (who knew?).
    Any links to videos or clear instructions and links to the correct LED bulb replacements would be appreciated. FYI there is no way I am dropping $150 on some DRL bulbs after dropping $450 on new headlights. Momma won't go for it...
    dirtnsmores and 1schoir like this.
  12. Feb 11, 2023 at 3:39 PM
    #4772
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Link to how-to on modifying/grinding the TS module resistor.
    https://www.tacomaworld.com/threads...th-stock-drl-flasher-and-no-resistors.176904/
    mikkydee[QUOTED] likes this.
  13. Feb 11, 2023 at 6:05 PM
    #4773
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    mikkydee likes this.
  14. Feb 11, 2023 at 6:35 PM
    #4774
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
  15. Feb 11, 2023 at 6:56 PM
    #4775
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    some people like to switch it on/off. I traded my DRL & harness for non DRL relay & cap
  16. Feb 11, 2023 at 7:15 PM
    #4776
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    daveeasa likes this.
  17. Feb 11, 2023 at 7:20 PM
    #4777
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    daveeasa and crashnburn80[OP] like this.
  18. Feb 11, 2023 at 7:26 PM
    #4778
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    On my ‘05 I replaced the flasher with a DD flasher. I like it.
    At some point I intend to add DRL with a stalk swap.
  19. Feb 11, 2023 at 7:27 PM
    #4779
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Actually, this is silly. If swapping to a non-DRL, you'll be unlikely to melt the lens because the light won't constantly be on. Only flash intermittently with the signals. So if swapping to non-DRL I'd stick with standard incandescent bulbs.
    Tiedie likes this.
  20. Feb 11, 2023 at 7:37 PM
    #4780
    daveeasa
    David
    PNW
    But tap to turn is badass.
    if DD could give me one swipe windshield washers too, I’d be happy.
    TerryTac0 likes this.
