DTRL toggle switch mod (stealth mode)
Discussion in 'Lighting' started by Crom, Apr 4, 2010.
  1. Apr 4, 2010 at 11:28 PM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Welcome to Crom's guide of modifying your Day Time Running Lights (DTRL).
    This 2nd gen mod allows the owner to selectively control when the factory can operate. It does not interfere with any other system. This is my first mod contribution to the TW community. Please enjoy.
    Parts needed for this mod:
    1. Switch
    2. 2 x Butt Splices
    3. Connector ( I used a 3-pole Molex connector from an old computer case fan)
    4. Drill and drill bit to make a hole for your switch.
    5. Crimp/wire stripper tool
    6. Needle-nose pliers
    7. Lighting
    8. Time
    9. Patience
    The hardest part of this mod (if you choose not to remove the lower dash) is transforming yourself into a human pretzel to get the job done. It does require patience but can be done in about 1 hour if you can work uninterrupted.
    Step #1 Prepare your switch
    1. Solder a connector to the switch, use heat shrink.
    2. Use a connector, if you must remove the dash in the future you will need to disconnect the switch. My connector is a 3-pole molex adapter connector from an old computer case.
    Step #2 Prepare your workspace under the driver side dash.
    1. Push your seat all the way back.
    2. Clear away all obstacles and clean or remove the floor mats.
    3. Prepare your light source.
    4. Invert your body.
    NOTE: ALTERNATE METHOD TO STEP #2 FROM BRADLEYJ
    Step #3 Move stuff out of the way.
    1. Remove the hood release lever, study the design, it has some white plastic tabs that need depressing, then it slides back towards the engine. Take your time with it. It will come loose. Tuck it out of the way.
    2. Move the ODB diagnostic port out of the way. Push the white plastic tab and it should pop out.
    Step #4 Find wire harness "1M"
    1. Find the "1M" harness. It is behind the junction block on the driver side.
    2. The harness is on the backside of the junction/fuse block. The backside of the junction block is the Body ECU.
    Step #5 Splice into DTRL wire
    1. Wire Harness "1M" only has 3 wires so it should be easy to spot. These three wires go to/from the Body ECU to the signal flasher.
    2. Push the 1M harness plug out. I used some needle-nose pliers to push with. It popped out without any real resistance.
    3. Cut the Green/Red tracer wire. Leave enough room to strip a bit of insulation off.
    4. Install your butt splice on each end of the DTRL wire.
    Step #6 Test your switch.
    1. Connect the switch connector and test your switch. Make sure it works.
    2. Remember, that the switch must be "ON" in order for the DTRL to work. If the switch is "OFF" the DTRL will not operate (Stealth Mode--Yeah baby!)
    Step #7 Install switch.
    1. Make a hole in your dash and install your switch.
    Step #8 Put stuff back
    1. Put ODB port back into place.
    2. Reinstall the hood release lever.
    Step #9
    1. Enjoy! [​IMG]
    REFERENCE MATERIAL
    wilcam47, JDeRose, Marc70 and 5 others like this.
  2. Apr 4, 2010 at 11:34 PM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    Finnally. A DTRL switch mod guide thats for dummies. TY, I needed this.
    crackils likes this.
  3. Apr 5, 2010 at 11:58 AM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Finally! Someone found this out! Thank you Crom!!!
    One question though, what is actually going on in this picture below? I know splicing and such is going on, but what is actually being connected to the green/red DTRL wire?
    Also, does this have any effect on the blinkers?
    IamEricRN and furi like this.
  4. Apr 5, 2010 at 1:14 PM
    Crom
    Nick
    San Diego, CA
    Millions
    You're welcome. :)
    Chad,
    Perhaps that picture is not the greatest. In the picture, my connector is only 50% connected. I still needed to connect the other side of the green/red wire via butt splice to the black wire. Once its completed it will look identical to picture in step 6.
  5. Apr 5, 2010 at 1:36 PM
    Chad
    Chad
    Cary, NC
    Ohh ok. So what you're saying is you cut the green/red DTRL wire, and connect one side to the red wire from the connector, and the other side to the black wire from the connector? So what you did is like what I've demonstrated in the attached image?
    Also, is soldering really necessary? And where did you get the switch from?
    furi likes this.
  6. Apr 5, 2010 at 1:45 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Chad, That is precisely what I did!
    Soldering makes for the best connection for the switch to the switch connector, but you can use whatever method you prefer. The switch was from radio shack, the very first image shows the name, type, and part number. I am very happy with it.
    IamEricRN likes this.
  7. Apr 5, 2010 at 1:55 PM
    Chad
    Chad
    Cary, NC
    Just to make sure I'm correct, you soldered the one side of the connector to the switch right? So in essence, I could just electric tape it and heat shrink it so it will stay put? I have no idea how to use a solderer and have no access to one either.
    PS. sorry to ask all these questions, just making sure I understand it :eek:
  8. Apr 5, 2010 at 2:06 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Yes. I had to build this:
    I suppose so.
    Soldering is easy and for ~$10 you can buy a soldering iron and solder at walmart. Watch a youtube video on how to solder and your all set.
    No prob. I'm glad to help. This is what TW is all about.
    McDudesYota and TacoLou like this.
  9. Apr 8, 2010 at 2:42 AM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    thanks for info man, very cool
  10. Apr 8, 2010 at 3:31 AM
    LaxVarsity04
    LaxVarsity04 Caveman
    UCLA= Upper Corner of Lower Alabama
    96 4runner, soon to be 2010 DC TRD sport
    soon
    what exactly does this do????
  11. Apr 8, 2010 at 8:36 AM
    Crom
    Nick
    San Diego, CA
    Millions
    This 2nd gen mod allows the owner to selectively control when the factory Day Time Running Lights (DTRL) can operate. You get to decide if they're on or off, not Toyota.
    From the factory DTRL work like this:
    • Low beams off, + parking brake off = DTRL (ON CONSTANTLY, with no control to turn off)
    • Low beams on = DTRL off.
    The switch I built, which has been spliced into the DTRL signal wire interrupts the signal sent by the Body ECU to the signal flasher, which in turn gives control to the truck operator.
    The whole point of this mod is so that I can park my truck and leave the engine idling and turn off ALL my lights.
    Taco-Obsessed and File IFR like this.
  12. Apr 8, 2010 at 9:34 PM
    LaxVarsity04
    soon
    thats a very nice addition. i will definitely be doing this
  13. Apr 26, 2010 at 2:40 PM
    Cryer
    Cryer O shizzle!
    Bryan, Tx
    '11 Tacoma TRD Sport
    3" lift
    so if i just cut the wire, will it kill me front blinkers? or just dtrl?
  14. Apr 26, 2010 at 2:54 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Glad you like it. :)
    Your blinkers will work fine if you cut it. It ONLY affect DTRL, It does not interfere with any other system.
  15. Apr 26, 2010 at 3:18 PM
    Chad
    Chad
    Cary, NC
    So in essence you could cut it and it'll never come back on right? The switch only gives you the ability to turn it on and off correct?
    TacomaAF likes this.
  16. Apr 26, 2010 at 3:19 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Yes. If you go that route make sure you tape the end coming from the 1M connector to avoid any short circuit conditions.
  17. Apr 26, 2010 at 8:59 PM
    Cryer
    Cryer O shizzle!
    Bryan, Tx
    3" lift
    nice, i will just be cutting it most likely, maybe in the future ill put a switch.
    thanks alot man
  18. Apr 26, 2010 at 9:43 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Glad to help. :thumbsup:
  19. May 15, 2010 at 11:52 AM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Since my truck doesn't have the DTRL stock... I was thinking of doing the DTRL mod here on TW. Will I still be able to do this DTRL switch mod as well? Or is that only for the people with the stock DTRL?
    McDudesYota likes this.
  20. May 15, 2010 at 1:53 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I'd rather not speculate one way or the other since I know nothing about the mod you're referring to. However I'm sure there is way and it can't be too difficult, we just need good technical information to make informed decisions.
