These are real tie downs toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by husqvarna 530rr, Mar 14, 2013.
  1. Mar 15, 2013 at 2:35 PM
    #41
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The whole bed is made from SMC (fiberglass-reinforced nylon), so now the bed sidewall flexes instead of the bedrail.
    And the screws are most likely 95,000 psi shear strength, not 95,000 lb. ;) If they are 3/16" screws, then the cross-section area is only 0.0276 sq. in., so 2600 lb shear. Most mil standard and NAS fasteners are no stronger than SAE Gr 8, but they are more consistent for fracture toughness
  2. Mar 15, 2013 at 2:59 PM
    #42
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    And I'm out.
  3. Mar 15, 2013 at 3:33 PM
    #43
    mattmyster
    mattmyster Well-Known Member
    matt
    nova scotia
    07 4 door trd offroad radiant red
    Kenwood DD deck, XD 17in rims, 285/70 firestone destination A/T, ,7in spotlights behind the grill, satoshi grill and color match, rough country lift, seat covers...maybe more cant remember
    new rings are probably unnecessary for our size truck however its your truck so modify it however you want! i got shit from people just for lifting an expensive truck but eh its mine so whatever who cares
  4. Mar 15, 2013 at 4:02 PM
    #44
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Where did you source these? They look badass!
  5. Mar 15, 2013 at 8:21 PM
    #45
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    Whats wrong with the bedrails and cleats?? I love em
  6. Mar 15, 2013 at 9:35 PM
    #46
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Very nice! Got any extra? :D
  7. Mar 15, 2013 at 9:50 PM
    #47
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yep, only difference between most mil spec fasteners and hardware store is traceability and pedigree.
    Maui Grown! :D
  8. Mar 15, 2013 at 9:51 PM
    #48
    husqvarna 530rr
    husqvarna 530rr [OP] Well-Known Member
    oahu hawaii
    sport
    none
    Good question... I thought they eould and had planned to use a small zip tie on the fronts, however they only rattle when hitting a decent size bump.
  9. Mar 15, 2013 at 9:52 PM
    #49
    husqvarna 530rr
    oahu hawaii
    sport
    none
    Ummm how exactly do you do that with two dirtbikes?
  10. Mar 15, 2013 at 9:53 PM
    #50
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    The factory tie downs are fine ( D rings ) for the rear, I've thought about buying the front factory tie downs from toyota for the 2013 models which are right in front of the wheel wells on both sides. I checked them out on the new trucks at the dealership.
    I didn't buy them cause of the price they wanted and toyota said there is prob some reinforcing plate behind them, compared to pre 2013.
    The cleats are marginal at best, they work good for what I use them for but dirt bikes and large heavy crap like that would make me look for an alternative solution.
    Jerry?!! B.A.M.F.
    Brett
  11. Mar 15, 2013 at 10:15 PM
    #51
    KenLyns
    Belly of the Beast
  12. Mar 15, 2013 at 10:35 PM
    #52
    Raceline08
    Brett
    Santa Rosa, ca
    I think a few are. Not the same.
    Brett
  13. Mar 16, 2013 at 5:02 AM
    #53
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    OP, nice install. Yes the fasteners are quality NAS stuff. They definitely are not brass with the coin slotted head style.
    The 7075 will be fine to double it up, but I hope you anodized, or alodined the plates plus primed and painted them.
    I like the rings, are they from a 53?
    As for aerospace fasteners being almost the same as Grade 8 except for traceability...I say no way. Quality aerospace hardware has a lot more details in adding radius under the fastener head, better thread forming and will pass a magnetic particle inspection.
    I have inspected brand new GR8 bolts with mag particle and they are loaded with cracks from manufacturing.
    OP, send me a PM with the PN or what helicopter they are used on. Maybe I can obtain some locally.
    PK
  14. Mar 16, 2013 at 8:39 AM
    #54
    Swordknives
    Swordknives mmm Tacos
    South OC CA
    2013 Dbl cab LB v6 SR5
    Looks good where did you get them?
  15. Mar 16, 2013 at 9:58 AM
    #55
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Pretty sure that's what I was getting at. Thanks tips.
  16. Mar 16, 2013 at 10:57 AM
    #56
    KenLyns
    Belly of the Beast
    Regardless of the flaws, if you buy a bunch of Gr 8 bolts from a branded mfr like Spaenaur or Fastenal, they will exceed the 160 ksi tensile strength requirement. The other properties like fracture toughness and better dimensional tolerancing separate the MS/NAS bolts from commercial bolts.
    Don't put much faith in the paper traceability. I've seen idiot MS/NAS bolt mfrs who heat treat the bolts after thread rolling, but that's another story for another day...
  17. Mar 16, 2013 at 11:35 AM
    #57
    bullaculla
    Da big big island!
    Specialty fasteners, yes very different. You cant get buttress threads from home depot, But normal bolts are really no different from good grade 8.
    I've seen lots of mil spec material that were supposedly tested from the factory fail our inspections. More than half of the helo tie downs we receive get sent back to peck and hale because they fail NDT.
    But you are probably right. My experience is in the shipyard, I'm sure the aviation side is nothing but specialty fasteners and with much more specifications and tighter tolerances.
  18. Mar 16, 2013 at 12:09 PM
    #58
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
  19. Mar 16, 2013 at 8:40 PM
    #59
    husqvarna 530rr
    oahu hawaii
    sport
    none
    Yes they came from a 53d, however the 53e uses them as well.
  20. May 16, 2013 at 11:13 PM
    #60
    kumz
    kumz Well-Known Member
    well hello mr steve
