These Damn Wheel Bearings...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco93, Apr 9, 2011.
  1. Apr 9, 2011 at 5:57 PM
    Taco93
    Taco93 [OP] Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    Where did you get them?
  2. Apr 9, 2011 at 5:58 PM
    AK27
    AK27 Well-Known Member
    i went to a small shop. the mechanic is a friend of mine and he ordered them through a local auto parts store
  3. Apr 9, 2011 at 5:59 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i might be getting some new bearings just because.....im at 55k:eek:
    it's inevitable im seeing........
  4. Apr 9, 2011 at 6:14 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    So was that the bearing and hub all ready pressed together? Is there any way you can pm me with the info?
  5. Apr 9, 2011 at 9:14 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
  6. Apr 9, 2011 at 9:17 PM
    DSMissed
    DSMissed Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    Damn... I'm just over 60k, NOT looking forward to doing this. Do you start getting bad steering wobble or vibrations or what?
  7. Apr 9, 2011 at 9:39 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'd re-think using the same seals/gaskets/O-rings.
    Even if they weren't leaking before their bound to now, the seal was compromised when you took it apart, even if not torn but if you look close at any O-ring, its no longer round, it'll be flat or warped (ovaled ) & that was the sealing surface, just sayin' if theres one there spend a couple more bucks & be confident in your install, its a bitch when you take what seems like a plausible short cut just to have to do it again...just my $.02;)
  8. Apr 9, 2011 at 9:41 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
  9. Apr 9, 2011 at 10:01 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    I think (and anyone else feel free to chime in) most people report hearing noise. I was right at 75k and started hearing a droning noise coming from the front so I assumed, from all that I had read it was the wheel bearings. Turns out it was the tire. One wheel bearing had some rust but it wasn't as bad as the pics in the provided links. I'm going to let these go till they are grinding!
    Good point (as always). I replaced mine since I had it all apart for the exact reason you state.
    WHAAAAA?
  10. Apr 20, 2011 at 10:54 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    So I tackled the drivers front bearing today, but the noise is still there. I will do the passengers side next week, but the noise don't make since to me....going straight on the highway I hear it....as I start to turn to the left the noise goes away, until I straighten up again....I would think the opposite. If the passenger bearing is bad, then wouldn't the noise get louder? Any suggestions?
  11. Apr 21, 2011 at 12:11 PM
    fubar
    fubar Active Member
    Maybe they were both pooched? Just one worse then the other?
    When I'm on the highway, the noise goes away when I turn right... so I'm assuming its the right wheel bearing. :confused:
    You got your bearing assebley off ebay right? Did you pick-up a hub somewhere and have it pressed before hand? Or did you just take yours off and bring it to a shop?
  12. Apr 21, 2011 at 3:01 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Ya I got 2 of the bearing assemblies off eBay. I just took the hub and bearing off the truck and had a shop take the old one off and press on the new one. They charged me 40 bucks. I'll do the other side next week.
  13. Apr 21, 2011 at 7:43 PM
    fubar
    fubar Active Member
    Gotcha. I bought the used hub off of Diablo and had a bearing assembly pressed on today. Will hopefully tackle it this weekend. Would nice to have it done before the opening of turkey season (monday).
    Did you buy the two seals and one o-ring from Toyota? I did... almost $70! What a scam...
  14. Apr 21, 2011 at 9:01 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Umm, taking a shot in the dark here, hows your tires ?
  15. Apr 21, 2011 at 11:03 PM
    #35
    Taco93
    Milton, Ontario
    2011 TRD Sport
    I am planning on changing both front bearings so I bought 2 outer seals and 2 inner seals from partsource (total price 67$). I had the truck all apart in the garage when I went to Toyota for the o ring but they had none in stock so I re used the old one. It looked fine. It's a good thing I bought the inner rings cause the one I removed so far was worn so bad, the little wire coil/spring that is wrapped around the rubber part was completely worn through on about 1/4 of the seal. I'll tackle the pass side next week. Oh, the shop charged me 40 bucks to remove the old bearing from the hub and press on the new one..he said the bearings were rusty..
  16. Apr 21, 2011 at 11:04 PM
    #36
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Brand new, I had them change the tires about a week ago!
  17. Apr 21, 2011 at 11:08 PM
    #37
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    I had the same wheel bearing problem, but only on the front left.
  18. Apr 22, 2011 at 8:58 AM
    #38
    fubar
    fubar Active Member
    Interesting! I initially only priced the outer seal at Part Source and it was the same price as Toyota. They also didnt have it in stock, so I went to Toyota to buy it. Toyota mentioned I should get the inner seal and O-ring.... the inner seal at Toyota was about $35!! I'll go back to Part Source and see what their price is for the inner...
  19. Apr 24, 2011 at 11:52 AM
    #39
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Seal at napa.
    NOS 31897
    Edit: Link didnt work, part number instead.
  20. Apr 24, 2011 at 11:59 AM
    #40
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
