these fit right??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachoTaco10, Feb 17, 2010.
  1. Feb 17, 2010 at 2:08 PM
    MachoTaco10
    MachoTaco10 [OP] Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    do these fit? I know the bolt pattern is correct but want to make sure before I buy them tonight. Thanks guy...EAGLE ALLOYS 185's[​IMG]
    Wheel Diameter17 in.Wheel Width (in)9.00 in.Backspacing (in)4.625 in.Offset (mm)-8.00mmWheel MaterialAluminumWheel FinishBlackWheel Construction1-pieceBeadlock IncludedYesBeadlock FunctionalNoLug Nut Seat StyleConical seat - 60 degreeHub CentricNoCenter Cap IncludedYesLoad Rating (lbs)2,100 lbs.
  2. Feb 17, 2010 at 3:09 PM
    thedude5108
    thedude5108 Well-Known Member
    Jamie
    Los Olivos, CA
    07 Tacoma TRD 4x4 Dub cab
    16x8 Series 185 Eagle Alloys, Billy 5100's at 1.75, and a bitchin Mag Lite mount :)
    Just got these same wheels in 16x8 with 4" backspacing and -11 offset. I had to grind the calipers for clearance. But barely anything. You should be fine.
  3. Feb 17, 2010 at 5:23 PM
    MachoTaco10
    Nick
    New Hampshire
    ok thanks man, 17's should be just enough then
  4. Feb 17, 2010 at 6:42 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    Saw these on an older style Tundra and they look sharp!
