The ultimate headlight upgrade H4 (not LED or HID)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Oct 27, 2015.
  1. Dec 19, 2016 at 10:04 PM
    #541
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    3rd gen headlight halogen upgrade is the same as the 2nd gen foglight upgrade. Both use H11, the proper wiring harness is listed here, (see the 2nd paragraph note for 3rd gen):
    https://www.tacomaworld.com/threads/the-ultimate-foglight-upgrade-not-led-or-hid.435419/
    Which DTL are you referring to? DTL using amber indicators will be unaffected. DTL using high beam on reduced voltage (headlight DTL) should also be unaffected on 3rd gen, as the high beam circuit is completely separate. On 2nd gen the DTL reduced voltage high beam is disabled as the relay disables the partial voltage setting of the high beam on the dual filament bulb.
    BenMara likes this.
  2. Dec 24, 2016 at 2:58 PM
    #542
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    WTF:eek:
  3. Dec 28, 2016 at 2:30 PM
    #543
    2004TacomaNavy
    2004TacomaNavy Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    Thank you for putting this together!
  4. Dec 29, 2016 at 5:29 PM
    #544
    Haany4x4
    Haany4x4 Well-Known Member
    Calgary, Canada
    2016 Blue TRD Sport 4x4
    I have a thought on that. The headlights on the third gen with the leds are the DTL and have their own switch control. However i notice that as soon as your low's come on the leds are dimmed so that tells me eigher they are under the same fuse but different switch OR there is a resistor in there once the lows come on for just the led lights. If that is true how can this be avoided trouble free...or will this create no trouble at all?
  5. Dec 31, 2016 at 1:33 PM
    #545
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    LED headlights probably don't use a 'resistor' for low brightness, instead, they likely use an active pulse-width-modulation current pump circuit.
  6. Jan 3, 2017 at 4:35 AM
    #546
    Haany4x4
    Calgary, Canada
    Right, diodes to reduce dc current good catch. So if this is the case then the low beam wiring harness would typically have a common issue do to this bridge diode...possibly??? Has anyone tried yet im still waiting for parts
  7. Jan 3, 2017 at 6:00 AM
    #547
    Chrome Beer
    Chrome Beer 7th Ceaser
    Dave
    Florida
    15 DCSB SR5 4X4
    Just a heads up i did this upgrade with the harness.Everything worked fine i got flashed now and then but o well.. But a year later when one of the 80W bulbs burnt out i noticed a burn mark on one side of the harness where the light plugs in. I would take picks but replacing the lightbulbs is a bitch. Just so you know if a fire occurs it wouldn't be covered under warranty because you altered it.
    Mush Mouse likes this.
  8. Jan 3, 2017 at 11:17 AM
    #548
    Haany4x4
    Calgary, Canada
    Oh that sucks...maybe 80 is a little too hot or loose connection on the wires causing arching. But you have a 2nd gen headlight hookup correct. I was asking about the 3rd gen projector led combo headlights
    Chrome Beer[QUOTED] likes this.
  9. Jan 3, 2017 at 12:35 PM
    #549
    Chrome Beer
    Dave
    Florida
    15 DCSB SR5 4X4
    Yes 2nd gen
  10. Jan 5, 2017 at 7:07 AM
    #550
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    Norton likes this.
  11. Jan 5, 2017 at 7:04 PM
    #551
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I don't have experience with that specific bulb, but Hella's reputation is good. The relays used in both the Ultimate Headlight and in the Ultimate Fog Light setups are, in fact, Hella products. FWIW, I was very happy with Hella headlights in my '92 Toyota Pickup. IIRC, they were plug & play and had a stock appearance, but provided lots more light than stock.
    crashnburn80 is the expert, but I'd expect these perform comparably to the Osrams recommended on pg 1. For less than $9/ea, I'll probably give them a shot when I need to replace my Osrams.
  12. Jan 6, 2017 at 8:35 PM
    #552
    Bluebaron7
    Bluebaron7 Well-Known Member
    Augusta, GA
    2009 Tacoma Double Cab TRD Off-Road(Sold)/2024 4Runner ORP
    3 Inch Lift, Leaf spring pack, SPC UCA's, Bilsteins 5100's, AFE CAI, ECGS Needle Bearing, CVJ Axles, Under seat Infinity Sub & 4 channel amp, softtopper, decked system, prinsu roof rack, Kenwood deck & Infinity speakers all around with door matting, taco sauce only sticker, steering wheel leather wrap and dash cam.
    I ordered this upgrade and I really can't wait to install the lights and wire combo. On a side note my credit card was also compromised for many charges after this purchase. I knew it was a possibility with other members having the same issue but it was a gamble I was willing to take. That's why I never use a debit card online or for gas when I can use a credit card for everything which isn't my money but the credit cards so they will definitely fight those frivolous charges. I'll post before and after pics when I install the upgrade. Thanks for sharing this OP.
  13. Jan 6, 2017 at 10:45 PM
    #553
    Mike44
    Mike44 Well-Known Member
    Victoria, BC
    2015 Silver TRD Sport DCLB
    Canopy, Lund side steps, 42" light bar behind the grill, Custom mud flaps, Hood and Window visors, Firestone airbag rear suspension, Undercoated, Husky X act fit floor mats front and back, Door sill protectors...... More to come.
    After seeing all these fraud issues with this guys wiring harness orders I think I'll hold off. I've added the ceramic harness to my stock wires via a quick plug and play and im currently running the Hella 135/90 watt bulbs. No visible signs of heat warping or distortion even on various lengths of drives. They are definitely brighter than stock but until the site takes pay pal I will hold off or look for something local. Plus the exchange rate blows for us canucks.
    Mush Mouse and Bravisimo like this.
  14. Jan 6, 2017 at 10:45 PM
    #554
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    both my bulbs went out after 5-6 months when i needed them mosto_O. 5am in the morning on my way to a fishing trip. luckily, i kept the stock ones in my garage to save the day.
  15. Jan 7, 2017 at 4:08 AM
    #555
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    Not to bash on ur upgrade but u have some facts wrong
    Stock hid bulbs(philips or paramount) are 3200lumens. Also come in different temp ranges to suite specific need and look without sacrificing output. Also it says off-road so that means they are not dot so not legal to drive on road just like pano hid kits
  16. Jan 7, 2017 at 8:14 AM
    #556
    Toyojake
    Toyojake Well-Known Member
    Jay
    Central TX
    2009 T4R Sport 4x4
    Subb'd for a later date
    Awesome mod! Did similar with my XJ
  17. Jan 7, 2017 at 3:35 PM
    #557
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I emailed Ray at Rallylights to see if they are aware of the issue and what they are doing about it.
    In the mean time, there is another vendor for made in the USA quality component H4 12 gauge headlight harnesses:
    http://www.headlightservices.com/Wiring.html
    Not ideal timing for sure. I always suggest buying 2 sets at a time to have a backup pair. Bulb life is rated at 200 hours.
    Bluebaron7[QUOTED] likes this.
  18. Jan 9, 2017 at 8:58 AM
    #558
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Ray got back to me and said they have had other reports of this as well. They have since changed their credit card processing company and all related passwords and appreciated being notified of the situation.
    Muffdiver, Norton and wdb like this.
  19. Jan 9, 2017 at 11:28 AM
    #559
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I'll vouch for the rallylights guys. I live near there and visit them in person. If they say it's fixed, it's fixed.
    Biscuits and Bravisimo like this.
  20. Jan 11, 2017 at 1:12 PM
    #560
    Richterman
    Richterman Well-Known Member
    07 black 4x4
    crashnburn80[OP] and Biscuits like this.
